This thread is privately moderated by MetroGTi, who may elect to delete unwanted replies.
Old Dec 23, 2012, 11:08 AM
Mexia Izonfia
MetroGTi's Avatar
Monticello, MN
Joined Oct 2003
Maximat Mill Repair
I've got a Maximat V10 lathe/mill combo in my shop. A few weeks ago the gears in the milling head gave out. As the machine was built in the 1960's, replacement parts are non-existent.
The two gears that gave out were the same size, and were made from a plastic/fiber composite similar to phenolic. After quite a bit of searching I found a suitable stainless steel gear blank (Stock Drive Products/Sterling Instruments: S12N15M024S1016) that had the correct pitch angle and tooth count, and could be modified to replace the damaged plastic gears.
The new gear was 2mm too thick, and needed a larger hub diameter with a step. I made an aluminum "collet" to hold the gear blank in my 3 jaw chuck. I faced the gears down to the correct thickness then bored out the hubs. I needed to tailor each gear hub to fit the knurled portion of the original gear shafts for an interference fit
When the gears were done, I put the new blanks shafts in the freezer and the shafts new blanks in the oven. After an hour or so I put the gear and shaft on the arbor press an "Presto!" the shaft goes into the gear.
After putting the repaired parts into the head and adjusting the shift forks I now have a working 4 speed milling head again.
MetroGTi is online now Find More Posts by MetroGTi
For Sale Sherline Mill alarcer Aircraft - General - Miscellaneous (FS/W) 2 Apr 25, 2012 05:16 PM
Sold Fancy Foam Andrew Jesky's Osiris V2 Milled NIB joemetal Aircraft - Electric - Micro & Indoor Airplanes 0 Apr 18, 2012 08:21 PM
Discussion who here Mills their own modeling lumber ? larryg Dock Talk 22 Mar 27, 2012 04:55 PM
Mill/Drill vs. Mill vs. Mill and Drill Frank S The Builders Workshop 10 Nov 25, 2004 12:04 PM
