Old Dec 30, 2012, 05:30 AM
Stuey is offline
Find More Posts by Stuey
Aylesbury,UK
Joined Apr 2000
Wemo minifan no spinner a big loss?
Hi guys I have just finished mounting a minifan in my 64mm F-15. I ran it up briefly on 3s to check the direction before fixing it in. Now it is glued in with the ali spinner I have checked it again with a full power run up on 4s. At about 1/3 throttle there is a slight vibration but is smooth through the rest of the range. I noticed the spinner does not look true when spinning slowly, and there is slight run out on the fixing screw head. Will I lose out much by leaving it off? It was very hard to push onto the rotor and is fitted ok as far as I can see.
Stuey is offline Find More Posts by Stuey
Old Dec 30, 2012, 06:08 AM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
have you tried spinning the spinner 20* until that goes away.
D_FAST is online now Find More Posts by D_FAST
Old Dec 30, 2012, 06:36 AM
Stuey is offline
Aylesbury,UK
Joined Apr 2000
I would try that but the spinner is so difficult to seat it would take forever. I have had the same problem with fitting the spinner with one of my other minifans so left it off.
Old Dec 30, 2012, 08:40 AM
tom bacsanyi is online now
Find More Posts by tom bacsanyi
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
This has been investigated by me and others. Expect a static thrust loss of 3 to 5%.
tom bacsanyi is online now Find More Posts by tom bacsanyi
Old Dec 31, 2012, 03:32 AM
Stuey is offline
Aylesbury,UK
Joined Apr 2000
I found a new spinner which I must have ordered seperately some time ago now. It looks to have a better quality machine finish on the inside, and the countersunk hole for the fixing screw is deeper meaning the screw fits in better. I fitted that one and gave it a run this morning and it was much better. Still a very slight vibration at 1/4 throttle, but completely smooth through the rest of the range. As it is awkward to remove to try turning it looking for complete perfection, I am happy to run it as is. Thanks for the input
Old Dec 31, 2012, 03:52 AM
ravikoth is offline
Find More Posts by ravikoth
RAVI KOTHARI
Joined Nov 2005
I am flying Mine since over a year with no spinner, flies perfect no thrust loss at all.
Mine slipped off and tore the duct, i then removed the EDF and reinstalled the same. not an iota of difference. (To me)
ravikoth is offline Find More Posts by ravikoth
For Sale wemotec 70mm minifan rotor and spinner the big g Aircraft - Electric - Jets (FS/W) 2 Aug 15, 2012 03:08 PM
Sold NIP Wemo Minifan PRO flyregfly Aircraft - Electric - Jets (FS/W) 0 Aug 15, 2012 07:03 AM
Sold WeMo MiniFan Rotor Spinner Adapter Combo! termite Aircraft - Electric - Jets (FS/W) 2 Apr 25, 2008 04:53 PM
Help! Wemo Minifan 480 rubbing HET F-18 dirtypool Electric Ducted Fan Jet Talk 26 Oct 13, 2006 12:13 AM
Discussion Max RPM's for a Wemo minifan 480? tho98027 Electric Ducted Fan Jet Talk 1 Jul 08, 2006 03:28 PM
