Trial of a Kevlar hinge.The hinge itself(outline of the braid in green) works fine,but as I expected before I started,I had to bevel the balsa sheet to allow movement.This defeats the object of preserving a smooth under surface,so I think either acrylic or over/ under tape hinges(another trial,never tried these either)will be the way to go..
I also need to offset the balsa to give enough width to cut the top bevel. |
Digging a trench.:-)
I needed to cut away the top skin and foam to insert a 10mm section to make the hinge line.This really needs to be square to the lower surface; after some head scratching as to how I could achieve a square and accurate cut,the piece of glazing pine caught my eye.Practically the correct angle!A bit nerve racking cutting into the wing,but I could feel the epoxy on the lower skin,so it went ok.A nice sharp wood chisel makes short work of cleaning the groove out. I need a nice fit here,too tight will risk distorting the wing....so far so good. |
| Thread Tools | |
| Discussion "Plank" wings and pendulum stability | derp express | Modeling Science | 30 | Mar 02, 2013 07:45 PM |
| Question Wing tips on a plank | Stupot46 | Slope | 3 | Feb 16, 2013 12:10 PM |
| For Sale Panasonic Lumix LX7 Digital Camera, 10.1MP, Black, Brand New in Box | PerlAddict | Non R/C Items (FS/W) | 3 | Feb 05, 2013 03:50 PM |
| Discussion Straightening a warped balsa plank/wing? | C₄H₁₀ | The Builders Workshop | 8 | Jan 07, 2013 12:26 AM |
