View Poll Results: As a Wasp Nano CP owner, would you consider getting the Wasp X3V as well?
Yes 19 45.24%
No 8 19.05%
Not sure or don't know 15 35.71%
Voters: 42. You may not vote on this poll
Old Jan 06, 2013, 09:47 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Lentar...great to hear about crash parts. Thx
ridge_racer is offline Find More Posts by ridge_racer
Old Jan 06, 2013, 10:06 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Originally Posted by Lentar View Post
The actual values you are supposed to put in the pitch curve are:
30, 35, 45, 55, 60 (Normal flying)
25, 35, 45, 55, 65 (Stunt flying)
Whatever the actual values, it does not make a difference, as the value 25 gives maximum negative pitch, and 65 gives maximum positive pitch.
In both curves, 45 gives zero pitch at mid-throttle.
Actually the middle numbers will make a difference on how the stick feels during the transitions of points in those curves between the minimum and maximum pitch. The more linear the more smooth it will be and is why most instead choose to forgo adjusting pitch for a micro cp on the pitch curve and instead leave it linear and adjust pitch end points with travel adjust.
On a properly setup CP heli 0 pitch should be 50% pitch curve ( or 0 on -100 to +100 radios) and 50% stick, anything else is incorrect for a CP heli and you might as well start off right
To get an -11 with 0 pitch at 45% (midstick) and +11 pitch with a curve that starts at 25 and ends at 65 they have adjusted the servo arm or pitch links length and/or messing with software. It should be 25 through 75 to have equal degrees of output and 0 pitch at 50%
What I really dont understand is how the two pitch curves 30, 35, 45, 55, 60 (Normal flying) and 25, 35, 45, 55, 65 (Stunt flying) give -2 pitch for 30% and -11 pitch for 25% and 10 pitch at 60% and 11 pitch at 65% between the two modes unless they are messing with travel limits as well on the regular and/or stunt mode.....
indoorheli is offline Find More Posts by indoorheli
Old Jan 07, 2013, 01:05 AM
Joined Nov 2010
Did banggood drop the price today or tonight? I had it in my cart with some parts this morning. I couldn't wait so I bought it. I paid 98 bucks for the colored box version with a lot of spares. Landing gear, motors, tail booms, extra lipos, tail rotors, linkages, canopy, main shafts, main gear, feathering shaft, rotor head, and blade grips...wheww...All came up to 139 shipped. I had a 5 dollar off coupon.
Old Jan 07, 2013, 01:47 AM
Joined Nov 2010
Just found this link online. http://events.rc-fever.com/ . Free spare parts for making a video of this thing flying...lol
Old Jan 07, 2013, 06:01 PM
Lentar is online now
Find More Posts by Lentar
Joined Oct 2012
Another thing I've noticed is that if you change say one value on the pitch curve, it seems to change the actual pitch at the other points as well, which is not something I was expecting. So its clear that something has been done in the software on the receiver.
Lentar is online now Find More Posts by Lentar
Old Jan 07, 2013, 06:37 PM
Joined Oct 2012
Now that is what I call an impressive parts order. Let us know when you get it!
Old Jan 08, 2013, 04:48 AM
skyartec_michael is offline
Find More Posts by skyartec_michael
Michael Skyartec
Joined Dec 2012
Wireless Training function video
Originally Posted by skyartec_michael View Post
@Lentar
Please follow the steps below to set the student-trainer function:
1.Bind the receiver with the Student Transmitter in STD MODE(the Receiver can be bind with transmitter only in STD MODE)
2.Set the Student Transmitter to SLV MODE.
3.Set the Teacher Transmitter to MAS MODE and select AT.( press "EXIT" When AT is flashing to confirm the auto detect setting)
4.Turn off all transmitters & receiver,
5.Turn on the Student Transmitter.
6.Turn on the receiver.
7.Turn on the Teacher Transmitter.
8.The Teacher Transmitter will beep once after successfully bind with the Student Transmitter.
9.Now you may use the student-trainer function without a wire connection between two NASA-701.
10.With the left ear down, the heli will be controlled by the Teacher Transmitter,
And with the left ear up, the heli will be controlled by the Student Transmitter.
Michael
Here I uploaded the video:
Setting Wireless Trainer-Student Function on Skyartec NASA701 (5 min 11 sec)
skyartec_michael is offline Find More Posts by skyartec_michael
Old Jan 08, 2013, 11:52 AM
skyartec is offline
freexgroup
Joined Feb 2006
now we have offer 1.1 for red light software upgrade
it can let wasp nano cp more stable on red light mode.
skyartec is offline Find More Posts by skyartec
Old Jan 08, 2013, 12:05 PM
jimqjp is offline
Find More Posts by jimqjp
Joined May 2012
" I believe the Mini CP landing gear is supposed to fit."
Is there any one measured the dimensions of the land gear?
jimqjp is offline Find More Posts by jimqjp
Old Jan 08, 2013, 02:24 PM
Joined Nov 2010
Will do. Very excited about this..
How do I upgrade the software? Does the kit include a programming cable for the radio?
Old Jan 08, 2013, 02:33 PM
Stevez1kart is offline
Find More Posts by Stevez1kart
Trees are bad
Stevez1kart's Avatar
United States, NE, Omaha
Joined Sep 2012
How do I upgrade the software? Does the kit include a programming cable for the radio?[/QUOTE]
This may or may not be what you want. I haven't seen it included with kits.
http://www.skyartec.com/ProductShow.asp?ArticleID=1694
Stevez1kart is offline Find More Posts by Stevez1kart
Old Jan 08, 2013, 02:54 PM
Trees are bad
Joined Sep 2012
Ok I think the above post is incorrect. Look at this instead.
http://www.skyartec.com/ProductShow.asp?ArticleID=1879
Old Jan 08, 2013, 05:09 PM
Joined Nov 2010
Looks like a SIM cable..?
Old Jan 08, 2013, 10:10 PM
Joined Oct 2012
Yes this is the SIM cable which you need to use with the NASA-701 transmitter. The cables used with the older transmitters don't seem to work. The 8 in 1, 12 in 1 types of sim cable-USB dongles that you may have seen on the internet and eBay also do not work, since they do not have the 5 point DIN plug which Skyartec uses.
I've actually ordered one for myself (has not arrived as yet)
Old Jan 08, 2013, 10:20 PM
Joined Nov 2010
So firmware updates are accomplished with this cable as well?
New Product SkyArtec Wasp 100 Nano CP zadaw Micro Helis 175 Aug 08, 2013 08:17 PM
Discussion Check Out the New WASP 100 Nano CP Parkflying Skyartec 0 Nov 04, 2012 04:11 AM
Sold Skyartec Wasp 100 JGuilty13 Aircraft - Electric - Helis (FS/W) 3 Jun 08, 2012 02:28 AM
New Product 5 Channel SKYARTEC Wasp 100 Coming! (Video) zadaw Micro Helis 27 Sep 26, 2011 07:49 PM
New Product Skyartec WASP 100 Mini Helicopter Parkflying Product Announcements 0 Apr 27, 2011 01:04 PM
