Dec 26, 2012, 10:48 AM
McHenry, IL
Joined Mar 2003
Tools...
I mentioned tools in the thread title, so here's a couple more I can't do without in my shop...
The first one I want to talk about is called a Bench Block... It's made from cast iron, the top is approximately 3/4" thick and ground flat(mine needs a new surface on it), it's quite heavy for it's size, it also has various sized holes bored through the top surface and a "V" groove across the center of the top, you can use it as a mini anvil, for clamping irregular shaped workpieces, etc... More uses than I could ever list, jewelers use them, machinists use them... You may be able to get one at HF, any machinist supply house or jewelery makers supply shop...
I had mine out to help press the gears on to the Long Umbrella Gear, so, I figured it's a good time to show it in use...
Another thing I could not get by without in the shop is a decent set of small files, I'd recommend round, triangle and flat profiles at a minimum...
A couple photos...
Ken
