It could be good as well. The trick is to pick a suitable expo, not too much until the sensitivity are the stick center is "not observable" - that is an extreme expo value. The issue some beginners face is they are not used to small stick movements. When the helicopter is drifting left, they apply too much right counter stick movement, causing the heli to fly right instead. A suitable expo will fix this.
I started learning with some expo (I couldn't hover without it!) then gradually reduced expo, then now, it's 0.
Singapore
Joined Dec 2012
Swash plate leveling for FBL CP heli
Ok, I did not buy the swash plate leveling tool after reading both your replies. (it was in my shopping cart) I notice the main gear of V911 which I bought as spare can be used for leveling the MCPX's swash plate. This gear has a 3mm internal diameter which allow the main shaft of MCPX to fit in nicely without any free play, it can than lowered and place near the three balls of the swash plate to check for leveling, the push rods were then adjusted accordingly for all three balls of the swash plate to touch the surface of the drive gear, it does provide good visual alignment check as macem suggested. This method may be as close as using the single purpose "swash plate level tool", I may be able to use this method for the V922 if I decided to add one more micro FBL CP. Please correct me if I am wrong. Thank you very much. |
Good job. That's the same method I use to level a friend's mCPX late one night. I used a v911 main gear. I also cut off some unnecessary parts of the gear so that it's easier to fit at the antirotation guide.
It works perfectly so just wanted to put that out there to validate what you shared. Thanks for sharing and the easy to understand photo. Newbies should be able to replicate it just fine. |
Latest blog entry: Syma S105 Battery Mod
Singapore
Joined Dec 2012
Thanks a lot to Daryoon for sharing. I did not cut off any part of the gear, I push the anti-rotation guide slightly for it to enter the hollow section of the gear, so that this gear is still usable for the V911. Cheers. |
LOL. No. Lonepilot. Your method is perfect. If you can save the gear, then even better. My friend had a aftermarket frame and the gear couldn't slip over it as is. That's why I had to cut it.
But it was a spare gear and a cheap part.
Singapore
Joined Dec 2012
Hi, FyreSG, I wish that I can progress fast and graduate to be a 6CH FBL CP heli pilot like you ..
![]() I always bring both the MCPX and V911 for flying. When on lookers see me keep crashing my MCPX, I pull out the V911 to fly around to show them I "actually" can "FLY" .....or, I change over to flying V911 to cool down myself when I keep crashing the MCPX .... (not to cool down motor of MCPX as it is crashing instead of flying)I will carry V922, V911 and MCPX out for flying after I purchase the V922
Singapore
Joined Dec 2012
I need to buy a drink for those who did stop me from buying the leveling tool in time .... ![]() Thanks again for all your willingness to share. |
Spain
Joined Aug 2010
I'm glad to help you with the configuration of your HT-8 and your transmitters. One question: Are you expiriencing tail drift with you DX6i tx when flying the FBL100? I guess it has to do with the mixing in the tx, but I haven't had spare time to experiment. Pedro. |
Joined Jan 2012
[QUOTE=pedrojlucas;23750698]Hi KKDDMM,
I'm glad to help you with the configuration of your HT-8 and your transmitters. One question: Are you expiriencing tail drift with you DX6i tx when flying the FBL100? I guess it has to do with the mixing in the tx, but I haven't had spare time to experiment. Pedro many thanks on your findings with the compatibility to the DX6I , I have ordered the HT-8 and as soon as I recieve it I will Start loking into the possible tail wag steve
| Thread Tools | |
| Mini-Review WLtoys V929 Beetle Ladybird Quad Mini-Review | FyreSG | Mini Multirotors | 3465 | Jun 16, 2013 11:43 PM |
| Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) | jameschen072 | Micro Helis | 383 | Jun 13, 2013 09:28 PM |
| Discussion HiSKY FBL100/ WLToys V922 Preliminary findings thread | jameschen072 | Micro Helis | 175 | May 20, 2013 07:26 AM |
| Discussion Walkera Mini CP 3D Flybarless RC Helicopter | glybytony | Mini Helis | 3 | Oct 12, 2012 11:01 PM |
