Old Feb 27, 2013, 10:01 AM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Bob and Harry; glad to hear we are going to see your models, especially as they are two of the more interesting and off-beat entries. I know what you mean Bob, it has been flaming cold here too, and has had an effect on my progress as my workshop heater copes OK down to just above zero, but below that frozen fingers set in!
Sundancer is online now Find More Posts by Sundancer
Old Feb 27, 2013, 03:38 PM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Me. I'm fairly rocketing on with my build.....
Colonel Blink is online now Find More Posts by Colonel Blink
Old Feb 28, 2013, 12:54 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
You're doing OK Colonel - as well as I am at least, which maybe isn't saying too much this time! And I think the Kitten is going to be something a bit special.
Old Feb 28, 2013, 01:04 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
we have the third completed build, ECBoehm's exquisite Bob Woollett designed Wren is finished and waiting for the weather. Give yourself a treat and have a look at it at http://www.rcgroups.com/forums/showthread.php?t=1813131 - real vintage aeromodelling eye candy!
Old Feb 28, 2013, 04:07 AM
mixer421 is offline
Find More Posts by mixer421
Agricultural flyer
mixer421's Avatar
United Kingdom, England, Kent
Joined Aug 2007
I'm just plodding along. A lousy winter cold is slowing me up - can't concentrate and a sneeze at the wrong moment could cause disaster.
mixer421 is offline Find More Posts by mixer421
Old Feb 28, 2013, 09:57 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Pleased to report that RFJ has sorted out the initial problems with his Manx Monrach and it has now flown successfully (28/02/2013)
Old Mar 10, 2013, 02:45 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
News Flash
We have our fourth completed build, c_dwebbs lovely little "Skyline Kitten", a very pretty model.
Old Mar 11, 2013, 02:03 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
ECBoehm has flown his beautiful Wren; he reports some trim problems with excessive climb and is adding downthrust.
Old Mar 13, 2013, 03:32 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
John38 has started his build log for the double sized Smeed Debutante - see http://www.rcgroups.com/forums/showthread.php?t=1850447
Old Mar 13, 2013, 09:11 AM
flyinglog is offline
Find More Posts by flyinglog
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Hello !
I think i will enter with this one :
http://outerzone.co.uk/plan_details.asp?ID=1082
But i start later, have to finish a Skampy first to clear the bench.
It is near completition, so it shouldn`t take ages.
I really like the simple design.
Regards !
flyinglog is offline Find More Posts by flyinglog
Old Mar 13, 2013, 10:42 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Originally Posted by flyinglog View Post
Hello !
Regards !
Hi flyinglog
Good choice, it flies amazingly well for such a simple design and was very, very popular in the 1950's in the UK. The designer, John Barker, was a club mate and friend of mine for a number of years in the 1980's and I built a Lulu then (photo below). John also designed a very fine vintage lightweight rubber model called Hepcat and when I knew him he built a replica of an A/2 (F1A) glider he designed at the same time as the Lulu, but this time for radio control - see the other photo below.
Welcome to the build off, I will add you to the entry list and look forward to seeing your model.
Old Mar 14, 2013, 01:20 PM
1234567
flyinglog's Avatar
Deutschland, Berlin
Joined Aug 2011
Hello !
Thank you for the interesting storys about the LULU .
I will build it as towline single channel, because i have no timer, but some small RC stuff.
Do you know something about weak points or improvements that can be made ?
Did you build the full height spar with splitted ribs ?
Best regards,
Sebastian
P.S: nice LULU on the Pic
Old Mar 14, 2013, 01:58 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Hi Sebastian
I don't think the Lulu has any particular weaknesses, except perhaps that you will need to take care to not allow the covering to warp the flat plate tailplane. Mine was built with the full depth spar as per plan. Since your model will be a little heavier with radio, you might perhaps consider making the centre section spar with 1/8" x 1/16" spruce caps top and bottom, 1/8" balsa between, with the tip spars all balsa. The only other change perhaps worth considering would be to build the tailplane using half depth criss-cross diagonals - see the photo below - to resist warping.
If you mount your radio gear well forward you should be able to use this to replace the nose ballast a free-flight version would need, so that the total weight is kept as low as possible.
Good luck and enjoy your build.
Old Mar 17, 2013, 11:45 AM
cd_webb is offline
Find More Posts by cd_webb
United States, AR, Hope
Joined May 2009
Well, I've begun a slightly larger Old Timer (Flying Midget) and will probably continue to tinker with it a little bit along, but with half of the BritPlan time already past, I've decided to start a second entry. I'm craving a simple little "backyard flier" that still looks like an airplane and the Titch, by Ron Warring, fits the bill.
Construction looks interesting and should go relatively quickly. Another electric conversion for RET.
SD, I'll get a link posted to my build log for you as soon as there is one. I promise to stay on top of this one and post progress a little more frequently than the last one.
David
Finally started...
http://www.rcgroups.com/forums/showthread.php?t=1856745
cd_webb is offline Find More Posts by cd_webb
Old Mar 17, 2013, 12:03 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Great David, I've added it to the entry list and will post the link to the build thread once you start it. It is a nice little model, I remember fancying it myself when I saw it in one of Vic Smeed's compilation books. It's the sort of simple but appealing structure that makes you want to reach for the balsa knife! I presume it will be electric?
Yippee! 18th Annual Gyronuts June 1st and 2nd 2013 - NEW St. Louis Location! jodini Auto Gyros 48 Jun 04, 2013 10:33 AM
Contest Build off for FROG designs October 1st 2011 to April 30th 2012 Sundancer Vintage & Old-Timer Designs 237 Apr 23, 2013 03:29 PM
Discussion Proposed "Britplan Build Off" 2013 Sundancer Vintage & Old-Timer Designs 96 Dec 31, 2012 07:56 PM
Contest EF1/APRA Shelton, WA June 30th - July 1st flyboy23e High Performance 0 Jun 25, 2012 07:22 PM
Discussion A New Event January 2013 any interest? flyingdan1 Competition Aerobatics 3 Apr 20, 2012 07:14 PM
