Old Dec 16, 2003, 02:36 PM
brianchristie is offline
Find More Posts by brianchristie
Should it be doing that?
Riverside, CA
Joined Mar 2001
Help!
Brushless ESC's and motor compatibility?
Hi all.
I have a TMM 40e-3ph brushless, sensorless controller. Will is work with a Mega 22 / 20 / 2 or any other brushless motor?
(it's a 40A rating)
I've been using it w/ an AXI outrunner-type motor.
Thanks.
BC
brianchristie is offline Find More Posts by brianchristie
Old Dec 16, 2003, 02:38 PM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Yup, just watch your amp limit.
(as long as it's a non-sensored motor)
William A is offline Find More Posts by William A
Old Dec 16, 2003, 02:54 PM
Riverside, CA
Joined Mar 2001
Thanks!
Thanks a bunch for the quick response!
I kinda figured I could...but since this is my first brushless controller, I wanted to ask.
I also assume that, as w/ my AXI, reversing the two outer motor connections I can reverse the direction of the motor?
Thanks again.
BC
Old Dec 16, 2003, 03:05 PM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Yes, again correct.
Noticed you mentioned the 22/20/2, also read they were in short supply in another thread.
Where all they all going ?
Old Dec 16, 2003, 03:36 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Re: Thanks!
You can swap any two leads to reverse rotation, not just the outer pair.
Haldor is offline Find More Posts by Haldor
Old Dec 16, 2003, 03:43 PM
Riverside, CA
Joined Mar 2001
Noticed you mentioned the 22/20/2, also read they were in short supply in another thread. Where all they all going ?
The are going into Robbe Eollos! :-)
Sold Brushless Esc's and Motor- TowerPro and Great Planes Etonic Aircraft - Electric - Power Systems (FS/W) 4 Apr 13, 2006 07:13 AM
Garage sell, brushless esc's, gyro, motor wing-hater Aircraft - Electric - Helis (FS/W) 2 Apr 10, 2005 09:19 PM
brushless esc's, brushless motor, gyro wing-hater Aircraft - Electric - Airplanes (FS/W) 4 Apr 10, 2005 07:40 PM
Kontronik brushless ESC's lumins Electric Plane Talk 3 Jun 12, 2001 12:07 AM
Kontronik brushless ESC's lumins Power Systems 4 Jun 11, 2001 12:12 AM
