Old Feb 09, 2013, 07:59 AM
davyg is offline
Find More Posts by davyg
United Kingdom, Scotland, Stranraer
Joined Mar 2012
real Noob question here guys.... but how long would it take to charge up 2 x 600mah nano tech batteries in series using a Turnigy Accucel 6 charger???
I have a 2 x loom and a 4 x loom... connected to an XT-60 Connector
davyg is offline Find More Posts by davyg
Old Feb 09, 2013, 12:10 PM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Originally Posted by TheSelf View Post
Thanks Heli pad-Good and helpful advice- is there a particular way to get at the motors without forcing or breaking anything?
Post #3. FAQ#7 (at the moment).
Heli Pad is offline Find More Posts by Heli Pad
Old Feb 09, 2013, 12:15 PM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
Accucel 6 is a variable rate charger. You could dial it up and down as you like. Conventional wisdom is to charge Lipo at 1C (safest). In this case 1C for a 600mAh battery is 0.6A. And that will take approx. an hour to charge.
But, I usually charge NanoTech at 2C, or 1.2A per cell. Theoretically charge time is 30 mins. Realistically, it's more like 40 minutes, because a smart charger with slow down the charge rate at the end of the cycle.
For two 600's, if you use a parallel cable, you should be using 2.4A for 2C, or 1.2A for 1C, etc.
Old Feb 09, 2013, 12:19 PM
davyg is offline
Joined Mar 2012
cheers for that...
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
Originally Posted by somebodyelse View Post
I don't know if it is helpful or what it would mean for programming a 9x (don't have one yet) but I bound the X1 remote with a WLToys V911 and pressing the flip button causes the heli to do a hard rudder right.
Well, AFAIK, the V911 is not designed to flip.
I don't own a V911 Tx, but I was under the impression that it doesn't have a working right shoulder button. I was surprised to see that it actually do something. But no, I don't think you could flip the X1 using the V911 Tx. You could do everything else.
To flip an X1 and have better range, you should use a V929/V949 Tx or equivalent.
Old Feb 09, 2013, 01:32 PM
craigiri is online now
Find More Posts by craigiri
Critic at Large
craigiri's Avatar
United States, RI, Portsmouth
Joined Nov 2012
Originally Posted by tdearth View Post
craigiri has one that will time travel.
I like this posted video of a blizzard that is going to happen in Feb. 2014.
Tim
That's about when I should be dug out........
craigiri is online now Find More Posts by craigiri
Old Feb 09, 2013, 05:37 PM
krefi is offline
Find More Posts by krefi
rather fly, but this'll do
krefi's Avatar
Portland, OR
Joined Feb 2008
X1 TIE Fighter! Video to follow....
krefi is offline Find More Posts by krefi
Old Feb 09, 2013, 05:40 PM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Now THAT is something really cool ...
Old Feb 09, 2013, 05:42 PM
reptileman is online now
Find More Posts by reptileman
nj
Joined Jan 2004
That's going to be awesome!!
reptileman is online now Find More Posts by reptileman
Old Feb 09, 2013, 05:47 PM
krefi is offline
krefi's Avatar
Portland, OR
Joined Feb 2008
It flies really heavy, understandably. And the wind, forget about it. But it does fly.
Old Feb 09, 2013, 07:19 PM
ronrc is offline
Find More Posts by ronrc
Joined Nov 2004
basic trim question
when I adjust the trim the effects aren't that obvious to me, so I'm trying to see if it's working properly.
If it moves forward in hover.
Would you move the forward/backward trim on the left or right of the transmitter?
if moving left or right in hover (flat) would you move the left/right trim on the left or right side of transmitter.
I hope this makes sense.
Thanks, Ron
ronrc is offline Find More Posts by ronrc
Old Feb 09, 2013, 07:22 PM
Greg Head is offline
Find More Posts by Greg Head
Joined Aug 2012
Thanks, Ron
Right side for both of those. The left stick is throttle and rudder so the trims on the left are for the throttle and rudder.
Greg Head is offline Find More Posts by Greg Head
Old Feb 09, 2013, 07:30 PM
ronrc is offline
Joined Nov 2004
Ok thanks that makes sense. Does it matter if you are in mode 1 or 2?
Old Feb 09, 2013, 08:04 PM
Joined Aug 2012
mode on the screen refers to dual rates not real mode one and two. If the throttle is on the left you have a mode 2 controller.
Old Feb 09, 2013, 09:57 PM
GorillaBob is offline
Find More Posts by GorillaBob
Re-Kitting Expert :o
Bullhead City, Arizona
Joined Jan 2005
Heli Pad,
Yes we sell these locally and at all the events we attend. www.gorillabobsrc.com
I just got some NanoTech 300's in but they are 2 cell packs. They would be a good size for the X1 if they were single cells!
GorillaBob is offline Find More Posts by GorillaBob
Discussion Syma 2012 new publish, syma X1, S800G, S107C,S036G,what's better wjh041 Coaxial Helicopters 9 Jun 20, 2013 03:07 AM
New Product Syma X1 Quadcopter Spare Parts wjh041 Beginner Training Area (Aircraft-Electric) 1 Nov 03, 2012 05:55 PM
