Old Dec 26, 2012, 12:57 AM
iwlf is offline
Find More Posts by iwlf
iwlf's Avatar
United States, NC, Troy
Joined Dec 2008
Question
House of Balsa AT-6 Texan Glow to Electric
I have an older House of Balse airframe that I'd like to electrify. Wingspan is 44", wing area is 319 sq inches and the proposed (glow) weight was 2.5 to 3.0 pounds. Wing loading was 18 to 21 oz / sq foot.
Given the power of electric motors, I'm assuming there is a combination that will fly this airframe. Can you help by suggesting motor/battery/prop combinations to get me started?
It may be that balancing is a bigger issue, trying to get enough weight forward.
This was supposed to fly on a .19 to .25 glow engine.
Thanks for your help!
iwlf is offline Find More Posts by iwlf
Old Dec 27, 2012, 09:34 PM
viva_peru is offline
Find More Posts by viva_peru
Oakland township, Michigan
Joined Jun 2005
Hi,
If you go with a 3S battery, you will need a motor with a kv of about 900 such as a Hacker A30-10xl. This is probably a little too big for the plane. A Hacker A30-14L with a kv of about 800 would also work, but it would be better with a 4s battery. From the E-flite line, the Power 15 would also work.
Good luck,
Teo
viva_peru is offline Find More Posts by viva_peru
Old Dec 30, 2012, 04:24 PM
catspaw is offline
Find More Posts by catspaw
catspaw's Avatar
United States, WI, Stoughton
Joined May 2003
Tag for replies.
I built one of these from scratch back in the late 80's when MAN re-ran the construction article. Put a OS20 in it, IIRC. Since I was still a rookie flyer, I had my instructor try it.
It was kinda twitchy because it came out heavy. I tried to fly it myself, ONCE, with not-so-nice results. Wound up selling it.
The reason it came out so heavy, was that the plans built differed from the kit in that the turtledeck was made from shaped foam instead of balsa like the kit. I didn't like the roughness of the foam, so I coated it with a solution of epoxy and microballoons.had to balance that out with lead in the nose, so you can guess why it was so heavy...
So anyway, I still have the plans I built it from, so maybe I'll try it again someday?
catspaw is offline Find More Posts by catspaw
Old Jan 01, 2013, 10:57 AM
iwlf is offline
iwlf's Avatar
Joined Dec 2008
Originally Posted by viva_peru View Post
Hi,
Good luck,
Teo
Thanks! That'll get me started. It may be that it's a beast to fly, but will be a fun project, I think.
Old Jan 01, 2013, 12:49 PM
blvdbuzzard is offline
Find More Posts by blvdbuzzard
The high desert of Southern California
Joined Jul 2002
Well you could use a Tacon 15, 3s battery, 12X5 prop. Will give about 4 pounds of thrust
Motor
http://www.hobbypartz.com/96m602-big...826-950kv.html
ESC
http://www.hobbypartz.com/07e06-proton-60a.html
battery
http://www.hobbypartz.com/98p-25c-2200-3s1p.html
http://www.hobbypartz.com/98p-25c-3300-3s1p.html
If you upped the motor to a Tacon 25, and a 12X8 3 bladed prop, you would get another pound of thrust.
Here is the online calc program I used.
http://www.s4a.ch/eflight/motorcalc_e.htm
Buzz
blvdbuzzard is offline Find More Posts by blvdbuzzard
Old Jan 04, 2013, 04:08 PM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
I had one of these and flew it on an HB;.25 many years ago... A few things come to mind..
1) Make sure that you have lots of washout! Without enough washout- this airplane was a tip stalling and ground smacking nightmare.
2) The HB-25 was too much power- most of what happened at the upper ranges was that there was more racket, but not a lot more speed.
3) I would NOT use a larger than glow prop as has been suggested earlier. Thrust is an irrelevant consideration here. I recall running an 8 x 6 prop. The gear is pretty short, so you can't go much larger.
4) I'd look for about a 350-400 watt setup on this size prop- this should emulate the glow engine pretty well. Make sure that you have plenty of battery - i.e. something like a 3 cell 3000-3700 size pack. You want at least 4 minutes at full bore- maybe 6, so a lot of typical electric setups won't work all that well (i.e. 20 C).
5) This airplane comes down in a hurry.
6) Do NOT use the stupid aileron cable setup in the kit- just go to separate aileron servos. That was another PITA and the ailerons never centered properly.
HTH
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old Jan 05, 2013, 02:50 PM
catspaw is offline
catspaw's Avatar
Joined May 2003
Playing around with the ecalc.ch power calculator, and various motor/prop/battery combinations, I couldn't get anything that didn't look ridicilous in way or another. I know this plane is limited to a small prop, but trying to get some combination of motor, battery, and thrust that was meaningful w/o overloading some component or another was very difficult.
Old Jan 06, 2013, 07:11 PM
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
It's not hard. Jeti Phasor 15-4, 8 x 6 prop or 8.5 x 5 prop, 3s 2500-3000 mAH pack and you'll have a flyable airplane.
Sam
Old Jan 07, 2013, 11:39 PM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
Mine flew great on an Uberall Nippy Black 2510/114 and a 3s 1500 Kokam. I did make quite a few lightening holes in all the sheet balsa and plywood though.
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Jan 26, 2013, 08:58 AM
iwlf is offline
iwlf's Avatar
Joined Dec 2008
Thanks for the suggestions, guys. I have it out this morning and am going to do some weight reduction (the airframe, that is, not mine!) and then get it back together.
Old Feb 24, 2013, 01:07 PM
Flying Beagle is offline
Find More Posts by Flying Beagle
...missing the PE Slope Rebels
Flying Beagle's Avatar
United States, MI, Manchester
Joined May 2004
My complete build thread: http://www.rcgroups.com/forums/showthread.php?t=382003
Wing span 44 in. ..................................Wing area 319 sq. in.
AUW: 26 3/8 oz .....................................Wing Loading: 12 oz./sq. ft.
Covering: Yellow Solite, Red Solite, Metallic Platinum Monokote
Motor: AXI 2808/24 ...................ESC: CC Phx 25...............Battery: ThunderPower 3S 2100
Rx: Electron 6 .......................Aileron Servo: HS-81 ..............Rudder & Elevator: HS-55ís
Flown: Jul-2005
Flying Beagle is offline Find More Posts by Flying Beagle
Sold AT-6 TEXAN by House of Balsa Kit W/Retracts $65.00 FREE SHIPPED!!! stevster Aircraft - Fuel - Airplanes (FS/W) 3 Dec 12, 2012 03:10 PM
Sold House of Balsa T-6 Texan Electric (Kit) gllucero Aircraft - Electric - Airplanes (FS/W) 0 Jun 14, 2012 12:36 PM
Sold House of Balsa T-6 Texan Dizzante Aircraft - Fuel - Airplanes (FS/W) 4 May 12, 2012 11:01 AM
Sold House of Balsa AT-6 Texan flyingj Aircraft - Electric - Airplanes (FS/W) 12 Jun 21, 2009 01:53 AM
For Sale House of Balsa AT-6 Texan - 15 fockewulf37 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 02, 2007 02:25 PM
