Old Dec 26, 2012, 03:47 PM
bassfisha is offline
Find More Posts by bassfisha
Joined Sep 2012
Seagull glasair sportsman
Got this beauty for Christmas and can't wait to get building. Anyone build this model up? What was your engine choice?
bassfisha is offline Find More Posts by bassfisha
Old Dec 27, 2012, 05:11 AM
bladebender is offline
Find More Posts by bladebender
United States, MI, Waterford Charter Township
Joined Apr 2008
I put a saito 115 like the size and power fit perfict .Bought the floats to that why I got it .Very nice plane just don't like the covering starting to sag
put a saito 115, like the power bought the floats to very nice plane just don't like the covering it is starting to sag.Saito is a sweet motor small and a lot of power .More and more impressed with seagull airplane would like a 377 arf
bladebender is offline Find More Posts by bladebender
Old Dec 27, 2012, 06:41 AM
Joined Sep 2012
How's the fuel usage with it and flight times.? I was thinking of maybe a dle 20? Electric would get very expensive for batteries at this size.. All I have is a bunch of 2200 3s.
Definitely getting floats too.
Old Dec 27, 2012, 09:10 AM
Joined Apr 2008
still building the plane should be done this week I hope , have run the motor in my p51 as long as you don't fly the hole flite at full throttle should not be to bad. Dle 20 should work good I would beef up firewall just put epoxy all over mine
Old Dec 30, 2012, 04:38 AM
Joined Apr 2008
well that saito 115 might not be a good idea hard to line up pushrod for throttle,but I got it.Now working on the wing slot for servo arms are off ,easy fix
Old Dec 30, 2012, 07:24 AM
Joined Sep 2012
I'm still toying with what to power this bird with.
Maybe electric, saito fg21 or 17, or a zenoah, dle... I like the sound of the saito but not the price. Got any build photos of how that engine looks? Looks to be plenty of space in that cowl. It's pretty large.
Old Dec 31, 2012, 04:30 AM
Joined Apr 2008
engin fits fine will have to cut the cowl for the head of the fourstoke
Old Jan 06, 2013, 09:05 AM
Joined Sep 2012
How's the build going blade?
Old Jan 09, 2013, 04:10 AM
Joined Apr 2008
have to many planes started .Put and engin in that new hanger9 super cub a dle35ra. Now back to the glasair cut the slot bigger in the wings so the servo arms fit going to order lites.Just not alot of time with work
Old Jan 19, 2013, 03:41 PM
MICKEL is online now
Find More Posts by MICKEL
C.H.E.A.P.
MICKEL's Avatar
Chino Hills, CA
Joined Jan 2005
Fa 115
A pic of my engine install and with the cowl on. Use the 90 manifold and you'll be cutting less.
MICKEL is online now Find More Posts by MICKEL
Old Jan 22, 2013, 04:15 AM
Joined Apr 2008
Mickel where is your throttle servo had a hard time with mine. Did you buy the float set with yours
Joined Apr 2008
Forgot to say looks good
Old Feb 02, 2013, 08:28 PM
moto mike is offline
Find More Posts by moto mike
moto mike's Avatar
Illinois
Joined Mar 2008
Hi folks
Just picked up a Glasair Sportsman 2+2 75-91 ARF
by Seagull.
Wondering what other engines people have used. The Saito 115 sounds good except for the price. I am considering a gas 20cc engine. Anyone have experience with the xyz 20?
Wing loading is in the 35oz per sq foot and wondered how it flies. MAN article makes it sound like a floater, but that weight made me think it would fly heavy.
My first impression is that the airplane is very well made. It has a sculpted appearance with lots of compound curves which means it was probably labor intensive compared to some ARFs out there. Control surfaces are pre-hinged with pocket hinges and move very freely while keeping a tight fit against the wings and stabs. Control horns are composite and are to be epoxied into precut recesses in the control surfaces. Flaps included. Control rods appear to be carbon fiber. Separate servo for the tail wheel which is pull pull. Covering will need some iron and heat gun attention, and is not as good as some I've seen, but not too much. Two pilots included.
moto mike is offline Find More Posts by moto mike
Old Feb 04, 2013, 12:42 PM
moto mike's Avatar
Illinois
Joined Mar 2008
Mickel
Seeing you live in a more temperate climate, I was wondering if you have maidened your Sportsman yet. The Saito looks nice in there.
Hoping to get some more dicussion going on this plane. Sort of surprised that not much is being said.
Old Feb 04, 2013, 12:49 PM
moto mike's Avatar
Illinois
Joined Mar 2008
Blade Bender
could you discuss the problems you had with the throttle hook up and what you did to get around it? I'm still considering an engine.
Looking at the assembly manual, it is not clear what is holding the wings on.
thanks
Discussion Blackhorse Glasair 120 shane55 Fuel Plane Talk 33 Aug 19, 2014 06:40 AM
For Sale Byron glasair td RAMFlyer Aircraft - Fuel - Airplanes (FS/W) 1 Feb 17, 2013 10:45 AM
Discussion Seagull glasair sportsman bassfisha Scale Kit/Scratch Built 3 Jan 31, 2013 04:28 AM
Sold Byron Glasair :: Fully Assembled, "ARF" sans Engine :: LPU Northern VA N925WB Aircraft - Fuel - Airplanes (FS/W) 4 Sep 17, 2012 10:42 AM
Sold Sportsman Aviation sportsman aviation ryan sta ypt 16 ARF rcdude01 Aircraft - Electric - Airplanes (FS/W) 3 May 08, 2012 08:51 PM
