Old Dec 27, 2012, 09:04 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
Contest
BBCC 2 Piper PA-18 Super Cub Scratch Build payne9999
I was looking at the 24" wingspan Carbon Cub and really thinking about it but then realized $189.00 was a lot for a molded foam micro. I really wanted to build two cubs outfitted like tundra planes, one micro (25") and one larger (60"). So, I scaled down my Tritle Super Cub plans and used some rib layouts from another cub design (since I didn't trace the original parts).
Anyway, here are the specifications:
Wingspan: 25.5"
Servos: 3.1 gram Headsup RC
Motor: Projected to be a 180-250 size brushless
ESC: 10 amp Headsup RC
UC: Floats and tundra tires (configurable)
Color: Cream and red
Controls: Elevator, Rudder, Ailerons, Flaps and throttle
Right now it is just a pile of balsa. Cutting out the parts the old school way with Xerox copies a hot iron and an x-acto knife. The ribs will be 1/32", stringers etc. 1/16" paulownia wood some 1/16" ply and misc balsa.
I was going to post this on the micro and indoor section but that area seems like mostly ARF's. I seem to have an allergy to foam....gives me a rash to think about flying packing material around the sky.
Dave
payne9999 is offline Find More Posts by payne9999
Last edited by payne9999; Mar 01, 2013 at 07:40 AM. Reason: Adding the Super Cub to a Balsa Conversion Contest
Old Dec 27, 2012, 09:30 PM
baldguy is online now
Find More Posts by baldguy
I eat glue
Canada, NS, Yarmouth
Joined Jul 2006
Good start.
That's my plan with his current 60" Super Cub and J-3, only going up to 1/5 scale (84"). I really like how his designs are done and I think they are more easily made more "scale" than any current kit.
baldguy is online now Find More Posts by baldguy
Old Dec 28, 2012, 11:16 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Here is the fuselage framed up. So far the framed fuse is .3 ounces.
Old Dec 28, 2012, 11:18 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Originally Posted by baldguy View Post
Good start.
Did Pat release a 60" Super Cub? I knew he juat released his 60" J-3. I think my Tritle Super Cub is 53.5".
Dave
Old Dec 28, 2012, 12:23 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Added the rest of the stringers and it weighs .38 ounces just shy of a Champ foamy micro fuse out of the box. So, given that it seems like it is on target. The motor and motor mount will be a little heavier but will have quite a bit more power.
Old Dec 28, 2012, 03:02 PM
I eat glue
Joined Jul 2006
Yep, he released a 60" Super Cub as well. I got both of his 60 inchers for Christmas. Going to modify my Super Cub into a Super Bear.
Old Dec 30, 2012, 10:46 AM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Looking to save weight everywhere I can. My budget says I am at about 100 grams AUW. I want to be below 90g. Saved a few by going to a different battery and a few more by punching holes in parts.
Old Dec 30, 2012, 11:11 AM
I eat glue
Joined Jul 2006
An old free flighter's trick is to slightly round the sticks a bit with sandpaper. Takes a little weight off.
Old Dec 30, 2012, 01:36 PM
Robert R is offline
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Dave,
You are a really high output/high quality builder.
Re weight why not laminate the stab outlines?
Subscribed.
Roberf
Robert R is offline Find More Posts by Robert R
Latest blog entry: Mustang Sally Sea Trials
Old Dec 30, 2012, 02:24 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Originally Posted by Robert R View Post
Dave,
Subscribed.
Roberf
I am too lazy
Old Dec 31, 2012, 06:22 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Working on the wing. The entire airframe minus covering, motor and battery is now at 53 grams. This weigh-in included the gear, tires and all the electronics and hardware. So far I am close to making the weight budget.
Dave
Old Jan 01, 2013, 02:32 AM
Robert R is offline
Robert R's Avatar
Joined May 2009
Originally Posted by payne9999 View Post
I am too lazy
Fair enough but, somehow I doubt that lazy is a tag that fits you very well given a 4 day build log.
Robert
Old Jan 01, 2013, 12:50 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
Robert
Robert,
My humor is to dry for most
Really I just hate making the forms and bending the wood. However, they are stronger and very light. My wing came out under budget at 9 grams so it will be OK but the bent and laminated tips would have been better overall.
Dave
Old Jan 01, 2013, 08:23 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
The wing is complete except for the flaps and ailerons.
The glue and knife are in the image for scale.
Old Jan 01, 2013, 10:23 PM
RedTaco is offline
Find More Posts by RedTaco
RedTaco's Avatar
United States, CA, Castro Valley
Joined Jan 2012
Looking really good Dave, You are making quite good use of your lightning holes! Do you find it hard to get the wing ribs sized well enough to get a good straight wing from hand cutting? that is one thing that has kept me from considering a scratch build. Not sure if I trust my patience enough to pull it off. Laser cut kits are such a crutch! Hard to get off of them.
That thing is really going to float along, cant wait to see the covering on it.
Ryan
RedTaco is offline Find More Posts by RedTaco
Build Log Dare Design 60" Piper Super Cub PA-18 AmpAce Scale Kit/Scratch Built 1081 Sep 24, 2012 07:06 PM
Discussion Dynam (Hobby King) Piper Super Cub PA-18 - which replacement motor? romandesign Foamies (Kits) 2 May 28, 2012 01:41 PM
Discussion Scratch build Piper cub PA-18 mrfrabcabert Foamies (Scratchbuilt) 50 Jan 04, 2012 01:44 PM
Sold NIB Dynaflite 1/4 scale Piper PA-18 Super Cub Kit Warby Aircraft - Fuel - Airplanes (FS/W) 1 Feb 08, 2006 09:53 PM
