Old Jan 27, 2013, 03:02 AM
Flying_Flair is offline
Find More Posts by Flying_Flair
United Kingdom, England, Hemel Hempstead
Joined Feb 2010
Derek,
I took the liberty of editing your diagram (butchering!) to better illustrate the assembly sequence. I hope this helps
Malcolm
Description: Assembly sequence for SFH
Flying_Flair is offline Find More Posts by Flying_Flair
Old Jan 27, 2013, 07:50 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Malcolm, sorry I have delayed to do that for you, but I neglected to mention it might be a little bit before I could get to it as I was actually working on some freelance this weekend.
BUT, I just sat down and knocked it out really fast. Let me know if you need more editing.
It should probably also be noted the image is not to scale, if you do put this in the PDF.
Derek_S is offline Find More Posts by Derek_S
Old Jan 27, 2013, 08:42 AM
Tom Wright is offline
Find More Posts by Tom Wright
Tom Wright's Avatar
Joined Feb 2012
Hi Derek
If that's a quick "knock up I would like to see proper job" Brilliant and very helpful .
Tom.
Tom Wright is offline Find More Posts by Tom Wright
Old Jan 27, 2013, 10:43 AM
Joined Feb 2010
Wow, thanks Derek. I wasn't trying to pressurise you - brilliant job.
The only difference I can see is that you have a spacer in the spruce arm.
I don't recall one on the SFH.
Tom, is a spacer used?
If its not required i can take it
Malcolm
Old Jan 27, 2013, 11:02 AM
Tom Wright's Avatar
Joined Feb 2012
Derek and Malcolm.
A spacer is not required ,and not used on my original model .It would only increase the bending moment on the arm .Great drawing though.The 3mm bottom lock nut is all that's needed.
Tom.
Old Jan 27, 2013, 11:27 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Fixed
Old Jan 27, 2013, 12:25 PM
PaulB is offline
Find More Posts by PaulB
Mike's Ma Maaaaaaaaan
Paderborn DE
Hard part done :-))
Tom,
of course you can use the illustration, just sorry that I donít have time to do a more professional one.
Got the blades done today, went well except that one of the lengths of trailing edge stock had a different weight distribution which meant that although all 3 blades were within 0,15 of a Gram that the C of G of one blade was a whole centimetre out. I used my old method of drilling holes in the blades at the appropriate ends at the maximum chord position and then filled them with hot glue (epoxy works well too, and you can mix some lead shavings in) to balance and they are now smack on.
I will add a picture to show what I mean.
Tom, did I read somewhere that you use 1800 mAh packs?? I have 3 of them (140 Grams each) and if they will fit and balance I would use them, what do you think?
Cheers,
Paul Bray
PaulB is offline Find More Posts by PaulB
Old Jan 27, 2013, 02:28 PM
Tom Wright's Avatar
Joined Feb 2012
Hi Paul.
Thanks for posting the photos . those blades should be fine with any size lipo up to 2.2A ,as long as the lipo's are mounted under the floor as suggested in the pdf.
Tom.
Old Jan 28, 2013, 02:19 PM
Tom Wright's Avatar
Joined Feb 2012
All
Here is the revised pdf for the Crane Fly SFH , I hope this helpful to existing builders and to those wanting to have a go .
Many thanks to Malcolm , Paul, Derek and Allan for their contributions .
Tom.
Old Feb 03, 2013, 12:05 AM
Three-Wire is online now
Find More Posts by Three-Wire
AMA 562227
Three-Wire's Avatar
United States, CA, Bear Valley Springs
Joined Jan 2003
Anyone on the fence about autogyros should just jump in and build one... I did and it's been great fun! My Crane Fly is an early version but flies superbly.
One word of caution, be sure your ESC's BEC is up for the job of handling the servos! Brownouts are unpleasant, even in autogyros.
CraneFly Flight #2 (2 min 0 sec)
Three-Wire is online now Find More Posts by Three-Wire
Old Feb 03, 2013, 07:05 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
My bearings just came in so I should be able to finish mine sometime this week.
Old Feb 03, 2013, 11:18 AM
Tom Wright's Avatar
Joined Feb 2012
Three Wire.
Congratulations on your success with a MK 1 Crane Fly , and for taking the time to post the video . I must say the MK 2 and SFH versions are easier , so you have done well . .
Tom.
Old Feb 04, 2013, 02:23 PM
PaulB is offline
Paderborn DE
I was knocked out with a Bug last week. Had a 39,5 temperature which made me a bit woosy in the head, might explain why when I got my order of bits from Giant Shark today that I found out that I had ordered 2 Blue Wonder engine mounts but only 1 wheel!!!! Can I re-design the model to be a twin rotor uni-cycle?????
Dohhhhhhhhhhhhh.
Oh well, off to the LHS to find 2 big light wheels :-))
Old Feb 04, 2013, 03:28 PM
Tom Wright's Avatar
Joined Feb 2012
Don't worry Paul I get things wrong even when I feel well .
Tom.
Old Feb 06, 2013, 02:31 AM
andre seb is offline
Find More Posts by andre seb
FRANCE
Joined Feb 2004
blades
Hi
I want to clarify about blades :
C30 cervia blades are given for 690mm rotor
In the PDF home made blades are 400mm long giving some 850mm rotor
So What is wrong ?
Are Cervia blades lengh OK ?
Andre
andre seb is offline Find More Posts by andre seb
For Sale 1/48 20 ton knuckle crane SilentHunter Boats (FS/W) 0 Apr 11, 2012 06:04 PM
Discussion AP -BIG CRANES Working on Bigger Cranes..!.. guyg Aerial Photography 3 Mar 04, 2010 11:26 PM
Discussion Crane & cranes - A\V This Morning guyg Aerial Photography 2 Jan 02, 2008 10:33 AM
Discussion DeBolt Memorial Autogyro Fly In boberos Auto Gyros 7 Mar 02, 2006 09:30 PM
autogyros , anyone fly one? bronco Electric Plane Talk 2 Feb 14, 2002 04:06 PM
