This thread is privately moderated by MTHead4u, who may elect to delete unwanted replies.
Old Dec 23, 2012, 11:01 PM
MTHead4u is offline
Find More Posts by MTHead4u
Having fun again!!
MTHead4u's Avatar
United States, AZ, Queen Creek
Joined Aug 2012
DiaLFonZo-Copter - FPV SpyderQuad
Build up of my FPV SpyderQuad (V1)
I purchased this through Eric (DiaLFonzo) as a flat (G10) parts kit only, no hardware, standoffs or other parts. I requested a 2nd lower plate to mount the power distribution board due to the confined space within the upper and lower frame plates.
Due to this being a first run on his new design there were a few changes that he was in the middle of making before releasing it but I finally pressured him enough to make me one before the changes.
Build specs:
SpyderQuad (version 1)
Naza/GPS FC
T-Motor 2216-11 900kv
DJI 30A OPTO ESC
Voltair PDB
GemFan CF 10x4.5 Props
FrSky V8R7-II Rx
225mm booms = 508mm front M/M, 355mm rear M/M, 381mm FM/RM
First off, huge props to Eric, the manufactured parts where flawless and all packaged individually to prevent shipping damage.
Seeing that the Naza would just barely fit into the frame running the .75" boom blocks from the original design I opted to buy some 1" tall boom blocks but didn't want to run through bolts and nuts. I decided to build off Eric's boom block design using my 1" blocks. I reamed the lower block holes to .1875" and pressed the .75" hex spacers in the blocks, then reamed the upper block to .201" to allow it to hand fit over the hex spacers, this holds the booms in place without screws in the top plate so you can work on the interior.
On the motor side I ordered Eric's .75" tall blocks so the landing legs would still lock in as designed.
Re-skinned 30A OPTO ESC
PDB installation
Cramming the ESC's in the frame.. One of the changes to the released design will be ESC mounting pads on the motor plates, this help keep them cool and allows for more options with ESCs.
I got on a roll and forgot to take more pictures of the inside, it was going together so smoothly and I could wait to see it completed.
As of now, I'm still flying on the stock Naza setting, she hovers fantastically and is quite responsive. As I get more flight time on her I'll add the FPV equipment and readjust setting if necessary.
You can see his whole thread here.
http://www.rcgroups.com/forums/showthread.php?t=1738262
MTHead4u is offline Find More Posts by MTHead4u
Old Dec 24, 2012, 03:50 AM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
Never had much luck getting the motors exactly vertical, with the round rods. They would slip in flight or the tiniest deviation would throw off the balance.
Jack Crossfire is offline Find More Posts by Jack Crossfire
Discussion DiaLFonZo-Copter - DJI SpyderQuad Upgrade Dialfonzo Multirotor Talk 502 Aug 05, 2014 08:53 AM
Discussion DiaLFonZo-Copter - FPV SpyderQuad Dialfonzo Multirotor Talk 220 Jun 30, 2014 07:50 PM
For Sale DiaLFonZo-Copter - DJI SpyderQuad Upgrade - USED Dialfonzo Aircraft - Electric - Multirotor (FS/W) 4 Nov 26, 2012 06:48 PM
Discussion FPV plate Soft mounted - Luis & DiaLFonZo-Copter Dialfonzo Multirotor Talk 5 Jan 05, 2012 12:04 PM
