Old Dec 24, 2012, 05:30 PM
Daz393 is offline
Find More Posts by Daz393
Depron Daz
Daz393's Avatar
United Kingdom, England, Basingstoke
Joined Feb 2012
Question
Lazy retract?
I am suffering from a lazy electric retract that sometimes opens straight away, sometimes after several seconds, and sometimes never unless I cycle the gear switch once or twice. The other is 100% spot on all the time.
Without having to buy another, is there a way of fixing this?
Daz393 is offline Find More Posts by Daz393
Old Dec 24, 2012, 09:09 PM
Cougar429 is offline
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
Try removing it from the surrounding structure to see if it is a physical bind problem.
Other option is to try switching the Y-connector if used to tie both to a single channel and/or plug each separately into the gear channel to check function. If you have a bad extension or Y-cable perhaps the voltage to that retract is compromised.
Cougar429 is offline Find More Posts by Cougar429
Old Dec 25, 2012, 04:58 PM
Daz393 is offline
Depron Daz
Daz393's Avatar
Joined Feb 2012
Thanks for the advice, I'll check it out.
Old Dec 28, 2012, 07:33 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
My first task in trouble shooting a sticky retract is to loosen all the mounting screws. See if it frees up. If it does, then the retract rails are not true. I've sometimes rebeded them with washers but when its bad I'll lift up the retract and slop some thickened epoxy or JB weld in there, coat the retract rails with vaseline and screw the retract back down. Not tight, just snug.
Edwin
edwin1 is offline Find More Posts by edwin1
For Sale 48" Lazy Bee (LPU in Chilliwack BC, CANADA) drktkm Aircraft - Electric - Airplanes (FS/W) 3 Jul 24, 2012 03:13 AM
For Sale Lazy Bee Kit with Float Kit & misc. softlanding Aircraft - Electric - Airplanes (FS/W) 8 Apr 20, 2012 05:15 AM
Discussion Professors are overapid and lazy Jim Thomerson Life, The Universe, and Politics 21 Mar 28, 2012 05:30 PM
Wanted Lazy Bee, Lazy Cub, or Crazy Panda Bentrod Aircraft - Fuel - Airplanes (FS/W) 5 Sep 19, 2010 11:13 AM
Wanted still looking foam lazy bee or lazy e bee thechannelmast Aircraft - Electric - Airplanes (FS/W) 0 Jan 22, 2008 07:05 PM
