Old Dec 26, 2012, 01:58 PM
Our God's Alive
100mph's Avatar
United States, NE, Bennet
Joined Mar 2011
Plans for Micro wing with a AR6400 and 2 gram brushless.
This is my 20 inch flying wing made out of 3mm depron and a carbon fiber strip on the leading edge for support. It has a 2 gram outunner, a 3x2 prop, 160 mah 1 cell hyperion lipo, AR6400 converted to brushless, and a cheap hobbyking 3 amp brushless ESC. Flying weight with battery is 19 grams.
Micro rc wing (2 min 9 sec)
Description:
Description:
Here's the plans provided by Davereap
Click this one:
Description:
100mph is offline Find More Posts by 100mph
Old Dec 26, 2012, 03:20 PM
Westbrook Maine
Joined Apr 2003
Wow. Nice flying and great video.
Fritz
fmhans is offline Find More Posts by fmhans
Old Dec 26, 2012, 05:00 PM
Our God's Alive
100mph's Avatar
Joined Mar 2011
Fritz
Old Dec 26, 2012, 05:38 PM
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
that cool! how does the 3020 stack up against the gws 5208 or 2510?
nemoskull is offline Find More Posts by nemoskull
Old Dec 26, 2012, 07:18 PM
Our God's Alive
100mph's Avatar
Joined Mar 2011
I've never tried those props, all I have is the 3020 ones. They seem to work well, the wing has a little over a 1:1 thrust ratio with the 3x2 prop.
Old Dec 27, 2012, 12:46 AM
cabman1969's Avatar
Melbourne, Australia
Joined May 2008
I'm also working on a wing for the ar6400.. I need to ask someone how to set up the elevons with an ar6400 and a dx6i using just the brick servos???? Can someone please give me some advice???
cabman1969 is offline Find More Posts by cabman1969
Old Dec 27, 2012, 12:54 AM
Sonic Rainbooms for all
airpower's Avatar
Joined May 2007
Um, radio programming, wing type/mixing, elevon. It's in the manual, which you can get online at horizon hobby or spektrum website.
airpower is offline Find More Posts by airpower
Old Dec 27, 2012, 06:33 AM
A.K.A sir Crashalot
methuso's Avatar
Östersund, SWEDEN
Joined Sep 2005
Very, very nice. seems not too fast too, which might be good for me
Please share the construction. I llways wanted a wing but never got me one.This seems cheap enough having some DTrx's and some 1.7gr HK servos and yea.. some 2 grammers too.
Plans, wingfoils ??
/Methuso
methuso is offline Find More Posts by methuso
Old Dec 27, 2012, 07:16 AM
ror
Joined Aug 2009
Oh yes ! A plan please Mr 100 mph, please !!
ror is offline Find More Posts by ror
Old Dec 27, 2012, 07:57 AM
Our God's Alive
100mph's Avatar
Joined Mar 2011
I'll get a drawing on paper sometime today. As for the mixing, I used v-tail because that uses the rudder and elevator on the ar6400. It is a very floaty plane.
Old Dec 27, 2012, 09:23 AM
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
The standard block has only elevator and rudder servos on board, so elevon mixing is not of use without also mixing the ailerons to move the rudder servo...first set elevons on... then go to one of the two available mixes and use aileron as master with rudder as the slave.. set the mix to 100% then when you move the aileron stick the rudder(on board servo) will move...you may have to fiddle with the +-on the %ages in the mix to get the movements going the correct way
also as above.....I will have to try that on my wing...its a much simpler solution.... duh! I am getting old and dont see the obvious sometimes..lol
Good video and a nice wing....
From the picture it looks like a simple constant chord wing..with a chord at about 6".. whatever the chord, it can be enlarged a bit if you want a slower wing.. but remember extra weight on these light weights is a killer to performance..
Have a look here for a variety of V wing shapes... then scale them down to an appropriate span and build as per the specs from 100mph
http://www.rcgroups.com/forums/showthread.php?t=1122108
question what kv motor did you use...
If you post the dimensions I can draw it up in sketchup for you..... dave
davereap is offline Find More Posts by davereap
Old Dec 27, 2012, 10:12 AM
Our God's Alive
100mph's Avatar
Joined Mar 2011
Here is a drawing of half the wing, You might want to make the prop slot more at a 90 degree to the center. I used a 3x1 mm carbon fiber strip on the whole leading edge, there is no airfoil. Balance point is half way on each side of the leading edge. You also have to round the front so the carbon strip can bend around it.. Sorry if some of this isn't clear, I am sick and have a 101.9 degree fever, so I can't think to well.
Description:
Description:
Old Dec 27, 2012, 11:07 AM
davereap's Avatar
Joined Feb 2005
what is the angle for the sweep back? or the distance it sweeps back..
working from your picture and measurements I get this..I hope its close.. a sweep of almost 35 degrees
Old Dec 27, 2012, 11:11 AM
NEWBEFLYER's Avatar
United States, VA, Woodbridge
Joined Apr 2007
Here's the mini StinRay you can find on this indoor site plans and all. Easy flyer love it. Weighs a little more 28gr good indoor flyer. 3mm foam I used a mustang mtor and brick along with a Mossy prop. Great for combat.
NEWBEFLYER is offline Find More Posts by NEWBEFLYER
Old Dec 27, 2012, 12:33 PM
Our God's Alive
100mph's Avatar
Joined Mar 2011
I couldn't find a protractor when I was measuring it. Your picture has the same sweep back as my wing, the second picture looks correct for plans.
Sold ar6400 receiver with 2 micro servos and lipos devinvagt Aircraft - Electric - Micro & Indoor Airplanes 1 Jun 18, 2012 12:24 AM
Sold 2 x 1.7 gram micro servos with 1.25 molex connectors Johnnymeg Aircraft - Electric - Micro & Indoor Airplanes 7 May 17, 2012 07:21 PM
Sold Used hk 1.7 gram servo with ar6400 connector 7 shipped conus nemoskull Aircraft - Electric - Micro & Indoor Airplanes 0 Apr 04, 2012 01:13 AM
Discussion 2-3 gram servo for use with AR6400? Cheesehead Indoor and Micro Models 8 Oct 01, 2011 09:09 AM
Discussion For sale 2 mighty midgets brushless sub-micro brushless motors 3.5 grams anestho Indoor and Micro Models 0 Aug 04, 2006 12:21 PM
