Old Jan 01, 2013, 03:47 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
I use Titebond III which is a waterproof white/carpenters glue. I brush a thin coat on the backside of Coverlite and iron it on before it dries. Also works good for repairs over existing coverlite even if painted. I don't know what is in Balsa Loc and the other formulas like BalsaRite but white glues seem to work great and I especially like the waterproof ones since I live in Western Oregon where it rains or is very damp at least half the year. Seems like I remember the Balsa Loc being kind of expensive.
Dave
payne9999 is offline Find More Posts by payne9999
Old Jan 01, 2013, 10:34 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Titebond III sounds like a good choice. I don't use it for building because it doesn't sand as well as Titebond II. But, it is more water resistant and flexible, just what is needed for covering.
There are so many variations in "white" glues it pays to try a few out. I don't like Elmer's "School" white glue (it does not dry clear for me). Then there is "Tacky Glue". I use it in place of canopy glue (Formula 560).
So, try out a few different 'white' glues. If one doesn't work, try another.
portablevcb is offline Find More Posts by portablevcb
Old Jan 07, 2013, 05:06 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Originally Posted by J Morgan View Post
We need Fuzz to weigh on on this. He has used it for years on everything from tissue covering to putting in on his breakfast cereal. Fuzz knows Mod Podge!
J
Yes, I have been using it for years! I have used it, along with aliphatics, for heat laminating woods and covering frames. Sealing foam plugs, foam planes(bite my lip)
One thing I have noticed about mod-Podge, once cured it is indeed waterproof. It dries and cures much harder than aliphatics, which means it sands easier. My most recent use, is wood laminations for surface outlines. Ammoniated water used to relax the wood, does not seem to affect the cure, which is faster than aliphatics. And sands so much easier.
Gloss seams to work better for heat proccesing. Less porosity. But for coating/finish work, the matt sands real easy. Mix a little talc into it, thin it about 25% with water, and it's a great sandable sealer on foam. I prefer not to use water based products on wood surfaces. So I still use the smelly old Balsa-Rite for my Kover-All, Poly-span, and dress lining coverings, as I use lacquer sealers anyway.
Here the Firefly laminations being done with matt(for easy sanding) Mod-Podge.
Fuzz
St. Martin is offline Find More Posts by St. Martin
For Sale (5x) DYS A3536-11 750KV Brushless Motors (same as 2814-11's)- $70 shipped CONUS Mactadpole Aircraft - Electric - Multirotor (FS/W) 2 May 10, 2012 01:51 AM
Discussion Symetrical airfoils same as plate wings? joe_crash Modeling Science 33 Mar 31, 2012 09:10 AM
Discussion AXI motor same quality as Scorpion gtxkid Electric Motor Design and Construction 35 Mar 04, 2012 02:00 PM
Discussion Mod Podge warhead_71 Foamies (Scratchbuilt) 34 Mar 17, 2009 07:03 PM
balsa loc southern soarer uk Composites Fabrication 2 Apr 01, 2005 04:21 PM
