Old Dec 26, 2012, 11:17 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Build Log
FM - Midwest L-19 and Min- X Galloping Ghost
Ok, time to do another build log of re-living my youth. This one will be on the Midwest L-19 I had in high school. The same time as my Falcon 56. I had a Min-X Pulsmite GG with a Rand LR-3 actuator and an Enya 09 engine.
I did find a Min-X GG system and that is on its way and an Enya 09 already here!
I could not find a Midwest kit but I did have a copy of the plans. I used my CAD program to create a set of plans that I could build from. It'll take a few days to get the shop ready and start building.
I'm also considering using electric power. We'll see.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Dec 27, 2012, 11:18 AM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
Do you by any chance have the full size windshield template for this?
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Dec 27, 2012, 11:38 AM
buzzard bait is offline
Find More Posts by buzzard bait
United States, NY, Ithaca
Joined Sep 2007
Wonderful project! Thank you for posting the CAD plans, the great old pics, and the classy Min-X transmitter.
I hope you go with the Enya 09...great little engine. I've got two good used ones from ebay and they run perfectly. Here's my Petite Parasol from a 1966 MAN article that I still have...
buzzard bait is offline Find More Posts by buzzard bait
Old Dec 27, 2012, 01:43 PM
Joined Mar 2008
John
This is all I have:
Old Dec 27, 2012, 06:31 PM
Joined Nov 2009
Thanks!
John
Old Dec 29, 2012, 12:48 PM
Joined Mar 2008
Revised the full size pdf drawing to include windshields and a few typo errors. See OP.
Old Dec 30, 2012, 10:39 PM
Joined Mar 2008
Spent some time cutting out the parts, thus making my own kit. I print out the plan, then cut it up and use 3M 77 spray to attach the plans to the wood. Then I cut out to the lines and remove the plan from the wood.
I did have some 5/16 wood for the LE. The spars, LE, TE, and LE sheeting have all been cut out. The stab, fin, and rudder pieces have been cut out. I made up the 2 fuselage sides, 3/8 frame, bottom sheeting, LG mount, and stringers.
Tomorrow the ribs and the formers.
Old Dec 31, 2012, 05:21 PM
HobbyCNC is offline
Find More Posts by HobbyCNC
HobbyCNC's Avatar
Joined May 2004
Looking good!
HobbyCNC is offline Find More Posts by HobbyCNC
Old Jan 02, 2013, 01:36 AM
Joined Mar 2008
All the ribs, formers, and misc. fuselage pieces are cut out, sanded and ready to build with. I'm too tired to take pictures. I'll provide them tomorrow.
Old Jan 02, 2013, 11:03 AM
Joined Mar 2008
Here is my kit!
Old Jan 03, 2013, 08:32 PM
Joined Mar 2008
The stab, elevator, rudder, and fin are built. They have been sanded smooth but still need to be rounded off.
I built both wing panels and the center section is now drying.
Moving along!
Old Jan 03, 2013, 08:35 PM
HobbyCNC is offline
HobbyCNC's Avatar
Joined May 2004
Moving along!
"I see you" building your airplane....
Looks great!
Old Jan 04, 2013, 04:44 PM
Joined Mar 2008
The wing is done. Just some very minor detail sanding then it will be ready to cover. It weighs 2.71 oz (77 grams) as it sits.
I'm including a picture of the stab, elevator, fin, and rudder too. The edges have to be rounded off on these.
On the wing where the panels meet the center section and where the main panel begins its taper, I added a false rib to support the LE sheeting.
Old Jan 04, 2013, 09:47 PM
HobbyCNC is offline
HobbyCNC's Avatar
Joined May 2004
Nice work!
Old Jan 04, 2013, 11:04 PM
Joined Mar 2008
Thanks HobbyCNC!
The wing and tail surfaces need some small detail sanding then the'll be ready to cover.
The weights so far are:
Wing - 77g 2.71 oz
Stab - 7g
Elevator - 5g
Fin - 3g
Rudder - 2g
Total - 94g or 3.31 oz.
It's lighter than I thought. I'm using my heavier wood too!
On to the fuselage.
Help! Min-X Galloping Ghost Crist Rigotti Vintage & Old-Timer Designs 18 Dec 23, 2012 07:57 PM
Wanted Midwest L-19 Crist Rigotti Aircraft - Fuel - Airplanes (FS/W) 1 Dec 20, 2012 06:59 AM
Discussion Midwest L-19 Crist Rigotti Vintage & Old-Timer Designs 16 Dec 13, 2012 05:52 PM
Discussion galloping ghost lostplane900 Combat 0 Mar 24, 2012 04:29 PM
Sold Vintage Min-X Galloping Ghost System BobHH Aircraft - General - Radio Equipment (FS/W) 0 Nov 20, 2010 04:40 PM
