Old Dec 27, 2012, 10:40 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
subbed. this is gonna be interesting.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 28, 2012, 06:42 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
<<< Grabs a chair
D_FAST is offline Find More Posts by D_FAST
Old Jan 07, 2013, 01:59 PM
demondriver is online now
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Look'in Great Nate!, I have a costumer who wants an EDF B-1 so I'm gonna learn as much as I can from you & the-Flex before I start my Swing-Bone.
Subbed up!
demondriver is online now Find More Posts by demondriver
Latest blog entry: Foam Safe Spray paint!
Old Jan 07, 2013, 08:06 PM
IWC is online now
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
subscribed
IWC is online now Find More Posts by IWC
Old Jan 08, 2013, 12:32 AM
edwen303 is online now
Find More Posts by edwen303
edwen303's Avatar
United States, CA, Corona
Joined Jan 2010
Subscribed.
Just did twin Concorde 55mm EDF, might get started twin 55mm EDF B-1B once wife grants my "application of funds".
edwen303 is online now Find More Posts by edwen303
Old Dec 13, 2013, 04:49 PM
Primate is offline
Find More Posts by Primate
Primate's Avatar
United States, FL, Winter Park
Joined Aug 2011
Ok, so obviously it's been a year since I started this build. Well, as life would have it my business got very busy shortly afterward and left me with no time/energy to continue on. That being said I am now able to dedicate some time to picking the build back up.
I ordered and have received all of my initial components as far as ESC's, servos, fan units and motors and such. After I started looking at where I left off I and also applying the thought I had put into it over the past year I decided that I would have to start over from scratch. I obtained some new material on the B-1 in the form of a couple of books and some schematics from Rockwell to help with the progression. Now I am coming along with a test version that is intended to work the bugs out before getting into too much work in the physical detail. So that brings us up to speed if anyone is still interested of course. I will post some new pics of my progress this weekend.
Nate
Primate is offline Find More Posts by Primate
Old Dec 13, 2013, 05:31 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Primate, here's a thread you might like to look over. Yes, it's bigger than yours and also a pusher prop, but a B-1 build none the less..
B-1 Bone ( Lancer ) Build
http://www.rcgroups.com/forums/showthread.php?t=530405
(attachments are great!)
John Morgan is a/the premo scratch builder. Although my builds are "different" a lot can be /I have learned from his threads.
Best of luck on your build.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Dec 13, 2013, 05:32 PM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Subscribed!!!
ksqm is offline Find More Posts by ksqm
Old Dec 14, 2013, 03:19 PM
Primate is offline
Primate's Avatar
Joined Aug 2011
Managed to get a little work done on the airframe last night and today. The nacelles on this test model are rectangular to save on build time. I want to get the basic airframe laid out so I can start working out how the wiring and control surfaces are going to work so I'll hold off on doing most of the outer skin until a bit later in the project.
Old Dec 14, 2013, 03:22 PM
Primate is offline
Primate's Avatar
Joined Aug 2011
Thanks for that link Cooler. At this point it doesn't matter to me if a person's B-1 build is pusher prop, turbine or EDF, I soak up as much info as I can since there are relatively very few projects of this model. I still have yet to see B-1 Bob's fly. I don't know if it ever did but I came across a hand full of videos of one that looks like the one he built but it's white and before takeoff it blew a tire on the rough surface of the dry lake bed.
Old Dec 14, 2013, 03:51 PM
i12flyrc is offline
Find More Posts by i12flyrc
i12flyrc's Avatar
Columbus, Ohio, United States
Joined Jul 2003
Hey life happens but glad you have the opportunity to start it back up. Looking forward to watching this progress.
i12flyrc is offline Find More Posts by i12flyrc
Old Dec 19, 2013, 08:46 AM
Primate is offline
Primate's Avatar
Joined Aug 2011
layered a couple sections of foam to support the pivot points and glued in some carbon fiber tubing for the pins. I also started to do some cross sections to help bring the shape together and add some strength. I am currently at 56g total with the nacelles and my running gear including battery comes out to about 160g so I think I should have another 50g give or take to finish the airframe and be ok for a 1:1 thrust:weight ratio but I'll have to see when everything comes together.
Old Dec 20, 2013, 04:05 PM
Primate is offline
Primate's Avatar
Joined Aug 2011
This stinking sweep wing linkage and whatnot is proving to be somewhat frustrating. I wanted to get it working before work but ran out of time. I tested one wing while holding the servo in place and it seemed to work ok but the weight is starting to pile up even while using carbon fiber plate and rods. Oh well, work in progress...
Nate
Old Dec 20, 2013, 09:57 PM
Primate is offline
Primate's Avatar
Joined Aug 2011
Ok. I managed to sort out my difficulties with the swing wing situation and it seems to work pretty good now. Obviously it isn't scale transition speed but I think I'll buy one of those adjustable servo speed deals in the near future.
Old Dec 21, 2013, 05:09 PM
Angelo is online now
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Why don't you hook it up to the flap channel? Then you can adjust the sweep slowly and also leave it at in between settings.
Angelo is online now Find More Posts by Angelo
Build Log B-2 Bomber Jmurdock Foamies (Scratchbuilt) 212 Aug 05, 2013 07:53 AM
Discussion B-17 Bomber-- People's Choice Thread...... CSI Electric Warbirds 40 Oct 08, 2012 01:55 PM
Gallery Near Disastrous maiden flight of a B-17 Bomber!! RobscoRC Electric Plane Talk 45 Jun 14, 2012 04:51 AM
New Product B-25 mitchell bomber 79" Prudolph21 Banana Hobby 7 Jun 13, 2012 12:48 PM
Discussion BANANA HOBBYS HUGE BlitzRCWorks B-25 Mitchell Bomber pulver Electric Warbirds 4 Apr 21, 2012 03:58 PM
