Old Dec 27, 2012, 11:33 PM
knlever is offline
Find More Posts by knlever
Design is everything.
Sri Lanka
Joined Mar 2010
Gliding towards free flight
After my latest attempt at rubber powered free flight, an attempt that we can best describe as having 'mixed results'. Previous attempts ie the "Cardboard Cessna 180" flew but were not durable enough.
Reviewing past posts and the kind comments in this forum, I decided to go back to basics and build simple gliders with 12" -14" span ( about 40 cm) for a start, to work out the aerodynamics and crash resistance.
Initial tests have been encouraging, hope to post some pix of an all card glider here.
What I have learned so far:
  • A model that glides slowly has a better chance of being powered by the weak, short burst of power that the rubber motors I am using provides
  • A model that requires a powerful throw to fly is a less likely candidate.
  • For a 30 cm long model, a 20 cm solid card wing is just marginal, and is is surprising to me what a difference card is compared to foam or balsa
  • Since it is diffult to keep the weight down, better try building a larger model, as the relative density of the model goes down, and the larger area will support greater weight. Some rubber powered models weigh 100 g or more with a 28" : 70 cm plus wing.
  • The crash resistance and durabilty I require absolutely needs stronger materials - no long tall grass here.
Admittedly I should have taken the advice and built a non - scale model first!
Ah well
knlever is offline Find More Posts by knlever
Old Jan 24, 2013, 02:45 PM
John Moore is offline
Find More Posts by John Moore
John Moore's Avatar
Southern Spain
Joined Nov 2003
I do not understand this message.
I thought you were busy on a micro ducted fan?
John Moore is offline Find More Posts by John Moore
Old Jan 26, 2013, 11:24 AM
knlever is offline
Sri Lanka
Joined Mar 2010
I am once again involved on several projects at the same time. It seems like it is taking ages, but I have made some progress. I admit the previous post is not very helpful.
It is simply that I have realized that I should build a non - powered version of the model to test flight loads, impact strength, stability and durability.
So I will build:
  • An 1/32 scale jet glider ( Saab Tunnan) ( for the EDF project)
  • A 1/32 scale Cessna 180 glider ( for the Cessna 180 project )
I have now on my desk a card model that can survive an impact with a brick wall several times ( except for the propeller) .
Getting the airframe right (strong enough and light enough) is a common requirement for Micro EDF, rubber power, gliders and so on.
I have read of an example of a balsa model that got destroyed falling off a shelf. I am not really going to be working with that level of fragility. I don't like working with foam either, though I tried it in my early experiments.
Discussion Kazu Orni:Falcon Kazu-kaku Ornithopters 1971 Yesterday 09:44 PM
Discussion Guillows B-25 Mitchell MPP Scale Kit/Scratch Built 246 Apr 28, 2013 12:07 AM
Question Do Free Items Count Towards Trader Rating ? rockhound1218 Trader Talk 29 Sep 22, 2012 03:35 PM
Sold Free Flight flight control board _SYCLONE_ Aircraft - Electric - Multirotor (FS/W) 5 May 10, 2012 08:17 PM
Discussion mcx acting a bit strange towards end of flight xbted Mini Helis 2 Feb 17, 2009 05:45 PM
