Old Mar 31, 2013, 01:39 PM
Migueltata is offline
Find More Posts by Migueltata
Joined Mar 2013
Allan[/QUOTE]
Thanks Allan for the support,
I have other question about the buddy box , on the V2. Is possible to use a Spektrum Dx-7 or Dx-6i as a slave?
Which sd card recommend to upgrade? The SD card must be formatted on FAT modo? What do You think about the 2Gb Sandisk Card?
Thanks again, Miguel
Migueltata is offline Find More Posts by Migueltata
Old Apr 01, 2013, 12:53 AM
AWorrest is online now
Find More Posts by AWorrest
Lincoln, NE
Joined May 2005
I can't address using the DX7 or DX6i as a slave as I don't own either. Version 2 works properly with my 9303 as a slave in the ACRO program trainer mode. For a glider, the flap channel wasn't transferred. I don't know if that wasn't the case with version 1. I would think if those transmitters you mentioned worked with version 1, they would work with version 2.
I use a Kodak 2GB card. I've tried a SanDisk 1GB, class2, and it read and wrote with no problems. I've also tried a PNY 2GB with no problem. Initially JR recommended using nothing larger than 2GB, although some users reported getting away with a larger card. I'm not sure if it is the manufacturer or the speed class that causes some cards not to work. All the cards that I have didn't require formatting before use. I would recommend that before you upgrade to version 2, you try writing and reading some of your models to the card. You won't need a card any larger than 2GB as the model data is less than 15KB for version 2 and even less for version 1.
Allan
AWorrest is online now Find More Posts by AWorrest
Old Apr 01, 2013, 06:13 AM
Joined Mar 2013
Allan
Thanks a bunch!!
Old Apr 08, 2013, 01:05 PM
Rob2160 is online now
Find More Posts by Rob2160
Team Armattan
Rob2160's Avatar
Australia, NSW, Sydney
Joined Jun 2010
Where can I download the software?
The link in this manual does not work.
http://www.horizonhobby.com/pdf/JR_1..._Update_v2.pdf
Rob2160 is online now Find More Posts by Rob2160
Old Apr 08, 2013, 01:27 PM
Butthead is offline
Find More Posts by Butthead
United States, MA
Joined Oct 2006
If you go to the JR 11X page on the Horizon Hobby website, select the "Manuals & Support" tab, and then access the link though there, it should work.
Butthead is offline Find More Posts by Butthead
Old Apr 08, 2013, 01:32 PM
Team Armattan
Rob2160's Avatar
Joined Jun 2010
Thanks, it didn't work through firefox but worked ok with IE.
Old Apr 10, 2013, 12:00 PM
Team Armattan
Rob2160's Avatar
Joined Jun 2010
Installed the update on one of my JR11x's and kept the other on 1.03.
A few things I like about the new firmware.
1. You can calibrate the sticks.
2. Servo Balance
One thing I don't like..
1. The model name is now not bolded in larger font, like the original
Also one thing I have noticed is under the voltage display on the main screen there occasionally appears a second voltage indication.. like this
10.6V
0.4V
I never saw it on the original firmware.. any ideas what it means?
It disappears if you go into the setup menu and seems to appear randomly
Old Apr 10, 2013, 01:31 PM
Lincoln, NE
Joined May 2005
The lower voltage reading is what appears on the XG11 screen for the receiver voltage. It has no relevance for the 11X and as far as I know, it causes no harm. On my transmitter it pops up on very rare occasions. I would be curious to find a way to make it show up predicably.
Some of the functions on the version 2 upgrade are not 100% applicable to the 11X as it uses an analog throttle trim rather than the digital on the XG11. I believe the principal purpose of the stick calibration is to facilitate changing the throttle stick from one side to the other. Otherwise, I have found no need for it and I haven't had the guts to try it yet.
Another function in this category is the stick mode. It has one useful purpose though. For a V-tail RES sailplane, set the mode to number four and you can get both the rudder and elevator function on the right stick without a lot of extra programming.
Allan
Old Apr 10, 2013, 03:53 PM
Pitstop000 is offline
Find More Posts by Pitstop000
Paul Pappas, AMA 42520
Pitstop000's Avatar
United States, CT, Norwalk
Joined Aug 2008
Allan the stick calibration menu except for mode changes also comes in handy when one installs the travel adjusters for throttle and or elevator.
Allan
Pitstop000 is offline Find More Posts by Pitstop000
Old Apr 10, 2013, 08:26 PM
c131frdave is offline
Find More Posts by c131frdave
Too many numbers
United States, IL, Lake in the Hills
Joined Oct 2010
Just updated mine. Kinda freaked me out at first because I didnt' read the release notes nor watch the video before updating- so when all my models (only 5) all dissapeared, I was alarmed. But then I remembered all my models are pretty basic and it would take all of 2 minutes to rebind and set them up again. Other than losing my saves, I really like the update. I think the menu is better organized. Glad I did it.
c131frdave is offline Find More Posts by c131frdave
Old Apr 10, 2013, 08:28 PM
Team Armattan
Rob2160's Avatar
Joined Jun 2010
Allan
Yes the 2nd voltage display is strange on the 11x. it sometimes shows 0.4v and at other times 10.0V. Seems random and I can't trace a cause for why it shows differently sometimes..
As for calibration... Try this.. set up a new model, standard wing, 1 aileron, no v-tail etc. (so each channel just displays its own movement without mixing)
Now without moving the sticks.. adjust the aileron trim left and right and see how many clicks it takes to display movement...
Most radios will not display evenly.. IE, my 11X will require 4 trim clicks right before the indicator moves on the monitor for the aileron.. but it will move left with just one click...
IE.. the centre calibration position is not exactly perfect..
Its a bit of trial an error but I have managed to calibrate my 11X on V2 firmware so that every channel (elev, Ail, Rudd) is perfectly symmetrical. IE two clicks from centre in any direction will display movement on the monitor screen exactly.
Futaba and Spektrum are the same.. I spend a few minutes with any new radio to ensure the sticks are calibrated exactly perfectly this way..
Its a tiny difference when flying, but I notice it when flying 3D helis.
Check your radio, I bet at least two channels are not symmetrical.. I have never had a perfect calibration from the factory
Old Apr 11, 2013, 02:32 AM
Lincoln, NE
Joined May 2005
Your post gave me the incentive to examine the stick calibration function. The aileron, elevator and rudder weren't bad. The throttle was off a bit. After going through the procedure several times, my sticks' calibration is now better by two orders of magnitude than my flying ability warrants.
Allan
Old Apr 11, 2013, 07:43 AM
Team Armattan
Rob2160's Avatar
Joined Jun 2010
Allan
Great to hear it.. some TXs are much worse than others but if the system lets you calibrate the sticks I can always fix it.
Don't worry, I was too scared to try it on my 8FG for the first 12 months.. so I completely understood your previous post.. It gives me peace of mind knowing the sticks are calibrated perfectly..
Old Apr 11, 2013, 08:37 AM
CatBird is offline
Find More Posts by CatBird
CatBird's Avatar
Louisville, Colorado
Joined Oct 2007
I might have a look at my stick calibration. But I have so many models with touchy elevator and aileron trim that I'm not sure I'd want to mess with it. I guess I could always try it and reset it if it's not better.
Bill
CatBird is offline Find More Posts by CatBird
Old Apr 11, 2013, 10:09 AM
Team Armattan
Rob2160's Avatar
Joined Jun 2010
Bill
Not sure if you can reset it.. but you can recalibrate it as many times as you want.. Sometimes it takes me 3 or 4 attempts before I am completely happy with it. I'll post a vid tomorrow.. 1am here now..
Discussion JR 11X Zero Firmware Update 0002-0000 F3P Connor Radios 3 Nov 14, 2012 01:18 AM
Discussion DX18 or JR 11X2.4 (w/ DSMX) Alpha_Geist Radios 12 Jul 01, 2012 11:49 AM
Discussion JR 11x ZERO NEW firmware(Version:0002-0000) Nettraptor Radios 1 Apr 04, 2012 03:39 PM
Discussion JR 11X2.4GHZ transmitters piperjon Radios 3 Apr 01, 2012 09:55 PM
Mini-HowTo JR 11x2.4 LCD Screen Protector Lancair_Pilot Radios 2 May 07, 2011 09:46 AM
