View Poll Results: As a Wasp Nano CP owner, would you consider getting the Wasp X3V as well?
Yes 19 45.24%
No 8 19.05%
Not sure or don't know 15 35.71%
Voters: 42. You may not vote on this poll
Old Jan 03, 2013, 01:34 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Originally Posted by Stevez1kart View Post
Banggood for one, RTF with and without case on next page. http://www.banggood.com/buy/wasp.html
Miracle Mart also with free shipping but looks like currently out of stock.
http://www.miracle-mart.com/store/in...oducts_id=9869
Thx Steve..
ridge_racer is offline Find More Posts by ridge_racer
Old Jan 03, 2013, 10:50 PM
Lentar is offline
Find More Posts by Lentar
Joined Oct 2012
Procedure for using trainer function in NASA-701?
@ Skyartec-Michael
1. I set one transmitter to SLV, and the other to MAS.
2. In the MAS transmitter, I selected AT, for automatic detection of the student transmitter.
3. I then turned off the MAS transmitter.
4. After binding the student transmitter, I switched on the MAS transmitter, but the MAS transmitter does not seem to control the heli with ear up or down?
Can the student-trainer function be used without a wire connection between two NASA-701 s?
Lentar is offline Find More Posts by Lentar
Old Jan 04, 2013, 01:45 AM
skyartec_michael is offline
Find More Posts by skyartec_michael
Michael Skyartec
Joined Dec 2012
Originally Posted by Lentar View Post
@ Skyartec-Michael
@Lentar
Please follow the steps below to set the student-trainer function:
1.Bind the receiver with the Student Transmitter in STD MODE(the Receiver can be bind with transmitter only in STD MODE)
2.Set the Student Transmitter to SLV MODE.
3.Set the Teacher Transmitter to MAS MODE and select AT.
4.Turn off all transmitters & receiver,
5.Turn on the Student Transmitter.
6.Turn on the receiver.
7.Turn on the Teacher Transmitter.
8.The Teacher Transmitter will beep once after successfully bind with the Student Transmitter.
9.Now you may use the student-trainer function without a wire connection between two NASA-701.
10.With the left ear down, the heli will be controlled by the Teacher Transmitter,
And with the left ear up, the heli will be controlled by the Student Transmitter.
Michael
skyartec_michael is offline Find More Posts by skyartec_michael
Old Jan 04, 2013, 11:34 AM
Lentar is offline
Joined Oct 2012
Originally Posted by skyartec_michael View Post
@Lentar
Michael
I did this procedure, however when the left ear of Teacher transmitter is down, the heli LED turns off, and the servos do not work (from either teacher or student transmitter)
When the left ear of teacher transmitter is up, the heli led lights up and the student transmitter is able to move the servos.
When AT was flashing I pressed "Menu" once and then turned off the transmitter.
Update
OK, I managed to get this running, but I had to feed in the transmitter S/N values manually, how do you get the AT command to execute? When you see the flashing AT command, what do you do next?
Old Jan 05, 2013, 11:06 AM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
Has anyone compared this side by side to the MiniCP it was cloned after?
GiantScale is offline Find More Posts by GiantScale
Old Jan 05, 2013, 11:45 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Here are a couple of threads in a Taiwanese forum. Sorry, my written Chinese is too poor to translate them. In the second thread, the Taiwan distributor for Walkera suddenly stepped in and threatened to sue anyone who spoke badly of him and Walkera. A number of members got scared and modified their posts.
http://www.rctw.net/thread-241230-1-1.html
http://www.rctw.net/thread-244042-1-2.html
zadaw is offline Find More Posts by zadaw
Old Jan 05, 2013, 03:49 PM
helikido is offline
Find More Posts by helikido
United States
Joined Aug 2009
This is basically a super cp clone.
helikido is offline Find More Posts by helikido
Old Jan 05, 2013, 10:13 PM
Lentar is offline
Joined Oct 2012
Since this has preceded the Super CP, it can't be its clone
But if you say its a mini CP clone........
Old Jan 06, 2013, 04:16 AM
Michael Skyartec
Joined Dec 2012
Update
@ Lentar Please press "EXIT" When AT is flashing to confirm the auto detect setting, I will take a video tomorrow to show all those steps more clearly.
Michael
Old Jan 06, 2013, 08:15 AM
Lentar is offline
Joined Oct 2012
Michael
Thanks, and we really appreciate the support provided us by you!
Old Jan 06, 2013, 10:11 AM
helikido is offline
United States
Joined Aug 2009
As far as I know the mini cup doesn't use the same servos or Rx unit?
Old Jan 06, 2013, 12:58 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Originally Posted by FyreSG View Post
This is strange because (typically) the pitch values are in the range of 0 to 100 (percent?) and so, throttle at minimum point is 0%, full throttle is 100%, so mid stick = 100 / 2 = 50%.
What is the reason behind shifting the mid point to 45%? To give a larger positive pitch range?
Maybe this is different in the world of micro CP helicopters. The larger birds that I configured are not like that.
Yeah I would think it is either programmed incorrectly or there is something lost in translation. I see no reason to have 50% not be 0 pitch in either mode unless you want to train your muscle memory for a non proper setup for all other properly setup CP helicopters
The rx unit is all theirs, but it uses a lot of the same parts as the minicp..which the superCP also uses most of the parts as well. Like the superCP both are based off the miniCP
indoorheli is offline Find More Posts by indoorheli
Old Jan 06, 2013, 01:47 PM
Joined Nov 2010
If I purchase this micro, what are some common spares I should also order as well?...Parts likely to break or fail?
Old Jan 06, 2013, 08:14 PM
Lentar is offline
Joined Oct 2012
The actual values you are supposed to put in the pitch curve are:
30, 35, 45, 55, 60 (Normal flying)
25, 35, 45, 55, 65 (Stunt flying)
Whatever the actual values, it does not make a difference, as the value 25 gives maximum negative pitch, and 65 gives maximum positive pitch.
In both curves, 45 gives zero pitch at mid-throttle.
Old Jan 06, 2013, 08:22 PM
Lentar is offline
Joined Oct 2012
1. Spare canopy (unless you do the Scotch tape mod as in my review)
2. Landing gear
3. Tail rotor
4. Tail rotor cover
5. Tail boom
This is just a suggestion, as the heli seems quite robust. Actually the only part I had to replace was a tail rotor following a crash on stony ground. Flying over grass and hitting throttle hold when you run into trouble will minimize crash damage.
New Product SkyArtec Wasp 100 Nano CP zadaw Micro Helis 175 Aug 08, 2013 08:17 PM
Discussion Check Out the New WASP 100 Nano CP Parkflying Skyartec 0 Nov 04, 2012 04:11 AM
Sold Skyartec Wasp 100 JGuilty13 Aircraft - Electric - Helis (FS/W) 3 Jun 08, 2012 02:28 AM
New Product 5 Channel SKYARTEC Wasp 100 Coming! (Video) zadaw Micro Helis 27 Sep 26, 2011 07:49 PM
New Product Skyartec WASP 100 Mini Helicopter Parkflying Product Announcements 0 Apr 27, 2011 01:04 PM
