Old Jan 05, 2013, 04:52 AM
stegla is offline
Find More Posts by stegla
stegla's Avatar
Guernsey
Joined Jan 2002
The balsa parts have been covered in paper. The paper used is known as 'bank' or 'flimsy' paper. Most bank paper weighs 45g/M^2 the paper I used is only 30g/M^2 and has great wet strength.
This is how I applied the bank paper........
1) 2 coats of dope to the balsa sanding in between.
2)Drag the paper across a bowl of water to wet but not saturate.
3)Smooth the paper over the balsa.
4)Soak the paper with thinners to attach it to the doped balsa underneath.
The fuselage needed 4 peices to cover.
Steve
stegla is offline Find More Posts by stegla
Old Jan 05, 2013, 01:25 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
adding some shape to the duct prior to sheeting
Old Jan 06, 2013, 01:45 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Duct is sheeted.
Old Jan 07, 2013, 01:46 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Looking great Stegla!
pdawg is online now Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old Jan 09, 2013, 01:15 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
The tailerons are being fitted...........using a slow-drying glue and plenty of jigging to everthing perfectly alligned.
The tailerons are all-moving. The hinge point is placed at 25% MAC. The hinge is 4mm carbon in a brass tube.
Steve
Old Jan 10, 2013, 02:29 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Just to recap................here are the specs.
span................ 26"
weight.................. 14 - 15oz
Wing area.............150 sq.in
wing section ...................MH42
incidence at root...... +1.5 degrees
incidence at tip...... 0 degrees
Tail sections .............NACA 0007
Fan........................... KP44 with a custom outrunner
Power....................200 -250W
Battery...................5s or 6s 800mAh or thereabouts.
Intake 100% fsa
Exhaust 90% fsa
Steve
Old Jan 11, 2013, 12:47 PM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
Yeah! You're right Stegla it becomes a nice jet!
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Jan 19, 2013, 08:22 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Now ready for the maiden.........AUW less paint is 390g. 14oz.
Waiting for some good weather.
Steve
Old Jan 19, 2013, 04:47 PM
MUTCAKE is offline
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
WOW! I have been trying to figure out what this thing was going to look like when you were finished. Man that's a really good looking aircraft. These things are so freaking hard to build and then fly, let alone make them look as cool as this. Hope it flies well for you.
MUTT.
MUTCAKE is offline Find More Posts by MUTCAKE
Old Jan 19, 2013, 10:05 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Good luck Steve!
NitroCharged is offline Find More Posts by NitroCharged
Old Jan 22, 2013, 12:03 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Thanks Guys,
I snuck out for a short flight lunchtime today. The wind was 0, however, it was cold overcast and it had been raining all morning.
A handlaunch on about 3/4 throttle saw it climb away strongly, indeed, I took off all the up trim I'd just put in previously. I was flying at a school soccer field so I just cruised around for the first flight.
1st impressions then.............
There were no nasty surprises, the CG looked ok, the model will cruise around on a very low throttle setting. The model just glides on and on and on making it hard to land.
Lookin forward to flying at our regular site so I can really wring it out.
Get some video asap.
Steve
Old Jan 22, 2013, 12:24 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
For something new I tried a spreadsheet cg calculator.
http://www.rcgroups.com/forums/showthread.php?t=1106300
The calculator gave me the Neutral Point at 29%MAC So I placed the CG at 23% MAC. 6% Static Margin (I think?) (OMG: starting to sound like an aerodynamics expert)
The above calculations and assumptions seemed to work in practice.
Steve
Old Feb 10, 2013, 07:37 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
The chosen colour scheme is inspired by the israeli airforce camouflage designs.
Steve
Old Feb 17, 2013, 01:57 PM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Tried to get some video yesterday but failed. Had a duration problem because one cell had gone down.
Nevertheless managed to get it almost trimmed-out. Needed an up-elevator mix with the throttle to cure a stong pitch down when opening the throttle.
Steve
Old Feb 23, 2013, 04:21 AM
stegla is offline
stegla's Avatar
Guernsey
Joined Jan 2002
Here's a still taken last weekend.
The cockpit looks very empty.
Steve
Discussion Never let a young teenager borrow your camera sandy1001 Dock Talk 4 May 08, 2012 09:11 PM
Discussion Warning with those with teenagers. Scott C Chit Chat 1 Mar 24, 2012 01:10 AM
