Old Dec 29, 2012, 03:39 AM
Brandano is offline
Find More Posts by Brandano
Possibly because the Wright Brothers held a patent on flight control surfaces that was so broad it covered anything from wing twist to ailerons, even though ailerons had already appeared earlier in European designs. It took a world war for that patent to be forcefully lapsed "for the good of humanity", i.e. , to allow other people to build better weapons.
Brandano is offline Find More Posts by Brandano
Old Dec 29, 2012, 07:14 AM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Nope, don't think so. He was using classic ailerons which was one of the big disputes concerning the Wrights. I think this inventor simply thought he had invented something better as a pitch control.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Dec 29, 2012, 09:33 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
When I did the drag control thing - - (which I abandoned ) it was obvious that how the drag is arranged on a aircraft can change trim very easily.
The model would loop nicely , simply deploying the split rudders .
This is the kind of stuff one can try on a model -and see what REALLY happens
richard hanson is online now Find More Posts by richard hanson
Old Dec 29, 2012, 11:48 AM
kcaldwel is offline
Find More Posts by kcaldwel
The post-truth world
kcaldwel's Avatar
Joined Jan 2007
Originally Posted by Thomas B View Post
Found it!....did some random searching on old odd aircraft newsreels and it turned up....: I knew I had seen it in a newsreel.
Thanks Thomas!
I have that news reel on VHS tape somewhere, so that is definitely where I saw it too. Nice to see it fly.
It is a creative way to reduce the performance of an airplane, for no particular gain.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Dec 29, 2012, 12:09 PM
ShoeDLG is offline
Find More Posts by ShoeDLG
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
Unfortunately, I don't think that kind of creativity will ever go out of style...
ShoeDLG is offline Find More Posts by ShoeDLG
Old Dec 29, 2012, 01:16 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Those pictures do not support your point, as the creativity shown in them WAS done for particular gains, unlike the odd experimental wing under discussion....
Old Dec 29, 2012, 01:17 PM
Joined Oct 2007
It's more fun to do it than just comment on it !
Old Dec 29, 2012, 01:20 PM
kcaldwel is offline
kcaldwel's Avatar
Joined Jan 2007
It is an odd world where destroying people and infrastructure is routinely thought of as a gain...
Kevin
Old Dec 29, 2012, 01:30 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
A better image of using control surfaces unconventionally...
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 29, 2012, 01:49 PM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
I tried to find some pictures that highlighted the canted pylons on the Super Hornet, which fall squarely in the category of a "creative way to reduce the performance of an airplane, for no particular gain." They may have been canted for a reason, but not for particular gain.
Old Dec 29, 2012, 02:03 PM
bigjohn is online now
Find More Posts by bigjohn
dare to be dull
bigjohn's Avatar
Deland, FL
Joined Jun 2002
I think you know less about aerodynamics than you think you do.
bigjohn is online now Find More Posts by bigjohn
Old Dec 29, 2012, 02:15 PM
Joined Oct 2007
cant both in and fer shere - you get an up pitch.
given the size n position - probably quite effective
Old Dec 29, 2012, 02:20 PM
Brandano is offline
The F22 introduced the use of rudders as airbrakes. Yes, they do change the pitch trim as well, but that can be compensated with the elevons. It has the advantage of reducing the increase in radar signature that would be caused by using the airbrake. That's also the reason why the B2 uses split elevons as rudders. Adding a vertical surface would be easy, but it would increase the radar cross section massively.
Old Dec 29, 2012, 03:03 PM
ShoeDLG is offline
ShoeDLG's Avatar
Joined Mar 2012
And you base that comment on?
Old Dec 29, 2012, 04:01 PM
richard hanson
A moderator felt this post violated the following rule: Offensive content (Profanity). It is temporarily hidden while richard hanson edits it.
Build Log Delta Vee - Flying Wing with No Movable Control Surfaces jimsky Flying Wings 7 Feb 12, 2010 07:50 PM
Question 4 control surfaces Flying wing??? Edwinzea Flying Wings 6 Sep 05, 2009 11:41 AM
Control surface deflections and drag stjobs Modeling Science 6 Feb 10, 2005 11:58 AM
Drag Reduction with Control Surface Tiplets green66 Electric Plane Talk 0 Dec 15, 2001 01:19 AM
Gyro for pitch control on Flying wing? rparigoris Power Systems 1 Nov 05, 2001 12:44 PM
