Nederland, GE
Joined Jan 2010
actually i do have a airplane i make now and then, which has pitch stability by drag above the CG, hovever it flies at 1:1 glide ratio at best lol.
it is a rectangular piece of sturdy paper but not really card, 10 by 6 cm, folded as follows: 1 time folded in half along the length, then one half folded open again till it stands at a right angle on the "wing". |
The B-35 and B-49 had flaps for the inboard surfaces. I see no need for those on a model. The outboards should be more than adequate for control anyway. The MD-80 cameras I have come with a couple of clip-on mounts. Adding the camera and mount to a hat brim would be easy. Hat cameras need some method of assuring they're aimed where you're looking. The 808 Keyfob style makes a better hat-brim camera. http://www.angelfire.com/indie/aerostuff/HatCamera.htm |
Keven:
Is this the one? http://www.google.com/patents?id=FYK...page&q&f=false |
That's an interesting patent. A method to solve a solved problem... by making the system more complex.
All it needed was for those drag plates to flap and,........
the precurser to single channel 'galloping ghost' ![]() Boy, that brings back memories of the 50's and my first RC. ![]() Found this on Youtube for those that don't know about three functions from one single channel -
Spent many hours with Galloping Ghost. Betcha can't find a Mighty Midget motor today!
Fa-50
The Boeing FA-50 is one of my future fantasy builds. Since it does not have a vertical stabilizers it needs drag rudders. Still trying to figure out placements of the rudders. Wings are small so it looks like it needs to be combined with the other surfaces.
I am thinking of using a Guardian Inertial Stabilizer for this project or a alpha-beta sensor for yaw feedback. Built a glider model with a vertical tail but glide path was about ten feet. So I need to power this thing to see how it flies. |
The biggest problem with that FA50 design is not the absence of vertical surfaces per se, but the fact that there's more vertical area in front of the CG than behind it. It won't just be non-controllable, but actually greatly unstable in yaw. that can be compensated electronically, but you will need to read the actual yaw, you can't just use a gyro.
I thought the Guardian has accelerometers as well as gyros. I do not know the sensitivity of the accelerometers but they should detect slideslip. Drift would be a problem with this. So coupled in with a beta fin should fix this. I can only imagine near stall speeds (high Alph) how much drag rudder deflection that would be needed to keep the yaw stable.
This is all speculation because I have not calculated the dynamics of such a system. I do have a 24" W/S full body test bead that will fly with a vertical. |
| Thread Tools | |
| Build Log Delta Vee - Flying Wing with No Movable Control Surfaces | jimsky | Flying Wings | 7 | Feb 12, 2010 07:50 PM |
| Question 4 control surfaces Flying wing??? | Edwinzea | Flying Wings | 6 | Sep 05, 2009 11:41 AM |
| Control surface deflections and drag | stjobs | Modeling Science | 6 | Feb 10, 2005 11:58 AM |
| Drag Reduction with Control Surface Tiplets | green66 | Electric Plane Talk | 0 | Dec 15, 2001 01:19 AM |
| Gyro for pitch control on Flying wing? | rparigoris | Power Systems | 1 | Nov 05, 2001 12:44 PM |
