Old Dec 30, 2012, 09:18 PM
Canada, ON, Chatham-Kent
Joined Nov 2012
Losi XXX readylift Battery? I have no clue
I have no clue which battery I need. I seen horizon hobby had a 6000mah 60c Lipo but it was $75. That's way to much for a battery IMO. I just need something cheap. Will a 5000mah 20c turnigy from hobby king work?
ShowTime88 is offline Find More Posts by ShowTime88
Old Dec 30, 2012, 09:43 PM
Obeying the law of gravity
Jeremy Kamutzki's Avatar
Canada, ON, Cambridge
Joined Jul 2011
Yes, if your car runs on 2s lipos that pack will be fine. It has a max discharge rating of 100A and I can't imagine a car running on 2s lipos would draw close to that current.
Turnigy packs ar good, as well as zippy and nanotechs. The nanotechs usually have higher discharge ratings so you might notice a bit more power.
Gens ace batteries are also good and they're sold be hobbypartz.
Jeremy Kamutzki is offline Find More Posts by Jeremy Kamutzki
Old Dec 30, 2012, 10:28 PM
Joined Nov 2012
Can I use anything from 20c to 60c on this truck? What's the difference?
Old Dec 31, 2012, 09:54 AM
Joined Jul 2011
The c rating is a number that tells you how many amps your battery pack can discharge at. To find this out, you must take the c rating and multiply it by the Ah (amp hour) of your battery. The ah of your battery is found by dividing the mah (5000 in your case) by 1000 to find the Ah capacity, so your battery would have a capacity of 5 amp hours. The amp hour of the batterymultiplied by the c rating gives you the max discharge rate of the battery in amps. You want this number to be higher than the amp rating of the esc because the esc will only pull what it needs and the battery will puff if it can't discharge as fast as what the esc requires.
So, to answer your question, if your esc rating is less than 100A then the 5000mah battery will work and if it's less than 360A then the 6000mah battery will work fine.
Usually you will feel a bit more punch with a higher c pack because it's just able to deliver the required current quicker.
Discussion 1/10 ReadyLift XXX-SCT comparable Lipo? ShowTime88 Off-road Cars 8 Jan 02, 2013 01:40 PM
For Sale Losi xxx-sct and xxx-scb plus parts lot Beauregard Cars - Trucks and Parts (FS/W) 0 Aug 10, 2012 05:56 PM
Build Log Have no clue what I'm doing... EPP Air/Swamp Boat KTMRacr Dock Talk 17 Jul 16, 2012 11:24 AM
Discussion No clue - have inherited ic boat can't start it... Russellaga Racing Boats - Internal Combustion 1 Sep 15, 2008 03:59 PM
