Old Jan 20, 2013, 04:14 PM
Hossinarizona is offline
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
Sold to Jim pending funds....
Payment received!
Hossinarizona is offline Find More Posts by Hossinarizona
Old Jan 20, 2013, 08:51 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I think I will rent a space and sell some power supplies if there is any interest here in this thread.
12V 12 amp - $20.00
12V 41 amp 500 watt - $50.00
24V 41 amp 1000 watt - $110.00
All units are used server supplies that have been modified for RC charger use. The 41 amp server power supplies' datasheet shows an expected life expectancy of 200,000 hours at max watts. Outside of lightning striking your house when you are charging, these should outlast you.
Also, all pictured supplies are plug-n-play. Just plug your charger to the 4mm connectors, plug supply/supplies into your outlet and charge away.
Why 24V? Some chargers like my FMA Direct PL8 are rated at up to 24 volts (or higher). I can charge batteries with a 12 volt input at half the amps of what I can charge with a 24V input.
Also have about 110 of these:
NEW - 12V 17 amp 210 watt- $30.00 (not pictured)
These will come with a power cord but you will have to screw it to the supply and convert the screw outputs to accept your chargers connectors (usually 4mm bananna type connectors).
Rick
rampman is online now Find More Posts by rampman
Old Jan 22, 2013, 11:09 AM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
RTF Great Planes Christen Eagle
RTF Great Planes Christen Eagle. Includes 5S Power system ( Hacker A50-14SX motor, X-70 ESC and all servos).
Asking $350.00
bruff is offline Find More Posts by bruff
Old Jan 22, 2013, 09:05 PM
wyldkrd is offline
Find More Posts by wyldkrd
Yeah, I can fly...
wyldkrd's Avatar
Mesa, Arizona
Joined Jun 2005
12V 12 amp - $20.00
Rick
I own one of his power supplies and LOVE IT. My Hyperion 730 can take 24v and I use it to charge large 4s packs parallel and run my GT Power Quad charger on the 12c only at the same time. I can charge for a day of flying in about 1 hour.
Good money spent on these
wyldkrd is offline Find More Posts by wyldkrd
Old Jan 22, 2013, 11:17 PM
Jim Varley is offline
Find More Posts by Jim Varley
Glitch Master
Jim Varley's Avatar
USA, AZ, Mesa
Joined Apr 2007
I can vouch for Rampman's power supplies as well, I have the 24 Volt array, and power 2 Hyperion Duos charging 4 6S batteries at 10 amps, and two more Common Sense balance chargers plugged in on the 12V side, charging Rx and Tx batteries at 2 amps each, at once, and it doesn't even break a sweat!
Jim Varley is offline Find More Posts by Jim Varley
Old Jan 22, 2013, 11:46 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
I need a 36 V power supply for my new charger.
bob
Old Jan 23, 2013, 01:29 AM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I can make one out of server power supplies. Have to float the ground like on the 24V ones; its just safer that way.
Rick
Old Jan 23, 2013, 01:59 AM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Talk to you at AEF.
Bob
Old Jan 23, 2013, 11:50 AM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
You WILL need a dedicated 120V 20A drop or two 15A outlets, one from each leg of your panel.
41A x3 in series = 41A and >1500 watts.
Rick
Old Jan 23, 2013, 07:22 PM
swarick is offline
Find More Posts by swarick
Stay Thirsty My Friends
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Can a household outlet handle that much?
Other Rik
swarick is offline Find More Posts by swarick
Old Jan 23, 2013, 07:30 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Will settle for a 24V setup. Don't need to charge a 14S battery at 30 AMPS. Rick you want a Christen Eagle don't you.
Bob
Old Jan 23, 2013, 10:36 PM
Glitch Master
Jim Varley's Avatar
USA, AZ, Mesa
Joined Apr 2007
Bob
Bob, your home probably has 20 amp at the garage outlets, and would be OK as long as your not running something like an air compressor on the same circuit. If Rick makes up a 36 Volt power supply, I have a meter that will read actual amperage of the draw.
Old Jan 23, 2013, 10:38 PM
swarick is offline
swarick's Avatar
USA, AZ, Gilbert
Joined Mar 2005
Is there a way to test for this besides licking my fingers and sticking them in the outlet?
Other Rick
Old Jan 23, 2013, 10:53 PM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Pee on the socket
Old Jan 23, 2013, 10:57 PM
bruff is offline
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Pee on the socket
Can you come over and check it out.
Bob
Discussion For Sale/Trade at AEF crxmanpat Arizona Electric Festival 69 Dec 26, 2013 11:07 PM
Discussion For Sale/Trade at AEF 2012 crxmanpat Arizona Electric Festival 2012 75 Jan 29, 2012 08:00 PM
For Sale planes for sale at AEF or can ship hondaboy92hatch Aircraft - Electric - Airplanes (FS/W) 6 Jan 13, 2010 12:42 PM
For Sale planes fr sale at aef hondaboy92hatch Aircraft - Electric - Airplanes (FS/W) 1 Jan 22, 2009 11:42 PM
Discussion AEF 2007 patches for sale bruff Arizona Electric Festival 0 Feb 01, 2007 11:15 AM
