I went to the field and got 3D pilots to try my V922!
They liked it and felt the V922 flight characteristics is similar to their MCPX. One of them took it to the sky for some 3D action.
More details please refer to post #2: http://www.rcgroups.com/forums/showp...67&postcount=2 |
I think it's better for you to try it in simulators or build a training gear for inverted flight. While I could fly the bird upright fairly well, flying it inverted is NOT EASY. In fact, getting it inverted is not easy! But the pros made it look like a piece of cake. At meet ups, they were like coaches examining how I flipped and gave me valuable advice. You should try meeting experienced pilots too.The place was Queenstown. Click on the "Maps" link above. (My RCGroups, Blogs, Classifieds, Clubs, Forums, Maps, Regions, Topics, Search) |
Joined Sep 2012
... the durability of the v922/fbl100 is surprisingly (im still terryfied by my old cb100 ...), tx, motor, gyro, tail, servos - more than adequate even for practicing piroflips (i never thought i could do it after the first two flights with the bird... but i got disabused ...) !!! and a cp-100 at an unbeleivable price (also for spareparts...) like that is not a decision for life-time... imho: the unmanagable product-mess of walkera is not a real recommendation ... macem |
Joined Dec 2012
Not impressed V922
I am not an expert, but I can easily fly my Walkera Genius CP in my living room
Because of the V922 transmitter is without DR/EXP, I will need a gymnasium before I get the V922 into the air so I can trim it or find out its problem The V922 has a bad case of instability and without DR/EXP the problem nearly unmanageable in my living room. I was planning to buy a Mini CP BNF for my second 100 size, wish I had... I though giving the V922 a try would be okay considering it is an e-flite clone... I consider the V922 a e-flite clown... I hope someone comes up with a good hack so I can use my Devo or Turnigy transmitter to save this cripple heli. My bet is Banggood will not print my review
Joined Dec 2012
Hi, yes you can use DEVO to control WLTOY birds, but you need to upgrade the firmware and also need some hardware modification. Please see the site http://www.deviationtx.com/ for more info. Currently, I am using DEVO 10 to fly my Walkera birds and EFlite birds
Joined Dec 2012
I think the most important component for any beginners is a programmable tx, but yet, that is also the most inhibiting factor for anyone to consider entering this hobby. However, I must have to reiterate the importance of it, because it allows you to tame your bird into something that is more manageable to your skill level. When I first flew a CP helicopter, I had no clue about TX settings, and the control is just too sensitive. The settings on TX is just Mars language to me. I kept crashing. I was very frustrated and think that I can never fly a CP. But somehow, I went through that period of frustration and climbed up the learning curve. The real breakthrough came from my increased understanding of my tx, and after I tame down the elevator and aileron dual rates, pitch curve, and the throttle curve, I could finally get the bird stable enough to fly and my skills of flying improved drastically since then. That is something only a programmable tx can do for you. And to your point about CP and FP, actually they shouldn't be too different. The only difference that make people think FP is easier to fly is because most FP are FLYBARed, this is the feature that makes beginner find FLYBARLESS CP so hard to fly. For flybar helis, when you want to move the plane forward, you have to keep push the elevator down to make the nose pitch down to move forward. However, if you ever try the same thing on a flybarless heli, you will find that the bird keep accelerating. The difference comes of the computer on board the bird. Flybarless heli essentially is a fly-by-wire system, the micro computer on the main-board will interpret the signal from the pilot before sending out the control signal to the servos. So when you keep pressing the control down, the computer will interpret it as you want to accelerate. The correct way to do it is apply a little bit forward elevator, and immediately apply a little bit backward elevator. (sorry, my language is not good enough to describe it, but what I want to say is flying a flybar and a flybarless heli is very different) Anyway, I truly believe there are many ways to do it, but I do sincerely believe that once you fly a CP, you will never move back to a FP. You can start with V922, but I'm sure sooner or later you will find the inadequacy of it and inevitably have to spend some cash to upgrade. |
A poorly configured TX will be bad for a beginner. That is true. What I'm trying to highlight is the default TX for V922 works fine for me and many others. Maybe it's luck or magic, I don't know, but all I know is... I'm happy with it and my 3D friends are happy with it too.
I agree that different pilots may have different preferences, so one way is to know if the TX suits a person is for him to somehow try the V922 before buying. If the TX feels good, then go ahead to buy it. ![]() Have you tried the V922? I suspect you may find the stock settings ok. ![]() Quote:
Singapore, Singapore
Joined Dec 2007
In reponse to pshkong, I must emphasise that my first entry to CP was a Solo Pro 100 with the J6 programmable transmitter. I too tried fiddling with the throttle and pitch curves, and also went into the dual rates and stuff. Even after much tweaking, I still found it difficult to fly.
I understand the marvels of having a programmable transmitter, but I guess perhaps the most important part of CP is to unlearn the way you fly a FP. That was one of the hardest challenge for me. I can fly FP in very constrained spaces and do lots of trick moves with ease, but with a CP I become like a novice again. So the point is the v922 still is a good choice for an introduction to CP. I wish I had this before I got the Solo Pro 100. Anyway, the Walkera Super CP is probably another good option with its promising affordable price and likely good performance. I'm getting that if the reviews are favorable. |
Joined Sep 2012
a programmable tx is not as important as somebody could believe... on the contrary: people slow down their learning-progress by changing the tx-settings everey five minutes... most non-programmable tx have the best beginner-settings allready installed - of course there are exeptional cases...
it could be the wrong way round trying to boost ones flying skills to meddle with the technology, usually it is far better to improve the flying skills step by step ... Quote:
you have to differ between guided- and non-guided flybars. the guided ones have paddels on the outer side, the non guided have weights. most of fp-helis (as the koax-helis, the v911, aso ... ) have non-guided flybars - this means a mechanical self-horizontal-levelling effect by the weights. the guided paddel-flybars keep the heli mechanical in that position it was tiltet by the pilot (the function of a guided flybar is realy complex...) this makes the difference for the pilot ... finally the flybarless-systems regulate that in an electronical way (two gyros to analyse the aileron and nick-position...). there is not much difference between fbl-helis and good adjusted flybared paddel-helis macem |
Joined Feb 2007
I'm on the fence between this one and the Super CP as my second CP (have nano cpx with dx4e). Waiting to see some better prices. Does this TX not have dual rates? That may be somewhat of an issue if attempting to fly inside house. Does the inverted control mode work very well? I'm to the point flipping is pretty easy (outside), but the backwards controls is my struggle right now when attempting to fly inverted. Just wondering if this special mode could be flipped into and out of fast enough to use it to help learn the correct inverted controls, or if it would just make it more confusing.
| Thread Tools | |
| Discussion HiSKY FBL100/ WLToys V922 Preliminary findings thread | jameschen072 | Micro Helis | 175 | May 20, 2013 07:26 AM |
| Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) | jameschen072 | Micro Helis | 359 | May 19, 2013 02:23 PM |
| Mini-Review WLtoys V929 Beetle Ladybird Quad Mini-Review | FyreSG | Mini Multirotors | 3417 | May 19, 2013 10:01 AM |
| Discussion Walkera Mini CP 3D Flybarless RC Helicopter | glybytony | Mini Helis | 3 | Oct 12, 2012 11:01 PM |
