Old Dec 26, 2012, 09:52 PM
jbrooks01 is offline
Find More Posts by jbrooks01
New Bethlehem, Pa
Joined Nov 2006
Balsa USA Smoothie
I finally got to open my Christmas present and get to start my BUSA Smoothie build http://shop.balsausa.com/product_p/443.htm . The Manual they give you in the new kit is first class and better than the 2 pages of instructions included with the original. Will be spending a day or two reading the instructions, studying the plans, and figuring out how to convert it to electric and still keep it around 4 lbs. I have an AXI 2820/12 and with a 12/6 APC E prop I should get 4 1/2 lb max thrust with a 3s 4000 mah lipo. I am planing on starting the wing first and will be using 2 aileron servos instead of the torque rod setup. I cut up the plan to make it more manageable taped the wing section onto my Building Board, then punched out the ribs to get ready for the wing build. The ribs weighed 2 1/8 oz so the weight is building up fast. Here's a picture. John
jbrooks01 is offline Find More Posts by jbrooks01
Old Dec 26, 2012, 10:44 PM
kimchiyuk is offline
Find More Posts by kimchiyuk
kimchiyuk's Avatar
United States, NY, Barryville
Joined Jun 2012
Good luck with the build. It's a cool looking plane. Are you going to do a build thread?
kimchiyuk is offline Find More Posts by kimchiyuk
Old Dec 26, 2012, 10:50 PM
New Bethlehem, Pa
Joined Nov 2006
Yes, this the build thread.
Sold Balsa USA "Smoothie" kit High & Mighty Aircraft - Fuel - Airplanes (FS/W) 4 Nov 15, 2012 04:10 PM
Sold Balsa USA Smoothie Kit Un-Opened Box 52" Span 40-50 2-Stroke Sport R/C FlyinPhilsPhotos Aircraft - Fuel - Airplanes (FS/W) 0 Mar 14, 2012 08:28 AM
Sold Balsa Usa Smoothie Kit happybird Aircraft - Fuel - Airplanes (FS/W) 4 Sep 10, 2009 06:06 AM
Discussion Balsa USA Smoothie Conversion twinster2 Glow to Electric Conversions 10 Feb 06, 2006 11:15 PM
NIB: Balsa USA Smoothie twinster2 Aircraft - Fuel - Airplanes (FS/W) 0 Nov 17, 2003 11:08 PM
