Old Dec 27, 2012, 03:45 PM
methuso is offline
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Ístersund, SWEDEN
Joined Sep 2005
THank You soooo much... now i dont have to put up wallpapers in the livingroom tomorrow?? hmm wait... maybe my wife will have an opinion on that.
methuso is offline Find More Posts by methuso
Old Dec 27, 2012, 04:01 PM
I R Irv is online now
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
There is alot of wings that can be done and they're all here in RCG. These are 2-cell but they could also easily be addapted to 1-cell. David, Slinger, Superfly-ish and my own design with twin elevons w/rudders.
TODD
I R Irv is online now Find More Posts by I R Irv
Old Dec 27, 2012, 06:22 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Originally Posted by nemoskull View Post
that cool! how does the 3020 stack up against the gws 5208 or 2510?
Jeez!!!! It's the HK (LCD) 2 gram motor!!! You'd kill it with a 5 inch prop.
356Jim is offline Find More Posts by 356Jim
Old Dec 27, 2012, 07:00 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
sorry, my dyslexia again. "2508"
nemoskull is offline Find More Posts by nemoskull
Old Dec 27, 2012, 09:07 PM
100mph is offline
Find More Posts by 100mph
Our God's Alive
100mph's Avatar
United States, NE, Bennet
Joined Mar 2011
TODD
They look great. I've seen the david, and the slinger, there was a couple people that used 1 cells in the david thread.
100mph is offline Find More Posts by 100mph
Old Dec 28, 2012, 01:14 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
And dont forget, you can always change the motor to the front , just like the stingray for any of the designs.. This gets rid of the problem of how to run your pushrods wide past the prop slot.. And as long as your COG is correct the model will fly..
davereap is offline Find More Posts by davereap
Old Dec 28, 2012, 08:17 AM
100mph is offline
Our God's Alive
100mph's Avatar
Joined Mar 2011
I agree with that, there is a big angle with the pushrods, but moving it to the front will fix that.
Old Dec 28, 2012, 02:41 PM
100mph is offline
Our God's Alive
100mph's Avatar
Joined Mar 2011
Also you can leave the nose pointed and put a carbon fiber spar straight through the wing.
Old Dec 28, 2012, 04:14 PM
cabman1969 is offline
Find More Posts by cabman1969
cabman1969's Avatar
Melbourne, Australia
Joined May 2008
Thank you davereap for the information on setup. Much appreciated!
cabman1969 is offline Find More Posts by cabman1969
Old Dec 29, 2012, 06:03 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
you are welcome, I am just getting into these micro models myself... normally I build foamies with layered KF wings.. but planes are planes and its all a matter of scale.. but with the micros every gram of weight affects its performance...
I am looking at build methods in an attempt to get better strength but without a weight gain..
The simple single layer of 3 mm is good, its likely with its flat CF along the leading edge is the best and simplest option..
3mm doubled up with glue between is much tougher, add tape over and its even better, but it all adds weight, which kills performance..
So far an open cut layered structure is looking good, with a film sandwiched between the layers to fill the gaps.. Its a lot more work, but I hope it will increase the longevity of any model..
I haven't built a V wing with this method but built a slow delta type
Old Dec 30, 2012, 06:53 AM
100mph is offline
Our God's Alive
100mph's Avatar
Joined Mar 2011
Looks good, lots of wing area. Here is my flying wing but made out of 9mm epp and a 2 cell with a 12mm inrunner. It weighs 2.75 ounces.
Description:
Description:
Old Dec 31, 2012, 10:02 AM
100mph is offline
Our God's Alive
100mph's Avatar
Joined Mar 2011
Yesterday I flew my micro wing indoors, and it flies really slow and fast. It can fly as slow as a champ.
Old Dec 31, 2012, 05:51 PM
davereap is offline
davereap's Avatar
Joined Feb 2005
Thats good, you obviously have the design correct.. first time..
Your area is 100.5sq" which is almost double the micro sukoi's 52sq"
But how does it's area compare with the champ's?
my xmas wing above has 225sq" so its going to be interesting to see what kind of speed range I get
did you get any indoor video?
Old Dec 31, 2012, 06:11 PM
100mph is offline
Our God's Alive
100mph's Avatar
Joined Mar 2011
I don't know the champs wing area. I forgot to bring my camera to indoor flying, so no video. Your speed should be the same or a little faster than my wing.
Old Jan 01, 2013, 02:33 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
My guestimate is that I will be slower at both ends of the range...with more area and more drag from its thickness and structure on mine.... plus I am turning a bigger prop with less revs, a 5x3 on 1 cel with a 4500kv 5gm motor....
It is just frustrating at the moment.. england is wet and windy every day..and our indoor session is not for another 10days..
have a good new year
Sold ar6400 receiver with 2 micro servos and lipos devinvagt Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 18, 2012 12:24 AM
Sold 2 x 1.7 gram micro servos with 1.25 molex connectors Johnnymeg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 7 May 17, 2012 07:21 PM
Sold Used hk 1.7 gram servo with ar6400 connector 7 shipped conus nemoskull Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Apr 04, 2012 01:13 AM
Discussion 2-3 gram servo for use with AR6400? Cheesehead Scratchbuilt Indoor and Micro Models 8 Oct 01, 2011 09:09 AM
Discussion For sale 2 mighty midgets brushless sub-micro brushless motors 3.5 grams anestho Scratchbuilt Indoor and Micro Models 0 Aug 04, 2006 12:21 PM
