Old Jan 12, 2013, 07:27 PM
Luis Moya's Avatar
Mexico
Joined May 2004
Originally Posted by CloudyIFR View Post
I only have version 6.5 so i can't teat it. It only costs time to download it and try it. If you do please report back.
Curtis
Fair enough. I'll try it and report back.
Luis
Luis Moya is offline Find More Posts by Luis Moya
Old Jan 13, 2013, 11:41 AM
Joined May 2012
Originally Posted by Luis Moya View Post
Would the gliders in this thread work with version 4.5?
All the best,
Luis [in Mexico]
Lius,
RF planes are backward capable, usually with adjustments.
Planes made under an earlier version of RF often require minor changes to the physics when running under a newer version, due to on going realism changes and improvements to the simulator. RF is not necessarily forward compatible though, so it is "see if it works" on a case by case basis.
While I started with ver 6.0 last spring, I understand from others on the KE forum there have been many improvements over the years, so upgrading to 6.5 would be the best choice. Upgrades are less money than buying a new copy of RF with it's USB Tx. However, if you've worn out the sticks on your present RF Tx, then that may be a reason for you to consider buying 6.5.
Please keep us informed as to how the gliders work for you with 4.5.
Fly_electric2 is offline Find More Posts by Fly_electric2
Old Jan 14, 2013, 09:45 AM
Vrated's Avatar
United States, UT, Marysvale
Joined Aug 2004
I have been flying many of the custom model gliders from the Knifeedge swap pages (between g3 through g6.5). I have put tow hooks on all of them it seems they are originally set up for hand launch in the swap pages. I really like the big "Maxim High liner" The bungee is a little on the weak side for this big glider. Is there a way to hop up the bungee so I can get a better launch for the Maxim High liner Glider?
Vrated is offline Find More Posts by Vrated
Old Jan 14, 2013, 05:28 PM
TailwindGliders
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Go to the "Environment" menu and select Edit Thermal Park or whatever airport is there. You'll get four windows that open up. In the photo below you want to select in the "Folding Listing" window "Control Objects" and "Bungee Anchor". Then in the "Properties" window you'll see at the bottom "Rubber Portion Percentage" and "Maximum Distance". Change those and you'll get a higher launch.
I'm glad you're having fun!
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Old Jan 15, 2013, 01:48 AM
DZM
DZM's Avatar
Joined Sep 2012
Have problem no "Bungee Anchor"
DZM is offline Find More Posts by DZM
Old Jan 15, 2013, 07:08 AM
TailwindGliders
Joined Apr 2002
Huh? You could either try downloading the file again as something didn't go right. Oh, are you using ver 6.5? If that matter, not sure.
Or you can add a Bungee yourself.
Select "Control Objects" in the "Folder Listing" window.
Then in the "Object Pallet" window select "RealFlight 6.5" then click the + sign by "Control Objects" and finally "Bungee Anchor". Click Add and then you'll see the Bungee Anchor in the Folder Listing.
Curtis
Old Jan 15, 2013, 01:04 PM
DZM
DZM's Avatar
Joined Sep 2012
Bad for me i got only G4.5
Old Jan 15, 2013, 03:10 PM
Maryland
Joined Dec 2002
Not so bad you can get the upgrade version of RF6 for a lot less than the full version.
http://www.atlantahobby.com/Store/pc...dproduct=13555
rc4fun is offline Find More Posts by rc4fun
Old Jan 15, 2013, 05:01 PM
Vrated's Avatar
Joined Aug 2004
Curtis
Thanks, That works good for the High liner Maxim.
Old Jan 15, 2013, 05:24 PM
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Has anyone made a virtual Bubble Dancer or similar?
Trisquire is offline Find More Posts by Trisquire
Old Jan 15, 2013, 07:35 PM
Joined Sep 2012
Any idea why my session keeps resetting right after launch? I will launch.. and right at the height of the launch I will level off and then it resets. Doesnt seem to be dependent on height though.. seems like something is not set right ... but I have no idea what.
Super frustrating though.
Edit... just discovered if I touch NOTHING.. it wont reset.. but I wanted to pull up like a dlg launch... ugh.
Edit #2 ... seems to be related to reaching a preset Stall speed. Which I am not sure I can change.. because the stall speed set (if thats the case) is way too fast.
DeadServo is offline Find More Posts by DeadServo
Old Jan 15, 2013, 08:34 PM
TailwindGliders
Joined Apr 2002
DeadServo,
I would try rebooting if you have not done so as I have had some weird issues too and that has solved them.
Curtis
Old Jan 16, 2013, 11:41 AM
Joined Sep 2012
DeadServo,
Curtis
This is a problem I have had for a long time it is unfortunately not specific to your files.
It seems to be related to a faulty controller as everything works great until I validate my controller.
Anyhow I have written to real flight and I am sure they will fix the issue.
Old Jan 18, 2013, 10:55 AM
Bakersfield, CA USA
Joined Jan 2001
OK, you convinced me. I broke down and bought RF 6.5. I've made two flights so far with the RF-97. Its a good flyer, launched by aerotow. Now, if I could just figure out how to release the towplane! Anyway, I haven't crashed it yet. (Not sure what happens to the towplane, tho!) Tonight, I'll download your stuff and give it a try.
Hey George, how are ya!?
Yep, I am having fun with it in the cold Montana winter.
I happen to be passionate about most things I do and enjoy sharing them too.
Curtis
georgeg is offline Find More Posts by georgeg
Old Jan 18, 2013, 07:19 PM
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
Hi all. Curtis removing the arrows produced good flights.Much better.
Does red merl really fly that good?If so I think I found next winters project.
doc993 is offline Find More Posts by doc993
Sold Real Flight 4.5 SIM w/ Real Flight 6 upgrade cjdscratch Aircraft - General - Miscellaneous (FS/W) 1 Jul 18, 2012 07:54 AM
Discussion From Real Flight to a Real Flight - GP Silhouette on Floats Jake at the Lake Waterplanes 3 May 16, 2012 12:14 PM
For Sale or trade Real Flight Simulator Controller W/JR Patch Cord Real Flight Simulator Contr donho1 Aircraft - Electric - Airplanes (FS/W) 1 Apr 29, 2012 01:18 PM
Discussion Thermal Soaring Training DVDs: Great Deal! Paul Naton Thermal 1 Apr 12, 2012 09:27 AM
Sold Real Flight G3.5 plus real flight G5 upgrade plus add ons sagomon Aircraft - General - Miscellaneous (FS/W) 1 Mar 13, 2012 08:00 PM
