Espritmodel.com Heli Air
Old Jan 09, 2013, 11:13 PM
Spain
Joined Aug 2010
Originally Posted by roadglidec View Post
sorry about the phrasing I am not a very good typist, but I and my DX6I are waiting for the Ht-8 and will report my findings Steve
Hope you enjoy it soon.
Pedro
pedrojlucas is offline Find More Posts by pedrojlucas
Old Jan 09, 2013, 11:38 PM
Spain
Joined Aug 2010
Trying to figure out tail drift with the DX6i/HT-8 setup
Hi all,
I have had some time to test the parameters previously posted in order to take away that tail drift to the right (nose to the left) I have detected when flying my FBL100 binded to HT-8/DX6i.
As I stated in the previous post, I haven't detected any tail drift in the Flysky 9x, Walkera 2801Pro and Hisky X-6S transmitters (I re-checked it again later). So this tail drift has to do with the DX6i/HT-8 setup and it seems there is no mechanical problem in the helicopter.
Then the bad news:
After trying differente values gyro settings (50%, 75%, 95%), it seems that there is no influence in the flying characteristics.
I also changed the swashmix values and no result at all.
I tried also changing travel adjust of the throttle and rudder channels, rising to 120% on both ends (high and low for throttle, left and right for rudder) and lowering to 80% on both ends. Because I have the feeling that the throttle that gets the receiver is not as high as it should be, I feel the throttle much more responsive and powerful when flying with Flysky 9x for example. Maybe someone else can confirm this.
Then I tried the more obvious but what I was trying to avoid from the beginning (it's not a very smart solution, I think), I put some sub-trim (15 to the right) and it solve the issue, so the helicopter is more flyable.
The good news about this:
The sub-trim solution is not good at all, at least for me. But, at the moment, it's something you can try to keep flying with this configuration.
And the good news are that it seems that every time the helicopter/transmitter are binded the sub-trim value persists, is not reset as it's usual with other FBL systems (like Walkera for example). I have checked a couple of times and I haven't had to put more sub-trim in every power-on, so there is no need to reset manually the sub-trim value to 0 before the transmitter is switched off.
I'm sorry not to give a better solution at the moment, but I'll try to figure out something again later. At the moment I'm going to enjoy flying my micros for the rest of the week .
Pedro
Old Jan 10, 2013, 01:11 AM
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
Pedro
As this system is not like a walkera or other manufacturer, i.e. others FBL systems must not use CCPM mixing on the transmitter side as the Hisky does.
Since CCPM mixing is used, maybe playing with the revo mix between main and tail motor could do the trick for the drift.
This doesn't apply if the gyro of the FBL 100 is a HH one, in that case you are back at square one.
I say this because on my Wk-2801 I have ATS MIX (revomix) for the CP helos as a setting that could be used.
Some of the earlier Walkera models didn't had HH gyro.
Take this with a grain of salt anyway.
blackmoon is online now Find More Posts by blackmoon
Old Jan 10, 2013, 03:17 AM
KDS450QS(ZYX4),V922,V959
FyreSG's Avatar
Singapore
Joined Apr 2012
HiSKY released a "new" version of the "linear servo board" (I hope I got that right) in July 2012:
http://5imx.3vwed.com/bbs/forum.php?...ead&tid=658683
I'm not exactly sure what is so special about this new version, and did our V922 came with the new version. Can anyone shed some light on this? If our V922 does not have this new version board, should we get them?
FyreSG is offline Find More Posts by FyreSG
Old Jan 10, 2013, 08:09 AM
FyreSG's Avatar
Singapore
Joined Apr 2012
If your transmitter does not bind...
Perhaps the throttle stick is not calibrated correctly. Check out MyRCMart's V922 transmitter calibration video:
WL Toys V922 Radio Calibration Issue & Fix - MyRcMart.com (2 min 32 sec)
Old Jan 10, 2013, 09:32 AM
Spain
Joined Aug 2010
Thanks blackmoon for the tip about revo mix. I'll take a look at it as soon as I get the chance.
Pedro
Old Jan 10, 2013, 03:07 PM
matrixFLYER's Avatar
Italy
Joined Nov 2011
I would like to understand one think.
With HT8 HiSky module can't you set your preferred dual rate and expo? Or you can?
Can it bind V911 too?
Thanks.
matrixFLYER is online now Find More Posts by matrixFLYER
Old Jan 10, 2013, 03:37 PM
Spain
Joined Aug 2010
Thanks.
Hi,
HT-8 is the module manufactured by Hisky to make compatible the Hisky protocol (named FHSS, the same used by WLToys in the V922) with "officially" Futaba, JR and Walkera transmitters. Some of us have successfully tried to get our Spektrum DX6i and Turnigy/Flysky 9x transmitter working with that module.
Once you get working the programmable transmitter with the HT-8 module you can tune throttle and pitch curves, D/R, Expo, and whatever you need to improve the performance and joy of your flights.
The really important thing that you need to set and you can't change is the type of swashplate that is fixed to 120ºC and the ccpm mixing in the transmitter that is needed for the fbl controller to work properly.
The protocol used by WLToys in the V911 is different. That is compatible with the Flysky/Turnigy 9x protocol.
Hope this helps to clarify your doubts.
Pedro
Old Jan 10, 2013, 09:02 PM
FyreSG's Avatar
Singapore
Joined Apr 2012
I've found the instructions for using HT8 with WFly 9-Channel transmitter:
http://5imx.3vwed.com/bbs/forum.php?...ead&tid=718900
I don't know what's the WFly transmitter about, or is it similar to 9X. But I thought the configs may be useful as a reference to get HT8 working on other transmitters.
Old Jan 11, 2013, 02:36 PM
Italy
Joined Nov 2011
Hi,
Pedro
Perfect. I don't understand why in the ht8 instructions are written pitch curve and other settings for futaba and jr radio. I thought you have to match those settings to use the module.
There is a list of the parts of v922 that does fit the mcpx?
Old Jan 11, 2013, 03:00 PM
Italy, Lazio, Rome
Joined Jun 2012
Here you can find some info
http://www.rcgroups.com/forums/showthread.php?t=1804818
ercapoccia is offline Find More Posts by ercapoccia
Old Jan 11, 2013, 11:28 PM
Futaba 9CRAPTOR 90V911V922
SMEGS888's Avatar
United States, CA, Hacienda Heights
Joined Dec 2012
I guys can you pls help me out. I just replaced a new tail boom. The prolbem im having is when i power up.. The whole head moves to the right and helo blades hit the right. I dont know whats wrong.
SMEGS888 is offline Find More Posts by SMEGS888
Old Jan 11, 2013, 11:34 PM
FyreSG's Avatar
Singapore
Joined Apr 2012
Is the tail motor at the correct side? Is the tail blade facing the correct side?
Old Jan 11, 2013, 11:37 PM
SMEGS888's Avatar
Joined Dec 2012
Yes they are. When going to half stick I can see the head tilt to the right.
Old Jan 12, 2013, 02:40 PM
SMEGS888's Avatar
Joined Dec 2012
Yea, checked it now need another tail boom. Man I gotta get solid 2mm not v911 tail booms that are hollowed.
Mini-Review WLtoys V929 Beetle Ladybird Quad Mini-Review FyreSG Mini Multirotors 3465 Jun 16, 2013 11:43 PM
Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) jameschen072 Micro Helis 383 Jun 13, 2013 09:28 PM
Discussion HiSKY FBL100/ WLToys V922 Preliminary findings thread jameschen072 Micro Helis 175 May 20, 2013 07:26 AM
Discussion Walkera Mini CP 3D Flybarless RC Helicopter glybytony Mini Helis 3 Oct 12, 2012 11:01 PM
