Old Dec 23, 2012, 07:11 PM
Joydon is offline
Find More Posts by Joydon
Australia, WA, Perth
Joined Dec 2012
DX7s Li-Po Battery Charging
I have installed a Spektrum 2s1p 4000mAh Li-Po battery in my new Tx, but am concerned that the built in charger in the transmitter is only a trickle charger running at a very low rate and as a result it is taking forever to re-charge the battery ( 24 hours or more) to get it up to max volts (8.2v - 8.4v).
It would have been a lot smarter to have provided an adapter lead with the Tx so that the Li-Po pack could be easily removed from the Tx and charger externally with a standard high performance Li-Po charger, which should be able to charge and balance the pack back to at least 8.2v in about 1 hour.
Any comment from the Spekrum Development Team
Joydon is offline Find More Posts by Joydon
Old Dec 23, 2012, 08:03 PM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
The DX7s will only charge a LiPo pack at a 200mA rate so it will take ~20 hours to charge a depleted 4000mAh pack. The DX7s charging circuit has built in voltage and current regulation so the only practical way to charge the pack faster is to disconnect it and charge it with an external charger.
And it's very unlikely that you will get any kind of official response from "the Spekrum Development Team" in this thread or this forum.
Pete
PGR is offline Find More Posts by PGR
Old Dec 24, 2012, 05:38 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I did as Pete says and charge it with the regular charger. I made an adapter from a servo extension as the pinout width is the same. I set the charger for 2 amps so it took a little less than 2 hrs to charge.
Gord
flypaper 2 is offline Find More Posts by flypaper 2
Old Dec 24, 2012, 06:34 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
A X Max wish of mine is that people would post in the correct Forum Area.
Everything in RC uses batteries but that doe not mean B % C is the best forum.
Surprise ther relly is a Radio Forum as well as arout 300 other specific forums.
http://www.rcgroups.com/radios-135/
Charles
Old Dec 24, 2012, 06:52 AM
ForsheeMS is offline
Find More Posts by ForsheeMS
ForsheeMS's Avatar
United States, NC, Lexington
Joined Jul 2012
MPI makes a plug that will work but you will have to solder banana plugs on and be very careful of polarity. Apparently Spektrum's polarity is backwards from the other brands.
ForsheeMS is offline Find More Posts by ForsheeMS
Old Dec 24, 2012, 07:24 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
There's nothing wrong with charging it in the TX. In my experience the TX cuts off the charge at 8.2v which will prolong your battery life as well. You have to remember this is a low discharge battery, not a high discharge one like you use in your planes.
grimbeaver is offline Find More Posts by grimbeaver
Old Dec 24, 2012, 09:13 AM
PGR is offline
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
Just to clarify something here, unlike the majority of transmitters you CAN'T charge the DX7s through the built-in charging jack with a programmable NiMH or LiPo charger.
The DX7s has a NiMH/LiPo charger built into it and the 12V charging jack powers that internal charger. In other words, there is no direct connection from the charging jack to the battery pack and if you try to charge the DX7s with an external NiMH or LiPo charger you WON'T be able to charge it any faster and you'll probably BURN UP the internal charger.
It also won't help to use a bigger 12V DC power supply. The charging rate of the internal charger is fixed at 200mA. I've charged my DX7s in the field by connecting it directly to a car battery and it didn't charge any faster than with the supplied 500mA 12V DC wall wart.
And for what it's worth, the 12V jack in the DX7s is polarity independent meaning that you can power it with either polarity and it will work fine as long as it's 12V DC.
Pete
Old Dec 24, 2012, 11:33 AM
ForsheeMS's Avatar
Joined Jul 2012
Pete
Pete, thanks for clearing that up. My post was definitely a little misleading. What I used was the MPI part number 2810 plug. Soldered on some banana plugs and removed the battery from the Tx hooking it directly up to my iCharger 206B. I am not charging through the charge port on the Tx. This way I know when the battery is fully charged rather than guessing at it.
Question Charging Li-po with li-ion (tri charger) razorseal Batteries and Chargers 2 Oct 16, 2012 07:02 PM
Help! When should I charge my Li-Po batteries? Farm Kid Batteries and Chargers 3 Jul 22, 2012 12:22 AM
Discussion Storage Charging 1S 3.7V Li-Po Batteries reflective1 Batteries and Chargers 5 Jun 13, 2012 11:07 AM
Discussion transmitter li-po battery charging auxcoord Batteries and Chargers 1 Mar 09, 2012 08:08 PM
Discussion Can any Li-Po charger charge any Li-Po battery? M_I_X Micro Helis 8 Nov 24, 2007 07:46 PM
