Old Dec 24, 2012, 04:14 PM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
Open Flight Stabilizer
post last updated on 20150201
please regularly check the V3 documentation file for current build status. JohnRB maintains an Open FlightStab News section with updates.
JohnRB Update 20141226: Updated OFS Firmware
Open FlightStab firmware has been updated to add support for Graupner and Multiplex SRXL. The firmware changes made by user ingo_s have been merged into the project. The Builds include Hex files for many of the different boards that OFS supports. Only the 2 RX3S V2 SRXL versions have been test by ingo_s.
If you wish to use a version other than those tested, do a very through ground test before flight.
The documentation has also been updated.
Source and Hex files link.
Documentation Link.
Original Post
starting this thread to discuss the development of an opensource flight stabilizer. i started this project after looking at various flight stabilizers and also getting the HK RX3S. i didn't like the performance of the V1 device (non-linear VR gains, no remote AUX gain control, stabilizer fights me on aerobatic manoeuvres). so, the goal is to hack the RX3S V1 and V2 and replace them with better firmware.
JohnRB and i currently maintain the master branch for the flightstab firmware.
ckleanth has also helped very much with documentation.
LazyZero has a flashing tool that simplifies flashing devices http://lazyzero.de/en/modellbau/kkmulticopterflashtool
there is also a nice blog of a walkthrough with pictures on how to program the RX3S devices and a flight report from mikejr83 atClive Hall has also written a nice doc describing the HKFactory and the OpenFlightStab versions at http://www.cbhmodels.co.uk/rx3s.htm
and thanks to many others in this thread that have suggested great ideas along the way.
standard disclaimers apply. please review and use it at your own risk. i'm not responsible if you bricked your plane, lost your RX3S, or both
noobee is offline Find More Posts by noobee
Old Dec 24, 2012, 04:15 PM
noobee is offline
Joined Dec 2006
RX3S V1 connections:
RX3S V2 connections:
NanoWii connections:
Old Dec 24, 2012, 06:13 PM
lvale is offline
Find More Posts by lvale
Portugal, Lisboa, Cascais
Joined Sep 2012
following
lvale is offline Find More Posts by lvale
Old Dec 24, 2012, 11:30 PM
Radio.Active is offline
Find More Posts by Radio.Active
Closed Account
Joined Aug 2011
Radio.Active is offline Find More Posts by Radio.Active
Old Dec 25, 2012, 07:11 AM
Yashiro is offline
Find More Posts by Yashiro
Yashiro's Avatar
chiba, Japan
Joined May 2004
I want to support the flaperon:-)
Yashiro is offline Find More Posts by Yashiro
Old Dec 25, 2012, 07:27 AM
ckleanth is offline
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
as long as you have 3 servo inputs this wont happen mate
ckleanth is offline Find More Posts by ckleanth
Old Dec 25, 2012, 07:29 AM
noobee is offline
Joined Dec 2006
Originally Posted by Radio.Active View Post
Well I have 2 of them that I don't like and I'm prepared to Zap them.
... Alan
let us know if you try to update the firmware? i've documented the steps that i took to flash mine. hope the notes are sufficiently detailed. i'll revise/update them as needed.
ah, ok then we need another AIL-IN channel.
interestingly, this is probably much easier to do on the RX3S V1 than on the V2, since the ISP connector pins are exposed and can be repurposed for RX use. i'll update the first post to maintain a feature-request list.
Old Dec 25, 2012, 07:40 AM
ckleanth is offline
ckleanth's Avatar
Joined Mar 2011
bugger I sold off all my v1 modulles
argh!!
Old Dec 25, 2012, 07:54 AM
noobee is offline
Joined Dec 2006
argh!!
with the v2, you probably need to mod the board a little, to run a wire from a dip switch (just too many dip switches on the v2).
on the upside, the v2 has all the IO needed for a quadcopter (4 in and 4 out)
Old Dec 25, 2012, 11:54 AM
ckleanth is offline
ckleanth's Avatar
Joined Mar 2011
just a few comments
with the v1 you have three dip switches, i havent checked your code but if you use two dip switches for your check loop then you can have six combinations for operation modes.
clever idea the reversing function using the gain knob but how sensitive is the gain adjustment because of the available knob rotation. have you changed the max value?
with the v2 yes a lot more dip switches (I dont have a module yet but I think its five)
again if you use two dip switches for your check loop then you can have ten combinations for operation modes (if you want).
for normal mode the aux woud have the off/on function
for flaperons you can use the aux as input so you wont have the off function without mods
for quadcopter 4 in 4 out as you said but so you wont have the off function without mods
vwing delta etc requires mixing
btw do you have enough memory on the cpu ?
Old Dec 25, 2012, 01:02 PM
noobee is offline
Joined Dec 2006
with 2 dip switches, i think there would be 4 combinations. assuming "1" is in the rev position, the settings right now are:
(rud, ele)
(0, 0) NORMAL
(0, 1) VTAIL
(1, 0) DELTA
(1, 1) DELTA
i could use (1, 1) for NORMAL-FLAPPERON, which would reassign the pinouts to include another RX AIL2-IN. @yashiro, do you use flapperon in normal mode (eg. 3d planes) or vtail mode (eg. gliders)?
if you want flapperon with the v1 device, you can use two ISP pins for AUX-IN and AIL2-IN. if you want flapperon with the v2 device, you probably need to solder a wire from one of the dip switches for AIL2-IN (since V2 already has a AUX-IN pin).
the VR knobs are quite linear now compared to the RX3S V1 implementation. i heard the V2s are better. HK must have fix the errors due to integer division.
right now, memory use for the RX3S is around 9400 bytes (out of 14000+), so there's still plenty of space. i could also use simpler implementations of the i2c library and itg3205 (gyro on the RX3S) to reclaim space if need (not at this time).
just a few comments
Old Dec 25, 2012, 03:36 PM
ckleanth is offline
ckleanth's Avatar
Joined Mar 2011
with 2 dip switches, i think there would be 4 combinations. assuming "...
made sense when I thought it, doesent make much sense now..
.if you want flapperon with the v2 device, you probably need to solder a wire from one of the dip switches for AIL2-IN (since V2 already has a AUX-IN pin).
why you need to do this?
Old Dec 25, 2012, 08:05 PM
Yashiro is offline
Yashiro's Avatar
chiba, Japan
Joined May 2004
hi,
It considers using by glider.
A flaperon is important.
The priority of V-tail is low.
Old Dec 25, 2012, 10:54 PM
noobee is offline
Joined Dec 2006
the v2 has 4 input (ail, ele, rud, aux) and 4 output (ailL, ele, rud, ailR) pins.
to support flapperons, you would need another input (ail2) pin. this extra input would probably need to come from one of the 6 dip switches.
Old Dec 25, 2012, 11:01 PM
noobee is offline
Joined Dec 2006
hi,
ok, i'll set
Code:
(rud, ele)
(0, 0) NORMAL
(0, 1) VTAIL
(1, 0) DELTA
(1, 1) FLAPPERON (normal tail)
flapperon mode would probably remap the pins to use 2 pins from the isp connector (miso and mosi), one for AUX-IN and one for AIL2-IN. AIL-R will then keep its original function as AIL-R OUT.
Sold Flight Stabilization System with Programing Card Woody_99 Aircraft - Electric - Helis (FS/W) 1 Mar 23, 2012 12:50 PM
Sold Flymentor Flight Stabilization with Field Programmer Woody_99 Aircraft - General - Radio Equipment (FS/W) 0 Mar 17, 2012 07:43 AM
Sold Totally Tricked out 400 size with flight stabilization installed, BNF Woody_99 Aircraft - Electric - Helis (FS/W) 2 Mar 12, 2012 06:56 AM
Wanted FY-30A Flight Stabilization System Casey_S FPV Equipment (FS/W) 0 Mar 05, 2012 02:40 PM
