Old Dec 28, 2012, 09:12 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
RealFlight Thermal Training
DONE!
I purchased Real Flight version 6.5 to better my helicopter flying skills but have been impressed with the thermal flying. Since I like to teach/share my experiences I am working on a more realistic thermal experience in Real Flight.
As with any flight simulation there are some limitations but I've been working with making it more realistic.
Here are the files I've made/edited to make RealFlight as close to thermal hunting as possible.
"Thermal Park Red Merle" is for larger Gliders such as my Red Merle. There is a landing tape and thermals will work their way around the field.
"Thermal Park Third Vector" is for DLG practice. I suggest using the wonderful work by Fly_Electric who modeled Dr. Drela's SuperGee II.
http://www.knifeedge.com/forums/down...=file&id=17885
I recommend watching the video: "Joe Wurts on Soaring" that shows us how to apply his "Third Vector" drawing. I've tried to replicate this in the RealFlight sim. There are links to both of these on the "Tips" page of my website www.TailwindGliders.com
"Red Merle" is my eSupra I've scratch built and haven been flying for a few years.
There is also an electric version called "Red Merle ALES".
Here's a link to all of my offerings for RealFlight:
http://www.knifeedge.com/forums/down...es&userid=8765
So grab the files, get your stopwatch working and go practice!
Lastly, there is a stopwatch that will countdown in RealFlight:
There IS a countdown timer in RealFlight!
I'm just about to hand launch my Red Merle ALES plane on a five minute task.
Thanks to someone at HeliFreak they showed me how to get a countdown timer.
Here's how you do it:
1) Press the key to the left of the Number 1 ("~" Do not hold shift down), this will open the console.
2) Type "setTimerMode down". This tells the timer you want it to count down instead of up.
3) Type "setTimerCountDownFrom 5:00". This tells the timer to count down from 5 minutes and 0 seconds when in countdown mode. You can change these values to whatever you like.
Have fun!
Curtis
Curtis Suter is online now Find More Posts by Curtis Suter
Red Merle ALES
Joined Apr 2002
Attached is a file of Thermal Park Third Vector.
This is a zipped file with one file inside with a file extension of .RFX. Remember the location of the unzipped file.
In Real Flight select the Simulation menu, Import and RealFlight Archive (RFX, G3X) see example below.
Navigate to where you saved the file and it should import with a confirmation message in the lower left of RealFlight.
Make sure you have the SuperGeeII model loaded (see Post #12). Once in the sim you should be standing there looking at three poles with mylar streamers and some trees in the distance. There is a light wind blowing directly from the trees. Thermals should start working their way through your field. Watch the streamers and you should be able to find the lift!
It'll take a bit to figure out the depth of field distance in the simulation but once you do you should see the SuperGeeII pitch, roll or yaw when flying through lift or sink.
SuperGee II Model Info:
The SuperGee has reflex and camber on the three position switch. Center is neutral, towards the front of the transmitter is camber and away is reflex. There are flaperons on the throttle stick with elevator compensation. CH7 has aileron to rudder mix that can be turned on/off. CH5 has dual rates for the ailerons and rudder.
Enjoy!
Oh, and don't hit my truck!
Comments and suggestions are more than welcome. If you tweak the settings please share!
Happy New Year
Curtis
Old Dec 28, 2012, 11:22 AM
georgeg is offline
Find More Posts by georgeg
United States, CA, Bakersfield
Joined Jan 2001
So, I take it you like the Real Flight sim?
georgeg is offline Find More Posts by georgeg
Old Dec 29, 2012, 07:53 PM
Red Merle ALES
Joined Apr 2002
Hey George, how are ya!?
Yep, I am having fun with it in the cold Montana winter.
I happen to be passionate about most things I do and enjoy sharing them too.
Curtis
Old Dec 30, 2012, 02:03 AM
DeadServo is offline
Find More Posts by DeadServo
Joined Sep 2012
This sounds awesome, Eagerly awaiting your updates!
DeadServo is offline Find More Posts by DeadServo
Old Dec 30, 2012, 10:52 AM
hog2soar is offline
Find More Posts by hog2soar
hog2soar's Avatar
Central California
Joined Jan 2010
Curtis,
I love flying Real Flight. Can't wait to up grade. This will be great.
The best part of Real Flight is the repair when you crash. It's called re-set.
Eddie
hog2soar is offline Find More Posts by hog2soar
Old Dec 30, 2012, 11:10 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
All you need to do come Spring is find a field where all the big arrows are floating in the sky
tkallev is offline Find More Posts by tkallev
Old Dec 30, 2012, 11:20 AM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
Awesome!
djklein21 is offline Find More Posts by djklein21
Old Dec 30, 2012, 11:22 AM
Red Merle ALES
Joined Apr 2002
Ha ha.
I had the arrows on for testing the thermal generators I'm placing in the sim. I certainly recommend you turn them off. I'm getting closer. Anyone wish to do some testing for me?
If so send me a PM and and we can swap emails addresses as that's my preferred communication method.
Curtis
Old Dec 30, 2012, 11:33 AM
IHAVAWDY is offline
Find More Posts by IHAVAWDY
registered weapon
IHAVAWDY's Avatar
United States, MT
Joined Mar 2008
Just stopped by to check your spelling... it seems pretty good so far, I'll check back later...I'm watchin you though...
IHAVAWDY is offline Find More Posts by IHAVAWDY
Old Dec 30, 2012, 11:40 AM
Joined Sep 2012
Id love to be in on the beta test!
Also, I wont have a whole lot of time since Ill be heading back to work in a few days. But when time permits I might be able to give you a hand with the 3D modeling and/or animation.... Its what I do
Old Dec 31, 2012, 07:20 AM
Red Merle ALES
Joined Apr 2002
For your pre-Thermal training I suggest this new model that was released yesterday to the swap pages:
Curtis
Old Dec 31, 2012, 09:43 AM
Vrated is offline
Find More Posts by Vrated
Vrated's Avatar
United States, UT, Marysvale
Joined Aug 2004
I will be receiving my new Real Flight G6.5 in a couple days. I have been practicing on RF simulators (all types of aircraft) Since G2 first came out. Looking forward to trying out your new set up when it becomes available.
Vrated is offline Find More Posts by Vrated
Old Jan 01, 2013, 08:05 AM
soarguy is offline
Find More Posts by soarguy
So many projects...
United States, IN, West Lafayette
Joined Oct 2009
Subscribed!
soarguy is offline Find More Posts by soarguy
Old Jan 01, 2013, 08:43 AM
Red Merle ALES
Joined Apr 2002
First of a few things are uploaded!
See Post #2.
Happy New Year!
Sold Real Flight 4.5 SIM w/ Real Flight 6 upgrade cjdscratch Aircraft - General - Miscellaneous (FS/W) 1 Jul 18, 2012 07:54 AM
Discussion From Real Flight to a Real Flight - GP Silhouette on Floats Jake at the Lake Waterplanes 3 May 16, 2012 12:14 PM
For Sale or trade Real Flight Simulator Controller W/JR Patch Cord Real Flight Simulator Contr donho1 Aircraft - Electric - Airplanes (FS/W) 1 Apr 29, 2012 01:18 PM
Discussion Thermal Soaring Training DVDs: Great Deal! Paul Naton Thermal 1 Apr 12, 2012 09:27 AM
Sold Real Flight G3.5 plus real flight G5 upgrade plus add ons sagomon Aircraft - General - Miscellaneous (FS/W) 1 Mar 13, 2012 08:00 PM
