My X1 board in a v929 perform like the stock radio t 100% rate. Even though I have it with -100 expo.
Big difference than the other night flying Heli Pad's real X1 with the same TX configuration. I can only think of the gear ratio difference or motor being the culprit. Perhaps a combination of the two. I will try giving it a aggressive output curve on the ail and elev channels to see if I can improve it's performance. I tried using a v949 TX too. This TX can flip the X1. It flips great. Need to put another battery through her. |
Latest blog entry: Syma S105 Battery Mod
SMD resistors adds negligible weight. I would solder it on the LED bar themselves.
Valdosta Ga.
Joined Jun 2008
These will work.
http://www.amazon.com/Cold-White-Lig...ini+led+lights Mine were nearly identical to this set. (More on that later) the circuit has a resistor in the battery box and runs off in the same voltage range as the little Lipo. Mine were red and, ok, to be honest, they were shaped like hearts, (I found them in a drawer and they were forgotten by the wife, don't judge me) but a set of side cutters trimmed them nicely into little plastic LED nubs exactly like the ones being sold here. The power wire they are strung on is mildly stiff and moldable with a thin nonconductive coating. I used little dots of hotmelt to affix them around the frame and at the ends of the booms. There were enough lights to circle the frame and put at least two on each boom. If you don't want as many, just trim the line when you are done. They are wired in parallel. I ended up not using 8 lights from the end of the string. If you are a gram counter, I imagine you are having an aneurism right now, but for night hoonage, this fits the bill nicely and flies great. Here are some uploaded pics of it in the dark and a close up of the resistor and switch. Heavy? Perhaps. Cool? Oh, heck yeah. http://www.flickr.com/photos/photone...7632418763778/ I was still able to lift an 808 cam in a shrink wrap sleeve after this. |
Valdosta Ga.
Joined Jun 2008
Forever. When the light goes out, I unplug it. (it isn't even warm.) ill use a sack from now on and budget for a 1s charger. |
Good luck and please be careful. |
Did gyokeres mention what lipo he uses? Perhaps the one he uses has the protection circuit build it already?
Valdosta Ga.
Joined Jun 2008
Great point. I am using these. http://www.amazon.com/gp/product/B00...ls_o06_s00_i00 It does say they are not available any more. Perhaps there is a circuit under the cap. Looks like I got really lucky in my ignorance, but that would have made a great story. |
| Thread Tools | |
| Discussion Syma 2012 new publish, syma X1, S800G, S107C,S036G,what's better | wjh041 | Coaxial Helicopters | 8 | Mar 18, 2013 11:12 AM |
| New Product Syma X1 Quadcopter Spare Parts | wjh041 | Beginner Training Area (Aircraft-Electric) | 1 | Nov 03, 2012 05:55 PM |
