Old Dec 27, 2012, 04:41 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Question
Will the BP Hobby ....H2217-4 3500 KV do this ?
Never did a high speed pusher with a prop this small.......Are these numbers, prop speed & thrust, close to being real ?
Thank you
Rich
cyclops2 is offline Find More Posts by cyclops2
Old Dec 27, 2012, 05:03 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
The numbers don't look terribly off, but I would put the big red rubber "ABSOLUTELY NOT" stamp on this one since the poor GWS prop is liable to explode at those RPMs.
The Graupner CAMSpeed 3x3 would be a much better choice...
But still no.
You'll definitely want to run less RPMs and a bigger prop on that plane. You've cranked the RPMs and pitchspeed up real high, but in doing so you sacrificed so much thrust that the plane would most likely fly like a glider with a screaming noisemaker attached to it. Where are you mounting the prop and motor on a U2, and what sort of flying are you planning to do with it? If possible, I'd recommend a Suppo (BP) 2217/8 1100Kv motor swinging a 9x7 folder on 3S.
If you absolutely must run a small, fast prop on four cells, the 2217/6 1500Kv with a 5.5x4.5 would be a better choice. 3" props are firmly outside reality for most non-tiny planes.
Piece is offline Find More Posts by Piece
Old Dec 27, 2012, 05:17 PM
cyclops2 is offline
Joined Mar 2003
The motor & prop have a very flat efficiency curve as power is reduced.
This setup is strictly to get the slow U2 glider up high enough to find a thermal & glide down. Then back up again.
The 340 continous watts to use a EDF are out.
Will buy a GWS HD 3" X 3" & test it out on the test stand for scream of 39,000 rpms . Ok with a U2
Old Dec 28, 2012, 09:02 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
That GWS HD 3x3 will probably explode long before you get it to 39,000...to avoid injuring someone, use a carbon prop for such high RPM.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Dec 28, 2012, 09:08 AM
cyclops2 is offline
Joined Mar 2003
Thank you Phil.
I am taking off my prop testing Flack Jacket.
Rich
I have wound up a APC E that high. I think it was a 5" for the GWS F-15 pusher.
Question Suppo / BpHobbies ..H2217-6 ..3500 KV motor. Currents it can take ? cyclops2 Electric Heli Talk 3 Mar 20, 2010 07:45 AM
Question BP H2217-4 3200 to 3500 KV rating. cyclops2 Power Systems 5 Dec 22, 2009 08:08 AM
Help! BP-H2217-4 motor. cyclops2 Mini Helis 0 Dec 17, 2008 08:13 AM
Help! BP-H2217-4 motor. cyclops2 Electric Heli Talk 0 Dec 17, 2008 08:11 AM
Discussion bidproduct.com BP 830, says kv 830 & BP 730, KV 1300 taekwondo Power Systems 0 Dec 06, 2007 04:47 PM
