This thread is privately moderated by RAMMER JAMMER, who may elect to delete unwanted replies.
Old Dec 26, 2012, 08:35 PM
RAMMER JAMMER is offline
Find More Posts by RAMMER JAMMER
Joined Dec 2009
receiver compatibility
Just received Flyzone's new DHC-2 Beaver for Christmas.
Can I use a Spectrum AR500 receiver in lieu of one installed ?
RAMMER JAMMER is offline Find More Posts by RAMMER JAMMER
Old Dec 26, 2012, 08:52 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
yes, but flaps will have to be on channel 5 (gear channel) meaning you'll have to mix your flaps channel to the gear channel to control them from your usual switch/slider.
copperbricks is offline Find More Posts by copperbricks
Old Dec 27, 2012, 08:59 AM
Joined Dec 2009
AR500 receiver use
Thanks for the response. Can I just use the gear switch for flaps instead of flaps switch (DX6i) ?
Also, this plane has lights. Can these switches be plugged in ?
Old Dec 27, 2012, 01:50 PM
Stikflyer is offline
Find More Posts by Stikflyer
Nova Scotia, Canada
Joined Apr 2006
With just a 5 channel Rx you will need a Y-harness so you can plug the lights in parallel with one of the other channels. The lights just require power, no signal needed.
Stikflyer is offline Find More Posts by Stikflyer
Old Dec 27, 2012, 02:52 PM
Joined Aug 2011
yes, just using the gear switch will be fine. Lights can be plugged into any channel with a y-harness.
New Product 2.4Ghz A-FHSS Compatible Receivers (Hitec Minima compatible) renatoa Radios 5 Sep 17, 2012 08:56 AM
Off Site Futaba FASST Compatible Receivers Rotozuk Aircraft - General - Radio Equipment (FS/W) 17 Mar 27, 2012 10:00 PM
Discussion Hitec 2.4 compatible receivers vuoladodo Radios 10 Mar 26, 2012 11:43 AM
Discussion Spectrum compatible receivers now available. HobbyCool_tech Mini Helis 0 Mar 20, 2012 07:20 PM
Sold Orange receivers (Futaba compatable) TG43 Aircraft - General - Radio Equipment (FS/W) 1 Mar 14, 2012 01:20 AM
