New Bethlehem, Pa
Joined Nov 2006
Balsa USA Smoothie Build Thread
I finally got to open my Christmas present and get to start my BUSA Smoothie build http://shop.balsausa.com/product_p/443.htm . The Manual they give you in the new kit is first class and better than the 2 pages of instructions included with the original. Will be spending a day or two reading the instructions, studying the plans, and figuring out how to convert it to electric and still keep it around 4 lbs. I have an AXI 2820/12 and with a 12/6 APC E prop I should get 4 1/2 lb max thrust with a 3s 4000 mah lipo. I am planing on starting the wing first and will be using 2 aileron servos instead of the torque rod setup. I cut up the plan to make it more manageable taped the wing section onto my Building Board, then punched out the ribs to get ready for the wing build. The ribs weighed 2 1/8 oz so the weight is building up fast. Here's a picture. John
I built one many, many years ago .... a great (but fast) flying bird! Enjoy the build, especially carving the fuselage's nose
Latest blog entry: Is it possible to lose weight?
Just a LOT of balsa, that isn't a Smoothie
I also use two types of CA to attach sheeting. How long does it take to get an order from Horizon?
Good Luck with the Monokote....I've heard some bad comments about the 'current' stuff. I still have some 10-15 year old rolls and have no intentions about purchasing new covering from them.
New Bethlehem, Pa
Joined Nov 2006
While I was waiting for my thick CA I sheeted the bottom front of the starboard wing, then made servo mounts for the ailerons. I used 1/16" plywood strips between the ribs, and a servo as a guide. then some scrap 3/32" balsa to fill in around the servos. The servos I will be using are the iFlight 25g's from Heads Up RC http://www.headsuprc.com/servlet/the...PB-Mini/Detail . I tested the servos and they all work. They are about the same as HS 225's but much cheaper. Anyone used these servos? John
| Thread Tools | |
| Discussion Balsa USA Smoothie | jbrooks01 | Balsa Builders | 2 | Dec 26, 2012 10:50 PM |
| Sold Balsa USA "Smoothie" kit | High & Mighty | Aircraft - Fuel - Airplanes (FS/W) | 4 | Nov 15, 2012 04:10 PM |
| Sold Balsa USA Smoothie Kit Un-Opened Box 52" Span 40-50 2-Stroke Sport R/C | FlyinPhilsPhotos | Aircraft - Fuel - Airplanes (FS/W) | 0 | Mar 14, 2012 08:28 AM |
| Discussion Balsa USA Smoothie Conversion | twinster2 | Glow to Electric Conversions | 10 | Feb 06, 2006 11:15 PM |
| NIB: Balsa USA Smoothie | twinster2 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Nov 17, 2003 11:08 PM |
