Old Dec 29, 2012, 01:34 PM
Scarlet is offline
Find More Posts by Scarlet
Oh no!
Scarlet's Avatar
Wales(UK)
Joined Jul 2004
New HK450MT build issue
Hi all.I'm currently building an alloy HK450MT and replacing some of the more dubious parts with genuine Align ones.I'm now building up the tail end and replacing the rotor control arm and the bearing mount that runs on the tail rotor shaft,because there a fair amount of slop there and I recall somewhere that replacing these items with genuine ones reduces it somewhat.The original bearing mount is set in plastic and looks as though it has a brass sleeve running inside and is fixed to the pitch assembly .I can't get the bearing mount off this sleeve;it must come off or the bearing mount wouldn't be available as a spare part(would it?).The only thing I can think of is that it's held on by green bearing retainer.Does anyone know?Thanks in anticipation.
Scarlet is offline Find More Posts by Scarlet
Old Dec 30, 2012, 06:44 AM
kdill2160 is offline
Find More Posts by kdill2160
"Heli-Pimp"
kdill2160's Avatar
McHenry, IL
Joined Mar 2003
Heat it with the tip of a soldering iron for about ten seconds, the heat will loosen the thread locker, then unscrew the t type arm from the slide shaft...
JMO... Ken
kdill2160 is offline Find More Posts by kdill2160
Old Dec 30, 2012, 06:41 PM
Scarlet is offline
Oh no!
Scarlet's Avatar
Wales(UK)
Joined Jul 2004
Ah.I thought it might be held on with bearing retainer.I didn't know for sure whether to heat it up or not in case HK decided this part should be made as one piece.Thanks for your input.
Help! Is this an ESC / Motor issue? (First Quad build) TEDious Multirotor Talk 4 Mar 20, 2013 11:59 AM
Help! Set up issue for first foamie build... dbdan Power Systems 4 Apr 01, 2012 08:23 PM
Alert NEW BlitzRCWorks Thrust Vectoring EPO F16......BEWARE OF FACTORY BUILD ISSUE kydawg1 Banana Hobby 4 Aug 12, 2011 11:33 AM
For Sale Hk450mt rtf Brand new Savy92 Aircraft - Electric - Helis (FS/W) 2 Mar 30, 2011 11:05 PM
