Old Dec 29, 2012, 05:14 PM
kelloggair is offline
Find More Posts by kelloggair
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
Originally Posted by xlcrlee View Post
Look at the jet engine intake angles, and note that the outboard engines are set to take in air approaching from a steeper up-angle [outboard inlets more downturned > relates to my washout "tirade" ].
Your small model should need even more downturn [higher AoA].
L
just so you know a 747 does not cruise at the angle that picture shows, it cruises at a 3 degree angle.
kelloggair is offline Find More Posts by kelloggair
Old Dec 29, 2012, 05:22 PM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
I perhaps stupidly assumed that everyone knows that and would mentally rotate the photo .
All my input has been of the airflow at various wing sections .... relative to the body of the plane, not to the angle of the body. But in truth, relative to the ground, the wings of a small slow-flying model of that type in level flight will be at an angle greater 3°....
Lee
the nose Pitot tubes show the onflow there, which will be at best -5° for a small model with scale wing planform
xlcrlee is offline Find More Posts by xlcrlee
Old Dec 29, 2012, 07:09 PM
hi2nr is online now
Find More Posts by hi2nr
United States, TX, League City
Joined Jun 2008
I think due to the size I can actually make the "flaps" fixed to give more lift
hi2nr is online now Find More Posts by hi2nr
Old Dec 29, 2012, 07:44 PM
xlcrlee is offline
Joined Apr 2006
You could eaither also extend them rearward and curve them in scale multi-steps, but not necessarily in FULL-flap position.
One possibility would be to have slipped-on removable flaps, without changing the T.E. you've built.
Another would would be to have two diff., insertable flaps, one set in the retracted position, useful for wind, and the other in maybe 15% or 20% up to max 30% flap position [the latter only for small indoor spaces].
OR, a hand-movable, extendable flap-system. Might be impressive.
In ANY case, I'd first try it with taped-on simple flaps to get a rough idea of size and function ....
Lee
Old Dec 29, 2012, 07:57 PM
hi2nr is online now
Joined Jun 2008
I have vinyled on some mock up "extended" flaps and also used it to increase the trailing edges of elevator/aileron surfaces. Awaiting the morning to test out the increased surface areas!
Lee
Old Dec 29, 2012, 09:53 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
you should move this to the Airliner forum
Keenan smith is offline Find More Posts by Keenan smith
Old Dec 30, 2012, 04:42 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
i think your props are on backwards in the photos, thats not how you flew it right?
derk is offline Find More Posts by derk
Old Dec 30, 2012, 04:52 AM
xlcrlee is offline
Joined Apr 2006
Cool tip for everyone! An excellent way to get that extra bit of performance out of your aircraft > put the props on correctly [or turn the plane around]
L
[actually, years ago when testing a newly designed & built small plane with a COX .020 at the COX factory using their factory-fresh fuel with evidently far more nitro in than what reaches the consumer at the end of the marketing pipeline .... the ONLY way to get that sucker to fly in an unscary manner was to put the prop on backwards!]
Old Dec 30, 2012, 07:55 AM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Hi2nr Your micro 747 is amazing Sir.
demondriver is offline Find More Posts by demondriver
Latest blog entry: RC Red Dwarf Starbug!
Old Dec 30, 2012, 08:35 AM
xlcrlee is offline
Joined Apr 2006
a b s o l u t e l y !
Old Dec 30, 2012, 09:38 AM
hi2nr is online now
Joined Jun 2008
I actually flew it both ways, flys the same or nothing noticeable to me. Plane didn't need much power to glide around lol
Old Dec 30, 2012, 09:51 AM
xlcrlee is offline
Joined Apr 2006
w.r.t. backwards props, washout, turned-around plane or ....?
Old Dec 30, 2012, 12:27 PM
carrerars is offline
Find More Posts by carrerars
carrerars's Avatar
Joined Aug 2008
WOW!!!!!
Amazing.... could you move this one to the airliners section?
(there are a lot guys that have to see this baby)
Just great.
Thanks for sharing
Markus
carrerars is offline Find More Posts by carrerars
Old Dec 30, 2012, 04:54 PM
Africanhero13 is offline
Find More Posts by Africanhero13
United States, TX, Whitehouse
Joined Feb 2012
That looks amazing I tried once( not a small one ). Didn't work out. Good lick to you though. Look like it will work!!
Africanhero13 is offline Find More Posts by Africanhero13
Old Dec 30, 2012, 09:00 PM
AirplaneFreak100 is offline
Find More Posts by AirplaneFreak100
as the name says!
AirplaneFreak100's Avatar
Barbados
Joined Sep 2012
Jeez wish i was as skilled as you
AirplaneFreak100 is offline Find More Posts by AirplaneFreak100
Build Log 747-8i Build rlebaron RC Airliners (Commercial, Cargo, Troop Carrier) 210 Feb 25, 2014 05:45 PM
Gallery Ultra micro 5g Boeing 747 mrexcel Scratchbuilt Indoor and Micro Models 17 Oct 02, 2013 03:50 PM
Discussion Late 747 JAL cargo build w747 RC Airliners (Commercial, Cargo, Troop Carrier) 26 Dec 18, 2012 10:04 PM
Idea Dual Thrust IR Micro Boeing 747 Electronick RC Airliners (Commercial, Cargo, Troop Carrier) 19 Oct 24, 2012 01:26 AM
Discussion Build micro-quad from micro-heli spare parts midelic Multirotor Talk 1 Apr 26, 2012 03:46 PM
