Old Jan 04, 2013, 02:47 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Originally Posted by RyanNX211 View Post
why such a long aerial ?
Wow, you've got a good eye. Yes it is drawn longer than 39", which I believe is the norm for 72MHz.
I just drew it long so I could see it in the animation and to prove to myself that it would be well out of the way for bungee launching. The actual trailing wire may be just a couple of inches.
@Cap_n, the Rhino Hide is 1/64" thick and it does seem like wood veneer, but it is obviously a pressed wood product.. There does not seems to be a grain. So it is wood "mush" pressed into a flat shape. Unlike veneer, it has strength in all directions, better for wing skins. It has a slight press board sort of texture that can be sanded smooth. The photo was shot with a spot light at a very low angle to highlight the texture. So far, I'm still very impressed. It is stiff enough to bridge over minor blemishes in the foam. For a 50" wing, it may be all the structure you need. I haven't decided yet. My servo holes will be on top, in the compression surface of the skin, so that's not good. I like strong wings, so I might add reinforcement in the foam at the servo holes.
Kent
Knoll53 is offline Find More Posts by Knoll53
Question Foil for 60" DS plank wooden wonder taurineman Dynamic Soaring 14 Oct 18, 2012 04:06 AM
Cool The Splinter DS - Brit Assult on the Plank DS Record Geo420 Dynamic Soaring 104 Nov 20, 2009 02:37 AM
Design ideas for an EPP Slope and DS Plank ifrichard Slope 7 Oct 27, 2003 08:46 AM
Help choosing Airfoil for 60" DS Plank occy Dynamic Soaring 5 Oct 20, 2003 02:02 AM
