Old Jan 02, 2013, 02:01 AM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
Nice man!
But 45f I guess I'm hoping the full winter to 40c but it won't happen..... ;-)
Maybe I'll start building micro edf planes on gas for global warming like edf40 cox :-p
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Jan 02, 2013, 05:02 AM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
thanks Robert,
well pulled the fan out and sure nuff all four screws that hold the motor in the housing were not only loose they were WAY loose, so I used a thin wire to spread some thick CA under the screw heads and ran them down tight, put everything back together and spooled her up, judging by the definite thrust increase I think the screws had been loosened while testing before the maiden...and it flew anyway so now I expect it should zip along even better!
maybe this weekend I get some more footage and see just how long these 360mah batts will go in this thing. very fun little jet to fly!
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Jan 02, 2013, 09:45 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
You can go 4S on the stock BH/ArtTech fan with motor combo...I took this vid last March with the winds HOWLING!!!...Even with the drop tanks on the ArtTech/BH F-86 was a missile!!!...I have a couple of vids with the drop tanks off and the plane is even faster...You can hear the RPM difference on 4S vs your 3S version...Here's the vid...
ArtTech Sabre 3 16 12 (4 min 4 sec)
Your "box" planes are DA BOMB!!!....With the MiG 17 being exceptional as you don't see these planes modeled hardly at all....
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Jan 03, 2013, 03:26 AM
sloperjoe's Avatar
Joined Mar 2012
hey thanks Kevin!
I knew I saw this video someplace before, while researching the different power set-ups in the various micro jets...looking for suitable fan units other than the AEO stuff. your video was actually what got me to buy a couple of these fan/motor units from Banana Hobby off the "parts" section for the Art Tech F-86. the other criteria I had was it needed to have enough poop to fly a model with regular servos and RX, which these do. I did take the case off the RX not so much for weight savings but to get rid of as much airflow blockage as possible. the servos are mounted inside the fuse but I cut a block out of the inside layer so they are tucked in away from the flow.
as far as going 4s with this model....I don think I can get a 4s pack in it and maintain CG without adding weight to the tail. if I had made it a touch bigger it probably wouldnt be a problem. mabey the next model I'll build as a 4s version with the other fan unit
does look fast and fun!
thanks again!
Joe
Old Jan 27, 2013, 07:16 AM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Joe, nice project, I really like the Migs, they look very cool in the air.. Can you show where you've got the receiver and battery located? Thx w
Waltjg is offline Find More Posts by Waltjg
Old Jan 27, 2013, 07:19 AM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Oh, and tell your daughter excellent camera work keeping up with these little guys! w
Old Jan 27, 2013, 03:07 PM
sloperjoe's Avatar
Joined Mar 2012
Howdy Walt!,
I really love this one, flies even better with the motor screws run down tight
took some pics for you, they're a bit fuzzy but you can see where everything is mounted. some of you will cringe when you see everything is mounted in the intake airflow... trust me, looks "rat-nesty" but the fan gets plenty of air, and everything stays cool
thanks Walt, its great to have her shoot these, its alot better than my cheezy hat cam
Joe
Old Jan 27, 2013, 10:34 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Thanks for the pics Joe! This is a cool little plane... Still have that little aluminum fan I bought, maybe abit bigger version of this for that fan... Hummmmmmmmm. w
Discussion 'Stick and tissue' Mig 17 Fresco for 30mm EDF JetPlaneFlyer Micro EDF Jets and Power Systems 80 Jan 28, 2015 01:40 PM
Build Log Russian Jets, Yak-15, and Yak-17 Feather, in 30mm EDF. Freddie B Micro EDF Jets and Power Systems 407 Nov 16, 2012 01:08 PM
Wanted HK 30mm dia, 3.17 shaft AL spinner Chuchuf Aircraft - General - Miscellaneous (FS/W) 0 Jul 28, 2012 09:39 AM
Wanted HK 30mm 3.17 shaft al spinner Chuchuf Aircraft - Electric - Power Systems (FS/W) 0 Jul 28, 2012 09:38 AM
For Sale DCU MiG-17 fuse...I think. nauga Aircraft - Electric - Jets (FS/W) 4 Sep 02, 2008 10:53 PM
