Old Dec 31, 2012, 04:39 AM
Brandano is offline
Find More Posts by Brandano
You can deduce sideslip with gyroscopes and accelerometers only if you presume the air to be in a steady state (and it takes a fair deal of computing power). A sideways gust will cause a large change in yaw without affecting much accelerometers or gyroscopes. That's why full sized planes still have several air sensors to integrate the data obtained by the inertial navigation system.
Brandano is offline Find More Posts by Brandano
Old Jan 02, 2013, 08:55 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Originally Posted by Sparky Paul View Post
It taxis... will it take off?
Interesting idea.My money's on it working.
Kent and myself are working on split fins as a way to knock speed off a plank for landing.(Nurfluegal forum)
Also in the show your Nurfluegal thread there's a vid/ pic of a Horten wing with a canard.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Jan 02, 2013, 09:37 AM
Brandano is offline
I think it will work with a couple of "but"s thrown in. It might make the wing prone to tumble. and I am not sure how well that fin will interact with the swept wing.
Old Jan 02, 2013, 11:27 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
It started out as a simple way to make drag rudders for a wing, and it just grew.
I noticed in the NASA stuff on the Shuttle they mention the speed brake and pitch control of the split rudder but they concentrate on the speed brake function, with nothing more on using it for pitch.
It is a god-awful thing to paste on a smooth wing.
I'm going for a wheeled takeoff, because the instant response needed for a hand launch could be in the wrong direction, or the thing could just be unflyable. The takeoff run would permit observing what is going on and maybe correct for that.
It's too cold outside to do anything more than bring in the paper during the day... Grumpp....
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jan 02, 2013, 11:46 AM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Real airplanes pitch up to slow down
nmasters is offline Find More Posts by nmasters
Old Jan 02, 2013, 11:51 AM
Brandano is offline
Big composited delta wing with leading edge root extensions. The brake probably becomes less effective as the AOA increases (its angle to the airflow decreases, and get blanketed by the wing and fuselage wake), ending up in a stable configuration where the wing is actually braking the plane. It also helps using the trailing edge surfaces as flaps. After all, it's not meant to go around, so I don't think there's a situation where you'd suddenly close the airbrake.
Old Jan 02, 2013, 12:14 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
I was there when Columbia became the first spaceship to land on Earth. It resembled what would happen were the world's largest tool box to be dropped from 50,000 feet, but it came down faster! :0
The effect of the brake would be pull the nose up and slightly decrease the rate of plummet. And stretch the plummet a bit if it was going to be short.
Actually climbing that thing would require adding power, which it had none of.
I'm hoping this apparatus will have some of the characteristics of an elevator, but less powerful, with any number of unexpected (pernicious) side effects.
Old Jan 02, 2013, 12:44 PM
Brandano is offline
I expect severe pitchup even with the brake closed
Old Jan 02, 2013, 01:12 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
I've adjusted the ailerons down from the elevon trimmed position, so that any pitchup will be caused by the vertical, and expect to have the elevator trim set all the way down.. almost closed, for the takeoff run, leaving some down "elevator" just in case it might need it.
Old Jan 02, 2013, 02:31 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Braving the arctic wind, on the street outside with the ailerons down as mentioned, it showed no inclination to take off.
Pulled the ailerons up 4 turns on the pushrods.. downhill into the wind, it shows promise.. steers nicely, but not much of any indication that it will take off with full "elevator".
I need a longer less restricted area, and to pull up the ailerons more.....
Old Jan 02, 2013, 02:55 PM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
You need a pretty good AOA to get free of the ground
The tiny indoor stuf I posted last year showed same thing .
set the gear such that you have a good AOA - it's a cut n try (what! no calculations!)
richard hanson is online now Find More Posts by richard hanson
Old Jan 02, 2013, 06:51 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Going into the ridiculous part of the state of the art, it's kinda difficult to determine how to work up to a workable solution, or the usual miserable failure.
I even contemplated trying the ZAGI as it is intended, with elevons, with the giant vertical there but not active just to see what the takeoff might be like.
Maybe tomorrow if the weather improves.
Old Jan 02, 2013, 08:08 PM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
Paul,
I'm impressed you have ventured to try out this crazy idea!
I think trying it with the elevons active would be an excellent idea. If you could get it trimmed with the split surface slightly deployed, and then tried the drag pitch control at altitude it might have some hope of success.
I don't imagine it will be that effective for pitch control, particularly at low speeds. I would be interested to know how much elevon throw it would take to re-trim with it closed and fully open.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Jan 02, 2013, 08:58 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Kevin, way back in the olden days of escapement actuated rudder onlys, pitching with rudder was normal.
On gliding approaches, it was possible to flare for the landing by starting a turn in one direction, and rapidly clicking over to the other rudder deflection, with the plane flaring as it passed wings level because of the slight speed gain when pitching down with the first input.
Live Wires would do this well.
Some fliers would sweep the rudder hinge line back to get a bit of up-elevator effect when the rudder was deflected.
I have a few planes that pitch with rudder, usually noticed just before touchdown when feeding in a bit of rudder to correct the heading. My Stearmann was really bad this way!
I really see this as an exercise in self-satisfaction.. there's no possible way it could be practical, when there's well-proven aerodynamic configurations that don't need monster surfaces for routine control.
The radio I'm using is only a 3-channel, with no mixing other than selecting elevons, which re\quires a different servo plug-in configuration at the receiver than the drag-elevator uses.
Maybe a 6 or 7 channel transmitter might be programmable to switch between the elevator-elevon and the elevator-drag surface.
Build Log Delta Vee - Flying Wing with No Movable Control Surfaces jimsky Flying Wings 7 Feb 12, 2010 07:50 PM
Question 4 control surfaces Flying wing??? Edwinzea Flying Wings 6 Sep 05, 2009 11:41 AM
Control surface deflections and drag stjobs Modeling Science 6 Feb 10, 2005 11:58 AM
Drag Reduction with Control Surface Tiplets green66 Electric Plane Talk 0 Dec 15, 2001 01:19 AM
Gyro for pitch control on Flying wing? rparigoris Power Systems 1 Nov 05, 2001 12:44 PM
