Old Feb 14, 2013, 04:38 PM
jbrooks01 is online now
Find More Posts by jbrooks01
New Bethlehem, Pa
Joined Nov 2006
Today's short project was the vertical stabilizer. I slotted the stab and rudder for the C A hinges, and sanded the bevels on the L E of the stab and L E and T E of the rudder. I used a ruler and a sharpie to draw straight and true lines on the fuse to aid in setting the stab. I attached the stabilizer to the fuselage with thick C A, insuring it was between the lines, and vertical to the horizontal stab by using a square. It looks good enough for government work. John
jbrooks01 is online now Find More Posts by jbrooks01
Old Feb 14, 2013, 06:25 PM
sirzeppu is offline
Find More Posts by sirzeppu
sirzeppu's Avatar
United States, UT, Farmington
Joined Aug 2011
Permanently installing the empennage is one of the most stressful parts of building (for me). Good job on yours!
sirzeppu is offline Find More Posts by sirzeppu
Old Feb 14, 2013, 09:49 PM
New Bethlehem, Pa
Joined Nov 2006
Thanks for the Kudos. John
Old Feb 15, 2013, 04:36 PM
New Bethlehem, Pa
Joined Nov 2006
I test fit the elevator and rudder today. Only the bottom of the rudder and the rear fuselage remained to be slotted, I drew a line and made the slots. I used a small Dremel drum sander to make the notch in the rudder for the elevator connector rod, and dry fitted the control surfaces with C A hinges. Everything works smooth and lines up. John
Old Feb 17, 2013, 06:17 PM
New Bethlehem, Pa
Joined Nov 2006
I finished the tail filler blocks today. The kit came with a 10" 3/4" X 3/4" block, which I cut in half, one for each side of the vertical stabilizer. I sanded and shaped the blocks to approximately the desired shape and used 6 Minuit epoxy to attach them to the fuselage. I used Hobby Lite balsa filler to fill the joints, and sanded with sanding sticks to finish up.
Old Feb 18, 2013, 04:43 PM
New Bethlehem, Pa
Joined Nov 2006
The fuselage is now ready to cover. I mocked everything up, and got a surprise. The tail wheel setup I was planning on using wouldn't work because of the rake of the rudder. I had a partial tail wheel setup for the Dubro Scale Tail Wheel, and decided to use that. I ordered a new one, but it will probably take a week to get here. The weight of the fuselage with control surfaces and landing gear is 22 1/8 oz, my goal for the same set up covered was and still is 24 oz. I may go a little over but maybe I can make up for it on the wing which has a goal of 16 oz. The combined weight of the motor, ESC, battery, prop, spinner, and 4 servos is 1 3/4 lb, so it looks like my flying weight is going to be around 4 1/4 lb. I am going to finish the remaining work on the wing before I do any covering. The box is looking pretty empty. John
Old Feb 20, 2013, 05:33 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
By George, I believe it is beginning to look like a Smoothie!
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: Carbon-Z T-28
Old Feb 20, 2013, 10:33 PM
New Bethlehem, Pa
Joined Nov 2006
Thanks, don't give up on me. I am trying to get the wing to look as smooth as possible, and that is taking me some time. John
Old Feb 22, 2013, 05:40 PM
KOMET 44 is offline
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Well,at least the boxis getting emptyer! Plane is looking great.Good look with the covering job.
sP
KOMET 44 is offline Find More Posts by KOMET 44
Old Feb 22, 2013, 05:46 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Yep, it won't be long until you clean off the workbench and start on your next project
Old Feb 22, 2013, 05:52 PM
twalther is offline
Find More Posts by twalther
United States, MN, Waseca
Joined Jan 2011
Who cleans a work bench!
twalther is offline Find More Posts by twalther
Old Feb 22, 2013, 05:56 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
I have a ritual when I finish a plane....CLEAN OFF EVERYTHING.....so I don't put the wrong part on the right plane
Old Feb 22, 2013, 09:30 PM
New Bethlehem, Pa
Joined Nov 2006
Everything is sanded and smoothed. I put a 3/32" cap on the trailing edge of the wing to give the C A Hinges something to bite onto, and slotted the ailerons and T E. Everything lines up, now all I have to do is find the slots after I finish covering. Will start covering the wing tomorrow. There are some flaws, but I hope they won't be too noticeable. Here is the last pictures of the naked wood. The weight as pictured is 34 oz. John
Old Feb 23, 2013, 08:21 AM
sirzeppu is offline
sirzeppu's Avatar
Joined Aug 2011
Beautiful
Old Feb 23, 2013, 09:10 AM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Looks good
cbarnes0061 is offline Find More Posts by cbarnes0061
Discussion Balsa USA Smoothie jbrooks01 Balsa Builders 2 Dec 26, 2012 10:50 PM
Sold Balsa USA "Smoothie" kit High & Mighty Aircraft - Fuel - Airplanes (FS/W) 4 Nov 15, 2012 04:10 PM
Sold Balsa USA Smoothie Kit Un-Opened Box 52" Span 40-50 2-Stroke Sport R/C FlyinPhilsPhotos Aircraft - Fuel - Airplanes (FS/W) 0 Mar 14, 2012 08:28 AM
Discussion Balsa USA Smoothie Conversion twinster2 Glow to Electric Conversions 10 Feb 06, 2006 11:15 PM
NIB: Balsa USA Smoothie twinster2 Aircraft - Fuel - Airplanes (FS/W) 0 Nov 17, 2003 11:08 PM
