Old Dec 28, 2012, 05:17 PM
ror is offline
ror
Find More Posts by ror
ror
France, Languedoc-Roussillon, Thuir
Joined Aug 2009
micro EDF: need your advices
I'm beginning in micro RC. I'm building actually a RC Peanut Druine Turbulent and my second project is a 18" FW190 D.
But I have another dream :a micro jet, certainly a 50's-60's jet. So, I need a lot of advices.
First: which model ? I found that =
http://www.samsmodels.com/acatalog/c...et-X_kits.html
I love the Venom, I'd like to find a vampire or a meteor. But maybe a delta wing would be more judicious in order to reduce load wing ?
secondly, which EDF ? I'm just at the beginning of the threads about fan, but I have to say that I am a little bit lost ! . So, what would be the good choice ?I want a light but powerfull setup; enough if possible to do others things that circles in the sky. Am I too ambitious ? Are there some fans that work in 1S or the minimum setup is 2S ?
thirdly: I'd like to use a micro retract gear as the one fprovided by Yellow Baron since he made a tri legs retract gear. So, what would be the better scale in order to board all the setup ?
Certainly a lot of questions again, but it's just the beginning
By
ror is offline Find More Posts by ror
Old Dec 28, 2012, 10:12 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
My best adive would get a GP F-86 or the eflight mig15 you can learn how to fly them and gut them when you feel ready to build your own.
If your looking for plans some of use just down size the plans that are on parkjets.com but there are a few that are for 30mm edf like au117 F-35.
The retracts are being worked on my NitroCharged on shapways but they arnt ready yet.
chester2240 is offline Find More Posts by chester2240
Old Dec 29, 2012, 09:04 AM
stegla is offline
Find More Posts by stegla
stegla's Avatar
Guernsey
Joined Jan 2002
Hello Ror,
Good luck with your micro EDF.... I too like the look of the Venom. Most Jetex or Rapier designs are just a little too small and will need enlarging, say 125%?
Something like this maybe?
http://www.rcgroups.com/forums/showthread.php?t=1186170
Pay particular attention to the ducting. Properly designed ducting is at the heart of any successful edf model.
Steve
stegla is offline Find More Posts by stegla
Old Dec 29, 2012, 11:54 AM
ror is offline
ror
ror
Joined Aug 2009
Originally Posted by stegla View Post
Hello Ror,
Steve
Thank. But I thing that scale is possible if build very light. Maybe with no retract gear but no more that 18" for a classic wing (venom,vampire...) or 13" for a delta wing.
yes, I'm reading the thread about the 20 mm fan and it's sure that there are a lot of precision to get a good thrust. But I'm here to harvest the maximum of informations.
Old Dec 30, 2012, 04:30 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Hello Ror,
Read this thread
http://www.rcgroups.com/forums/showt...highlight=fj+1
This model is 16.5" wingspan and weighs 87g and the performance is great.
Steve
Old Dec 30, 2012, 05:07 AM
ror is offline
ror
ror
Joined Aug 2009
Really nice, but at 80 Gr, for me it's a flying bus !! I thought more about 40-50 Gr ...Is it possible ? Am I obliged to go to 2S to get good performances ?
Old Dec 30, 2012, 08:06 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
I would suggest that you start with one of the 30mm or 35mm Sabers or Migs. The learning curve on edf is hard enough without adding ultra micro size, scratch building and forget retracts on a 20mm.
Get something that you are going to have success and fun with first. Then start raising the level of difficulty, otherwise you are setting yourself up for a lot of frustration and not much fun.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Dec 31, 2012, 06:21 AM
ror is offline
ror
ror
Joined Aug 2009
OK, and what is the weight of a classic setup for a 30 mm fan ?
Old Dec 31, 2012, 06:28 AM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
using the GP sabre fan+motor
8g fan+motor
5g Thunderbird 6 esc (or 6g for Turnigy 6A esc)
13g 200mah 2s (or better 16g 300mah 2s Nanotech)
2g Orange rx
6g (3x2g orange Hobby King servo)
34g Total
http://www3.towerhobbies.com/cgi-bin...?&I=LXBWMA&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXBPXF&P=Z
Someone measured the thrust (not me) in the Sabre airframe to be around 55g (I think thats at around 3.7A)
If you need more power, the Skyangel 35mm unit can produce 75g thrust in a well ducted airframe, although it weighs 12.5g fan+motor
(at 4.7A)
http://www.hobbyb.com/skyangel-repla...?cPath=128_141
green_flyer is offline Find More Posts by green_flyer
Old Dec 31, 2012, 08:49 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Dunno.. I have an Aerographics Me 163 16" span, a converted to slope (elevons) Rapier model currently at ~55 gms IMO it would take serious and likely costly effort to get similar weights with a power unit and attendant battery needs .
Bare is offline Find More Posts by Bare
Old Dec 31, 2012, 09:55 AM
ror is offline
ror
ror
Joined Aug 2009
OK, so i have to envisage a weight of 70-80 Gr in 2S....Waouuu, heavy. But what would give a 20mm fan ?
Old Dec 31, 2012, 03:18 PM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
here is what the stock SkyAngels 35mm fan does...on 3s with a 10amp ESC it puts out close to 6oz of thrust:
M2U01779 (0 min 0 sec)
here is what I used to "make it go":
stock SA fan and motor:http://www.hobbyb.com/skyangel-repla...0mr0ru3e97ejv2http://www.hobbyb.com/skyangel-rc-pl...html?cPath=143
5g servos X 2:http://www.hobbyking.com/hobbyking/s...arehouse_.html
turnigy 10amp ESC:http://www.hobbypartz.com/07e22-proton-10a.html
stock RX for CT6B:http://www.hobbypartz.com/79p-r6b-receiver.html
350-460mah 25-40c:http://www.hobbyking.com/hobbyking/s...Warehouse.html
heres the build thread:http://www.rcgroups.com/forums/showthread.php?t=1765490
also if you want to build a first jet you might give this one a go, the plans are for the "conventional" version, this one also easily flies on a 2s 350mah pack and is so lite with that pack it will take quite a smack with no damage, set your rates for elev to about 40% and the roll to about 55% and it flies like a trainer, after you get the feel of how it flies you can go with a 3s pack and it will go like ticked off hummingbird, build thread: (you'll need to go through this thread to find the 35mm version...which is what the plans are done on ) http://www.rcgroups.com/forums/showthread.php?t=1725467
and a vid with the 350 2s pack:
Xversion3 1YEAH (3 min 1 sec)
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Dec 31, 2012, 03:36 PM
ror is offline
ror
ror
Joined Aug 2009
In fact, I thought more about a 20 or 25 mm OD fan like the BIM products (I'didn't remenber their name !). are there any others products like that ? is it adapted for a peanut or a wallnut jet ? (I have to forget the retract gerar, I think...)
Old Jan 01, 2013, 02:51 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Hi ror.
I like the kp 24mm fan
http://www.kpaero.com/ProductReport....gory1=electric
However it is suited to 80g models.
Steve
Old Jan 05, 2013, 12:12 PM
ror is offline
ror
ror
Joined Aug 2009
I found these plans. I love vampire and swallow (who has a shorter -so lighter - fuselage). Is a 2 or 25 mm fan would be enough ?
Discussion First time flyer/builder needs your advice phrosted Multirotor Talk 9 Dec 18, 2012 12:10 AM
Help! Advice needed on Micro Warbirds william.m Scratchbuilt Indoor and Micro Models 20 Jul 02, 2012 03:46 PM
Discussion resurection: F-22 twin 55mm EDF- need advice NickFox Foamy EDFs 0 Jul 02, 2012 03:21 PM
Help! Need some advice on upgrading my EDF Gliding-Peter Electric Ducted Fan Jet Talk 5 Jun 27, 2012 07:24 AM
Discussion Need advice on micro controller lunkerhuntin Power Systems 1 Apr 17, 2012 02:09 PM
