Old Jan 01, 2013, 08:45 AM
Our God's Alive
100mph's Avatar
United States, NE, Bennet
Joined Mar 2011
Originally Posted by davereap View Post
My guestimate is that I will be slower at both ends of the range...with more area and more drag from its thickness and structure on mine.... plus I am turning a bigger prop with less revs, a 5x3 on 1 cel with a 4500kv 5gm motor....
It is just frustrating at the moment.. england is wet and windy every day..and our indoor session is not for another 10days..
have a good new year
Ok, now that I think about it your plane will be slower. Sorry about your weather, mine is snow and 10 mph wind. The place I fly at is only a indoor basketball court.
100mph is offline Find More Posts by 100mph
Old Jan 08, 2013, 08:54 AM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Its been maidened outdoors.. sorry my camera went dead so there is no video.. but it flys fine and its top speed is a lot slower than yours...
Mine doesnt like the wind much but will be fine indoors...
EDIT.......The larger area on mine makes for a slow and smooth cruising flight indoors, loops are tight and easy , it will do circles in as little as 6 feet, but the roll rate is sadly slow...so on the next version I will have to vary the wing area to control surface area
I have also found a much lighter material than the pretty xmas foils... white 12 or 18 micron carrier bags, which heat shrink at 110 degrees
davereap is offline Find More Posts by davereap
Old Jan 08, 2013, 04:07 PM
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
100 have you seen this thread, it would probably make quite an improvement with your wing.
TODD
http://www.rcgroups.com/forums/showt...=895413&page=3
I R Irv is offline Find More Posts by I R Irv
Old Jan 14, 2013, 10:38 PM
Our God's Alive
100mph's Avatar
Joined Mar 2011
Just looked through the thread, lots of good info in it.
My wing can only fly outside in a 0-3 mph wind, over that and it gets bumped around and changes direction a lot.
Old Jan 15, 2013, 04:58 AM
I R Irv's Avatar
Joined Nov 2008
It's the ball bearing mod that makes it a whole new motor.
TODD
Old Jan 15, 2013, 12:32 PM
Our God's Alive
100mph's Avatar
Joined Mar 2011
TODD
thanks, I saw that and wondered if it would get ride of the vibration at high speed, it is easy to the the vibration is caused by lack of bearing support.
Sold ar6400 receiver with 2 micro servos and lipos devinvagt Aircraft - Electric - Micro & Indoor Airplanes 1 Jun 18, 2012 12:24 AM
Sold 2 x 1.7 gram micro servos with 1.25 molex connectors Johnnymeg Aircraft - Electric - Micro & Indoor Airplanes 7 May 17, 2012 07:21 PM
Sold Used hk 1.7 gram servo with ar6400 connector 7 shipped conus nemoskull Aircraft - Electric - Micro & Indoor Airplanes 0 Apr 04, 2012 01:13 AM
Discussion 2-3 gram servo for use with AR6400? Cheesehead Indoor and Micro Models 8 Oct 01, 2011 09:09 AM
Discussion For sale 2 mighty midgets brushless sub-micro brushless motors 3.5 grams anestho Indoor and Micro Models 0 Aug 04, 2006 12:21 PM
