Old Dec 16, 2003, 10:34 AM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
No experience, which wood kit to build first ?
This Winter I want to try the building side of the hobby (been saying that for the last two Winters).
I've assembled various ARF foam models.....Twinjet, Zagi, S+B ME 163, Partenavia, MM Lil Hornet, Tiger Moth, well you get the idea. I have virtually no wood kit building skills.
In my posession, I have these kits to choose from:
Kwik-E
Simple 400
Aerocraft Apache
I'm guessing that of the three, the Kwik-E or Simple would be the first to start on. OR should I invest in some "starter kit" before I tackle either of these ? Thanks in advance.
Al P is offline Find More Posts by Al P
Old Dec 16, 2003, 11:12 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
I don't know anything of the kits you have. But id they are lazer cut they should go together easy.
I built the Herr Aquastar, an all lazer cut plane. I was amazed at the ease that this plane went together. The lazer cutting was so exact the wing held itself together without any glue.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Dec 16, 2003, 11:24 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
The Simple 400 is quick and easy to build for someone in your position.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Dec 16, 2003, 11:45 AM
Hal Ray is offline
Find More Posts by Hal Ray
Older but not wiser
Richland, MI, USA
Joined Jan 2001
Have built Herr kits and they are well thought out as are SR batteries kits. All you have to do is follow the directions, the SR directions are the best ( I think ).
HRH
Hal Ray is offline Find More Posts by Hal Ray
Old Dec 16, 2003, 12:43 PM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
I'll echo the SR recommendation. If you've never built a balsa kit, the Cutie or the X-250 (depending on your flying skills) are great first builds. The instructions are second to none.
IMHO, the Herr and Mountain Models kits are in the same league as the SR kits as far as quality and fit, but, while the instructions are good, they aren't the same level as the SR kits.
The only negative to starting with one of these is that you'll be spoiled. You'll expect that level of quality from you're next kit and may be disappointed.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Dec 16, 2003, 12:46 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Mountain Models Kits
Very easy and quick to build plus Doug Binder is available for advice. If you have aileron experience, the Switchback 3D is great especially with a 280 size geared brushless. The sport version is a good aileron trainer. The Cessna 180 is a good slow rudder/elevator park flyer. Avoid attempts at converting of small rubber powered stick models until you have building and flying skills with larger subjects.
E-Challenged is offline Find More Posts by E-Challenged
Old Dec 16, 2003, 12:59 PM
Radioguy is offline
Find More Posts by Radioguy
Winnipeg Intl, Canada
Joined Mar 2002
Hi:
I can recommend the Mountain Models kits as well.
Recently, I finished building my first laser-cut kit ... a Dandy Sport. Until then, I really didn't care for building, it was a necessary evil to get something to fly.
These kits are very well thought through and it took me longer to find the parts on the sheets than it did to actually do the construction operation. With a bottle of "Zap" or equivalent instant glue, you can make very quick progress that provides a great sense of satisfaction and accomplishment in a short time.
These laser-cut kits are a great step forward for modellers.
Best of luck with whatever kit you select.
Regards,
Lee Smith
Radioguy is offline Find More Posts by Radioguy
Old Dec 16, 2003, 02:03 PM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
I've built the Simple 400 and I would say it should make an ideal kit for your first build. The wing is foam so the only building to be done is the fuselage and tail feathers making the transition to "real" building easier.
Personally, the building of my airplanes (and boats, and cars) is at least 50% of the fun in the hobby. Actually, one of the reasons I'm getting out of the RC car part of the hobby is because other than the high-end, race-ready cars, the majority of the new cars coming out are RTR. What's the fun of eating food that someone else has already chewed?
babblefish is offline Find More Posts by babblefish
Old Dec 16, 2003, 03:57 PM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
Hi Al,
The simple kit (since you have one on hand) gets my vote. They are about as simple a build as you can get -- slab sides, rudder and h-stab are one piece, wing is two piece foam..... Cover foam wing and fuse in Ultracote (low temp) and away you go. Just keep the fuse square.... But, I seem to remember you already have a simple 400????
Otherwise, I recommend any of the laser cut MM kits (Tantrum, FB2, SB, MF). Go together fast and accurate. Little more work in covering than the Simple kit however and are more fragile (but lighter)..... The simple kits are flying tanks (tough little planes) .
rclark is offline Find More Posts by rclark
Old Dec 17, 2003, 08:46 AM
RonJ is offline
Find More Posts by RonJ
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
Hey Al,
RonJ here from Wisconsin. Can't believe you've never glued a few sticks togeather and flown them. You're going to have some fun while winter slips away.
#1- build the Simple 400. I have one and it is a very easy build and a superb flyer. Have a 7 turn Mega in mine and if you liked the Electro-Streak you will love the S-400. Use only one aileron servo and add a rudder servo. Increase the rudder area and this little plane will snap roll with the best. 8 KAN's or HE cells will produce at least 10 minutes of excitement.
#2- you gotta get a model from MM (Mountain Models). They are all great flyers and go togeather amazingly. They not only sell the kits but you can order extra wings, etc. if you ding up the originals. The Dandy Sport would be perfect for the Unidome Fly.
http://www.mountainmodels.com/
See you there.
RonJ
RonJ is offline Find More Posts by RonJ
Build Log Building a SA CAP 232 - my first kit and build mrm1 Beginner Training Area (Aircraft-Electric) 242 Nov 14, 2008 09:18 PM
First Kit Build : How much And What to get??? helifan Scale Boats 13 Mar 28, 2005 09:30 PM
First wood kit... ease of building? Huckebein Electric Ducted Fan Jet Talk 7 Oct 26, 2003 04:32 PM
Plouf! First non-kit build pivotal Hand Launch 7 Apr 13, 2003 05:53 PM
What would be a good first kit to build? not ARF Heli Slime Sport Planes 10 Jul 05, 2002 06:43 AM
