Joined Apr 2012
Lockheed Martin Various
So guys, I've been a lurker in these parts for a little bit. I came here because I've always been in love with VTOLs since I was a kid. I think they're an ingenious solution which has never had it's chance to truly shine.
I had the idea that I wanted to bridge my quadcopter's abilities with an EDF jet for a long time now, but I've been taking my sweet time trying to sort the details out in my mind. Then low and behold, Lockheed comes out with news that it's basically doing a tactical version of my exact idea. http://www.youtube.com/watch?feature...&v=vUpMG-KN7Pg So what can a lowly guy like myself do? I do think the principle is easy enough, however transitioning from VTOL to forward flight is always a challenge, and is an EDF capable of producing the trust necessary to transition in this manner? Even the retractable doors are easy enough. I'd love to hear some opinions about what Lockheed is doing and if there is anyway to replicate a vehicle with similar abilities using hobby-grade parts and preferably without the need for a liquid fuel, keeping it all electric and hopefully most obviously, smaller than a tactical grade UAV haha. Warm Regards Sherif |
The concept is hardly new, just reworked and adapted to a stealthy frame: http://en.wikipedia.org/wiki/XV-5_Vertifan
Further more in 2011 a picture of NGs MUVR concept appeared. Seems the fan-in-wing idea is still alive ![]() http://www.aviationweek.com/blogs.as...b-9f16def13c63 |
Joined Apr 2012
Wow, I'm impressed with your knowledge of history guys. It does seem like the Various is basically the Vertifan with the pilot taken out and rebodied in stealth airframe.
Sorry I should have clarified but RCvertt got the gist of it. I was thinking about how to recreate this using hobby grade parts. I liked the idea in theory primarily bc you have the best of both worlds, you can VTOL, however you ultimately have a highspeed airframe that you transition to like the Harrier or VF35. I thought (rather simply) that this would be a fun idea at the hobby grade level bc it could be a lot simpler with an electric platform and the BOM would be quite a bit less. One could theoretically program a flight controller to be in bi-copter mode providing stability and then with the flip of one of the channel switches, coordinate and transition to forward flight using the same sensors (gyro, accel) to allow for a stable transition. However, there is a lot I don't know about RC airplane design still and the weights that we usually deal with in multi-rotors would likely not be acceptable at the same size and scale with airplanes (my 650mm frame can be upwards of 2.4kg AUW). I suppose longer flight times could be possible with a larger airframe and a turbine vs an EDF, but then I'd be getting in way over my head. |
I think that once you remove the constraint of having a pilot in the loop, then the tailsitter works out as the best approach. In the case of a military vehicle the next obstacle is managing the payload, but it's relatively easy to solve, especially when using internal bays.
Joined Sep 2010
Maybe, just maybe, itīs possible to do it without custom controller programming.
So basic task is to control crossbreed between classic airframe and bicopter multicopter and use offshelf hobby components for it. Cheap ones preffered ![]() What about to install TWO cheap kk multicopter boards in one airframe, one kk board loaded with bicopter sw and one with openaero firmware for aircraft stabilizing. Airframe could be just simple delta (or anything else) with two props in wings (bicopter part) and tractor prop and elevons (aeroplane part). Both kk boards controlled by different channels, mixes done in transmitter (i īm using open9x so i can have multiple flight modes and mix any input controls to any output channel(s)). Flight modes could look like this: 1) hover - active is only board with bicopter fw, throttle going only to bicopter kk board 2) transition - both bicopter and openaero boards active, some portion of throttle mixed to tractor prop 3) once some forward speed gained, switch to standard flight - kk board with bicopter fw disarmed, full control and throttle to aeroplane board. I have seen quad copters with additional tractor motor installed flying just fine, so maybe this can work. And it's just something like to place quadcopter in the middle of the flying wing (it has been done) but with different controllers for quad and wing parts. just an idea ... Pen |
Stability and transitions will be the easy part compared to getting a decent flight time due to how heavy it will be. Those little 1300kv blue wonders can spit out 400 grams each with the right prop. If you think you can build the plane at about 600 grams ready to fly then it might work. |
Joined Apr 2012
RCvertt and Pen, I've been thinking about this ad nauseum today, watching birds fly and so forth and I wonder if there isn't a better solution. I also spent time thinking about the VJ101, and I think I'm on to a better train of thought.
Could you design a plane, featuring rotating high anhedral wings and forward mounted EDFs. For take off, the wings would flip vertical and the EDFs could blow air over the ailerons which would aide in VTOL control and then it would transition to forward flight in the same way an Osprey or the VJ101 would. This would reduce parts which would not be used during forward flight as the vertical component is secondary to the primary of forward flight. In effect, a tilt-edf. Thoughts? |
Would work pretty well for ducted fans, but it would be more complex for turbojets, due to having to handle hot gases. It might work with turbofans, with the control surfaces only immersed in the cold flow. Essentially it would be like the Doak VZ-4 (http://de.wikipedia.org/wiki/Doak_VZ-4) or a twin duct version of the Bell X-22 (http://en.wikipedia.org/wiki/Bell_X-22). Notice that in the Doak the pitch control in hover is achieved deflecting the turbine exhaust in the tail, tilting the fans won't do anything.
Something like an EDF osprey is the way to go. I looked more at the Various and the lift fans in an RC version would have to be much larger than theirs are in order for it to get off the ground.
I'm not sure what you mean by this. There should be no need for a moving surface behind the fans depending on the design. |
Joined Apr 2012
I'll put together a few sketches of ideas for you guys as a reference point so we can all be on the same page regarding the design.
As far as rotating high anhedral wings I meant the following: The idea was a whole wing which would rotate, not just the motor (one of many different options), so I figure the wings would have to be mounted high on the fuselage. The anhedral component would give a negative (vs neutral or positive) angle to the wing (when looking at it from the front) which should add some maneuverability to the higher wing mounting point. The theory behind this idea, for me, is that with the edf unit mounted in the wing vs at the edges it would always blow air over the control surfaces hopefully giving more control at different flight speeds as well as using the control surfaces for thrust vectoring when vtol'ing. ...now as I think of it... You could even place the rudders by the motors instead of in a conventional location with this setup, no? |
| Thread Tools | |
| Bob Martin SR7 & Bob Martin Talon (Slope) | jimbailey | Slope | 37 | Feb 14, 2012 10:27 AM |
| For Sale (6) Various Tuned Pipes Various Prices | stevster | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | May 11, 2011 09:42 PM |
| Discussion various planes, various problems | Dash 9 | Electric Plane Talk | 3 | Jun 14, 2010 10:58 AM |
| Martin, Martin wherefor art thou Martin | Kevin P | Parkflyers | 3 | Jan 24, 2003 04:39 PM |
