Old Dec 27, 2012, 09:24 PM
TheKaduu is offline
Find More Posts by TheKaduu
Joined Dec 2012
Help!
Newbie - What to buy for 40" Catamaran (ABS plastic)
Hi Everyone,
I bought a 40" catamaran, so I can upgrade it and make it do what I want it to do.
Here is the changes I made to it:
1) Took both motors off and installed only one of them back in the middle. Built my own brushed speed controller using relay and transistors. Converted the part that can be adjusted to make the boat go straight into a rudder controlled by a servo....... I burnt 2 speed controller I made. Got tired of it and moved on to the next changes.
2) Bought one 2848 water cooled brushless motor from HK along with Turnigy 120A boat ESC and ESC programmer. Made my own rudders that move in tandem......... This time the cheap motor/shaft coupler made out of plastic melted. So I made my own from aluminium.
Now... Everything is functioning correctly. But I want a better way of controlling the turns; I don't think I like using rudders. So, I decided to go back to 2 motors, but this time both brushless. Since I am controlling everything from a microcontroller, I will have better control over the turning process.
I am using 5000 mAh 20C 3S Venom battery which had bad cell and it is in process of being replaced (sleeping deep in saltwater solution as we speak). I also have 2100 mAh 20C 3S for powering the microcontroller other good stuff I have attached to the microcontroller. When I have some time, I will take pictures and put them here.
I do not want the boat to fly! With the current setup, I was able to get to 10 knots and it's enough to go up to 15 knots for me. My question is that I want to change shaft, stuffing box, possibly propeller. The motor I have might be small but I like it and I want to keep it. What recommendation can you all give me on the shaft and propeller sizes to maximize the run time while being able speed up to 15 knots?
Thank you for your time everyone,
Kadem
TheKaduu is offline Find More Posts by TheKaduu
Old Dec 28, 2012, 07:37 PM
TheKaduu is offline
Joined Dec 2012
Nobody?
Old Dec 29, 2012, 04:23 AM
785boats is online now
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Which cat is it? Some pictures or a link would help.
785boats is online now Find More Posts by 785boats
Old Dec 29, 2012, 04:27 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
There is a link in the first post, it's the Admiral.
Probably two motors in the 3650 size range and 120A ESCs would do the job, but it will get a bit heavy. I would probably go for 2860 on 3S if you want to keep the batteries...
CornelP is offline Find More Posts by CornelP
Old Dec 29, 2012, 04:55 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Kadem
Hi Kadem,
I think this sentence baffles the members here, as this is the fast electrics forum...
When an 'Admiral' comes along, the question usually is: ""How do I make this cat fly?"
The best answer to that question is to buy a hull that's designed to go fast...
As you're interested in pottering around, any hobby grade propshaft and stuffing tube will do, experiment with propsize to get the speed you want, without overheating the motors.
You didn't say where you're located, so pointing you towards the nearest shop is a bit difficult.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Dec 29, 2012, 12:23 PM
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Thanks cornel. I didn't see the link in the first post.
Old Jan 08, 2013, 11:33 AM
TheKaduu is offline
Joined Dec 2012
pompebled: I did not see a slow boat section Thanks for the info.
CornelP: Thank you for the info.
I switch back to 2 motors. I bought 2 3660 brushless motors and now have 2 120A ESC. I also acquired set of the following size props (addition to 2" stock props): 1.75" (dumas), Surge Crusher props, 42mm, 38mm 35mm. What can I say, I have no patience
I might have forgotten to mention that I have a Chevy truck washerfluid pump hooked up to all motors and ESCs to keep things cool even while going slow. Since everything is controlled with microcontroller, I have temperature sensor on all motors and ESCs. And the pump can be operated manually or automatic which can turn on if any of the temperature sensor measures anything above a certain value. I am a Software Engineer, and a good one too. So, the everything but mechanical part of this project is already done.
I also have GPS, compass (which needs to be calibrated with the new setup), voltage divider to measure the cell voltages (assuming that battery is balanced - I know voltage sags under load, nonetheless, it helps).
I owe you all some pictures now... Hopefully tonight...
Now, I am considering using 2 3S batteries in parallel. I already soldered the Deans connectors and tested it. I read to confirm what I already know that batteries should (preferably) be same capacity which are already bound to come tomorrow. Do you have any tips for the parallel batteries from your experience?
Thank you for your time.
Kadem
Old Jan 14, 2013, 10:24 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
I got an Admiral several years ago and threw in a set of Graupner 700's, went decent but somehow fried the motors(8.4BB's) should have gone with 9.6's and smaller props.....................anyhow I threw in a single drive Feigao 580L on 6s and here's the result. Went about 30 mph but handled like crap............put in a single 700 for a rescue boat, left it on the shore by accident when leaving, came back 5 minutes later and it was gone
NQD Admiral 40" Cat on 6s with 580L motor, 2nd run (2 min 6 sec)
Here's one that seems to have worked out pretty well.............
RC Boat , Admiral CAT heavily modified (0 min 43 sec)
scorpion1 is offline Find More Posts by scorpion1
Old Jan 14, 2013, 10:34 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Here's the one i was trying to find though...................leave it to the Germans to get an ABS toy to hit 60+ mph!!
Hopf NQD PX 757 Admiral Cat (1 min 12 sec)
Old Jan 24, 2013, 11:18 AM
TheKaduu is offline
Joined Dec 2012
Your's is nice too... Thanks for the videos.
Old Jan 24, 2013, 11:32 AM
TheKaduu is offline
Joined Dec 2012
Different problems
As I mentioned before, I now have 2 identical* motors, 2 120A Turnigy Marine ESC and various prop sizes. I only have one set of counter-rotating props (stock). Since 2 motors pushing with 2" stock propellers, the boat was going too fast at the idle speed. So, I took the propellers off before I tested for yaw (idiot)... With the rest of the propellers, the boat was not going straight.
The weird part is that at the lowest speed the boat slightly turns to left. But at the next higher speed, boat does a hard clockwise circle... This was observed with props that rotates the same direction... Is it possible that one of the motors is not accelerating smoothly; it is slow-slow-very fast as opposed to slow-fast-very fast as it should be?
I also think this could be caused by the ESC. Have any one of you experienced this before? Can I do anything to fix this?
Thank you for your time,
Kadem
Old Jan 24, 2013, 11:45 AM
zozer is offline
Find More Posts by zozer
Steps? What steps?
zozer's Avatar
United States, TX, Humble
Joined Jan 2010
This is commonly observed, it is due to the motors turning different speeds at different throttle inputs. Either the motors have slightly different Kv values - very likely - or the ESCs are not giving identical signals to the motor at the same throttle inputs. This happens with top-of-the-line motors and ESCs - I can only imagine how it is with cheap stuff. Try switching the motors to different sides, maybe the differences will cancel themselves out. That, or just run WOT most of the time and trim the boat for that.
zozer is offline Find More Posts by zozer
Old Jan 24, 2013, 12:00 PM
TheKaduu is offline
Joined Dec 2012
I may have forgotten to mention that both motors are 3180kv. I know this is too high of kv...
Old Jan 24, 2013, 12:04 PM
TheKaduu is offline
Joined Dec 2012
Thank you for fast response zozer... What is WOT? I was planning to incorporate an accelerometer to balance the motors, but I'll put the counter-rotating propellers on and test again first.
Old Jan 24, 2013, 05:26 PM
TheKaduu is offline
Joined Dec 2012
First thing I tried was the trim, but I found out that lower speed pulls left and higher speed pulls right. This is why I will try the accelerometer to balance the motors. I think I'll debug the controller next. Who knows, I might be sending the wrong speed to one of the motors. I think a bug is highly unlikely because the code is pretty much copied from the one motor code and one motor code was working just fine...
Discussion Remove yellow tint from white ABS plastic plane58 Dock Talk 17 Dec 27, 2012 01:56 PM
Discussion Adhesives for ABS Plastic Bill Diedrich Scale Boats 21 Sep 06, 2012 02:27 PM
Discussion NEWBIE ALERT! --What plane to buy! jammerz Beginner Training Area (Aircraft-Electric) 32 Mar 10, 2012 04:42 PM
plastic ABS cowl Corsair.. .40 size plane dirkyboy098 Non R/C Items (FS/W) 2 Mar 05, 2011 05:35 PM
Question What resin is suitable for ABS plastic? badbunny_uk Scale Boats 5 Feb 07, 2007 03:57 PM
